September 14, 2026, 09:09:54 pm
Hoffman Amps Forum image Author Topic: DC Voltage doubler  (Read 10682 times)
Offline LooseChange
    • Fix Your Darn Amps
DC Voltage doubler
« on: September 08, 2010, 10:15:30 am »
I have a 9v dc power supply.  I want to double it. Got a simple circuit?
Call me Dan
www.fydamps.com
Offline tubesornothing
Re: DC Voltage doubler
« Reply #1 on: September 08, 2010, 10:30:24 am »
Do a search on the net.  There are tons.
I use one like 4-49.
http://www.tpub.com/neets/book7/27m.htm
« Reply #2 on: September 09, 2010, 08:48:36 pm »
I don't think that circuit will work as it requires an AC source which gets multiplied in the rectification process.  But loosechange has a DC source.  A quick google search shows nothing simple; and there's a lot of wasted energy in the process.  Might be simpler to go with an 18VDC source.
« Reply #3 on: September 09, 2010, 09:19:59 pm »
What ToN points to needs _AC_ input. {as jjasilli typed faster.}
And that's really your cheep-n-cheerful option. Go to GoodWill (or my trashcan), find a 9V _AC_ wall-wart, wire pairs of diodes and caps to get 18V-24V DC.
Otherwise....
The dumb-answer is to tie a 9V battery to the end of your 9V supply. 9V+9V=18V.
There are standard chips to sing-up 5V-10V DC into "AC" and diode/cap-double it. Maxim is a big player. Doubler Pumps. ICL7660 and MAX1044 seem to be popular in 9V batt applications.
Offline Heinz
  • Resistance is futile
« Reply #4 on: September 10, 2010, 07:36:29 am »
There are little dc-dc-converter modules that do the trick. They are available for different power ratings and several input/output combinations. They are basically little black boxes with two input and two output pins. Prices are too low to bother with a DIY circuit.
You can find a lot of them in the mouser catalog: http://www2.mouser.com/Power/DC-DC-Converters-Regulators/_/N-5gc7?Keyword=dc+dc+converter.
in tranquilitate vis
« Reply #5 on: September 10, 2010, 09:16:06 am »
Ahhh, should have read the post more carefully.
So if this is coming from a 9VDC wall wart, perhaps use a 9VAC wall wart.  Double it for your needs, rectify for your other DC needs.
