August 29, 2026, 08:54:28 am
Hoffman Amps Forum image Author Topic: diode sub for 35Z5?  (Read 8567 times)
chuggy
  • Guest
diode sub for 35Z5?
« on: November 07, 2010, 12:31:10 pm »
I'd like to substitute diode rectification in my Kay 703 which has a dead 35Z5 half wave recto.
Would this involve a single diode or string from cathode to plate? What diode(s)? A resistor to substitute for the series heater would be needed.  The data sheet says heaters run at 35 V with .15 A current.... so 233 or so ohms bridging the heater connections?
THANKS-
JIM
Re: diode sub for 35Z5?
« Reply #1 on: November 07, 2010, 01:13:59 pm »
You can use a single 1N4007. Put a sag resistor in series with it to keep the B+ about where it was with the tube. I'd start with 100Ω but experiment to find the best value.
Your math looks good for the filament replacement resistor. Use at least a 10 watter.
You can buy a 35Z5 for $9 at AES. They also have a 35Z4 which should work fine for $2.50.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: November 07, 2010, 01:15:16 pm »
Unless the filament is out, just wire a 1N4007 across pins 5 and 7 and leave the tube in. B+ will go up so use 200V or 250V filter caps.
« Reply #3 on: November 09, 2010, 08:35:07 am »
... B+ will go up so use 200V or 250V filter caps.
Which means buying a new can cap in that amp (in all likelihood). That can costs several times more than a new 35Z5. So it seems like it's "cheaper to keep her."
But maybe you needed new filters anyway. Will a new can rated for higher voltage (due to less diode drop) fit in the old space? Usually there's no room to spare on this type of amp.
chuggy
  • Guest
« Reply #4 on: November 09, 2010, 01:24:10 pm »
Can was replaced with individual caps that fit easily.
Got a NOS 35Z5 via ebay for $1.04, so diodes on hold.
