September 18, 2026, 11:09:41 pm
Hoffman Amps Forum image Author Topic: plate to cathode cap  (Read 8767 times)
Offline rdrgtr
« on: September 25, 2010, 12:05:24 am »
I noticed something the other day when I was looking at a preamp circuit (dumble I think).  The circuit called for a 100pf cap from the plate resistor to the cathod.  Basically the cap was between pins 1 & 3 on the first tube stage.  High freq. roll off?  Just curious. :huh:
Re: plate to cathode cap
« Reply #1 on: September 25, 2010, 07:25:08 am »
Yeah, it rolls off some of the highs to "smooth" out the tone.
With respect,Tubenit
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: September 25, 2010, 09:09:45 am »
Any benefit of that application over a small cap across the plate resistor?  (sometimes called a "snubber" IIRC)
Chip
Quote from: jjasilli
Quote from: PRR
Offline RicharD
    • Toxic Water
« Reply #3 on: September 25, 2010, 10:01:49 am »
Snubbers are usually used to control high frequency oscillations.  The down side is it may snub into the audio band.  Often high gain amps need a snubber and can fortunately afford some hi frequency attenuation.
« Reply #4 on: September 25, 2010, 10:03:13 am »
Well, I'll tell you what I've done. Such as on the TOS build, I tried BOTH ways on different gain stages. Sometimes I like the plate to cathode ......... sometimes I preferred across the plate resistor.
I have a cap substitution box that makes quick work of experimenting that way.
I could not find a particular guideline for me other than simply listening to it.
« Reply #5 on: September 25, 2010, 06:59:32 pm »
In principle it makes little difference. Plate is "hot", either B+ or cathode is "pretty near AC ground", so it is a simple plate-to-ground high-roll-off.
You might hear a difference one way or the other.
I suspect in many cases you can just go wherever is easiest.
Offline Merlin
« Reply #6 on: September 26, 2010, 08:21:28 am »
Plate-to-cathode (or plate to ground) is better from the point of view of PSRR, but in practice it makes little difference.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #7 on: September 26, 2010, 10:09:27 am »
Or tie a cap across the plate resistor as in some Fender silver-face amps.
