September 15, 2026, 06:12:45 pm
Hoffman Amps Forum image Author Topic: 6P14P anyone ever use these Russian EL84 equivalents?  (Read 17739 times)
Offline stingray_65
« on: November 03, 2010, 07:43:25 am »
I'm looking at building a class A 25W/channel stereo amp to power my treasured 1957 EV Aristocrats speakers.
I've found a GREAT design thats very simple and straight forward, but it calls for EL86 output tubes.
I've found that EL86's are known to fail in a way that causes damage to the amp and should be replace with any similar power pentode.
I keep seeing these Russian 6n14n's being sold as an alternative to EL84's, but cannot find any reviews on performance.
Any opinions will be appreciated.
Ray
Offline FYL
Re: 6P14P anyone ever use these Russian EL84 equivalents?
« Reply #1 on: November 03, 2010, 11:46:28 am »
Four versions of this excellent tube:
6П14П / 6P14P; bog standard version, large thick glass = EL84, 6BQ5
6П14П-EB / 6P14P-EV; hardened version, longer lifetime = EL84M, 7189
6П14П-EP / 6P14P-ER; special quality, longer lifetime = E84L, 7320 (quite rare)
6П14П-K / 6P14P-K; hardened version, vibration resistant = EL84F (very rare)
As good as any vintage Western EL84. Try to get some pre-1983 6П14П-EB or -EP from Saratov, they are some of the finest EL84s ever manufactured.
Offline moody
« Reply #2 on: November 03, 2010, 08:02:24 pm »
Have used them exclusively for a couple of builds - definitely sound good and haven't had a failure yet (but I haven't been doing it long enough).  According to a few people I've talked to they have higher maximum dissipation than most el-84's.
« Reply #3 on: November 04, 2010, 01:20:03 am »
Hi Ray,
To increase reliability you could add a transient suppression/tube saving mod by installing 3 1n4007 diodes in series on each of the output tube's plates to ground and also install a 250v mov/metal oxide varistor btwn the PT's primary leads. They both reduce transient spikes that can eat up power tubes especially when turned up. The band or "-" should point towards the plates.
Offline stingray_65
« Reply #4 on: November 04, 2010, 05:40:43 am »
Thanks!
Offline fuzz
« Reply #5 on: November 10, 2012, 09:10:08 am »
hi,
I allow myself to bump this thread. I'm into a single end amp design , really simple, no tonestack just a simple RC filter as a tone (but doesn't work verry well actualy) . And I'm using an  EL84 I had in a blackheart amp . But the sound never gave me satisfaction . The tube seems to have a shrill top end which really hurt my ears, really annoying sound. Strange fact , I had the same sensation with the blackheart which was more complex (marshall tonestack) to shape the sound.
So I want to try another EL84 type tubes , especially the old russian ones. (the one I'm working with is a JJ EL84 ) but do you have any recomandations ?
I thought about the 6P14P  (really inexpensive ).
thanks.
« Reply #6 on: November 10, 2012, 02:05:17 pm »
Hi Ray, where you been?
Check your PM mail box.
            Brad       :icon_biggrin:
Offline ssouci
« Reply #7 on: July 23, 2016, 02:48:09 pm »
does anyone know how the older Russian 6P14P-EV (or 6P14P-EB) tubes compare in SOUND quality to the new-manufacture Sovtek EL84M tubes? (the M version, NOT the regular Sovtek EL84)
I've been told that Sovtek EL84M are the exact same tube as the 6P14P-EB, and hence will sound the same
yet, I have found people who say this is not true
thank you!
PS: I am looking for great sounding replacements for an old Fisher hifi stereo amp, that requires 4 x 7189 output tubes... but NOS vintage 7189 tubes are getting very hard and expensive to find, especially in matched pairs
