August 29, 2026, 08:50:39 am
Hoffman Amps Forum image Author Topic: Would this be too challenging ?  (Read 14603 times)
Offline Coastie99
« on: November 16, 2010, 05:43:37 pm »
Hi guys.
I'm relatively new to the amp-building game, and definitely technically challenged.
Having said that, I'm meticulous and fussy, and have managed 5 builds, all of which I'm very happy with.
A friend has asked if I would attempt building for him a ( nominal ) 30W amp, switchable to a ( nominal ) 10W.
Naturally, I have questions, which I'd appreciate somebody answering for me.  Simply.   :grin:
Firstly, let us imagine that there is a Fender design that one might take as the basis.  Good for me, since there's likely a layout diagram available.
Would a switching function be a complex add-on ?
Is there a 6V6 Fender design that attains that ( nominal ) output ?
A 6L6 design ?
And, switching (!!) from Fender ........ is there an EL84-based amp out there that I might consider ?
Any advice would be hugely appreciated.
Thank you,
Gary.
Offline phsyconoodler
Re: Would this be too challenging ?
« Reply #1 on: November 16, 2010, 05:55:04 pm »
"A friend has asked if I would attempt building for him a ( nominal ) 30W amp,"
  You can build any Fender or Marshall style amp and cathode bias it and add a low power switch.Three way power switch,lo,medium and high.
  and if you dig a little you can use variable voltage regulation and make it from 0 to whatever wattage you want.
 Fender Tweed Deluxe
 Fender Deluxe Reverb
 Fender Princeton Reverb
 Fender Tweed low powered twin
 Fender Super Reverb
 Marshall 18 watt
 Vox AC 30
 Vox AC 15
etc,etc,etc,..........
« Reply #2 on: November 16, 2010, 06:01:47 pm »
Does the low power setting need to be exactly like the high power version, but only less power? Or can you also have more distortion, more compression, etc?
In other words, the method of getting to less power may have artifacts. Knowing whether those are allowable could rule in/out a number of approaches.
Offline m3moser
« Reply #3 on: November 16, 2010, 06:04:29 pm »
Not sure you can get 30 watts from a pair of 6V6 or EL84 tubes.  A pair of 6L6 tubes would easily get you to 30 watts, so if that's a requirement then start with those designs.
Offline Coastie99
« Reply #4 on: November 16, 2010, 06:18:50 pm »
Wow, that was quick !
m3 ..... me either.  I did imagine a quad, but then I guess, we'd have too much oomph !!  Trouble is, my friend's not entirely clear what he wants.  He can
"hear" it, and the way he describes it, it's an EL84 sound,  But, he loves the dual 6V6 sound of my Silvertone ..... an entirely different animal.
psych .....  that's nice clear initial info.  Thank you.
hbp .....  not clear there.
Guys, thank you.  Just what I wanted initially.  I'll consult the friend and return in a while.
Gary.
Offline Coastie99
« Reply #5 on: November 17, 2010, 09:17:30 pm »
Great, I have some further info from my friend.
He wants a two channel amp.
He wants 30-ish watts, switchable to 15-ish watts.
He wants EL84's.
Doesn't need tremelo / reverb.  Top boost OK.
Is this one of the Vox AC-30 variants ?   Where do I find a schemo / layout, please ?
« Reply #6 on: November 17, 2010, 09:41:24 pm »
Offline Coastie99
« Reply #7 on: November 17, 2010, 09:55:10 pm »
So would I !!
Thank you most kindly.
Offline Coastie99
« Reply #8 on: November 18, 2010, 01:44:02 pm »
BUT !
Isn't there always ?
We need a dual-channel design.
Offline FYL
« Reply #9 on: November 18, 2010, 01:47:44 pm »
Well, the 36 is a two channel design. Add some glue if you want to add channel switching or use an ABY pedal.
« Reply #10 on: November 18, 2010, 02:22:59 pm »
It is dual channel. It meets all your friends specs. Even better, Ceriatone is in your neck of the woods. Just buy kit, stir in a little solder, serve hot.
Offline Coastie99
« Reply #11 on: November 18, 2010, 02:28:27 pm »
OK.  Please pardon my neophyte ignorance.
A further request from friend ......... could an output be built into this to allow foot-switching between channels ?
« Reply #12 on: November 18, 2010, 02:43:39 pm »
An ABY pedal is an external footswitch that will do that and no extra wiring needed.However,a relay and footswitch jack can be added but it's not paint-by-number to do that,it takes some skill.The ABY box is trouble-free and cheap.
Offline G._Hoffman
« Reply #13 on: November 18, 2010, 02:46:26 pm »
There are a bunch of channel switching options HERE, but adding a relay or some similar channel switching is pretty easy.  I'm told the folks at Cieratone are very good about answering questions, and they could almost certainly help you figure something out as well.
Still, an AB or ABY box would be easier.
Gabriel
Offline Coastie99
« Reply #14 on: November 18, 2010, 02:49:02 pm »
Thanks so much guys ....... we're back on track !
I'll follow up.
Offline Coastie99
« Reply #15 on: November 19, 2010, 01:12:49 pm »
I haven't investigated the footswitch biz. yet, but otherwise we're moving along quite swimmingly.
I've no intention of buying this kit BTW, but building a replica from the layout.
Obviously, I'll need power and output transformers. My Fender-based 6V6's builds have been simple in this respect, but as a ( still ) novice builder, I'm at a pretty-near complete loss regarding trannie specs.
So, kind advisers, what do I need please ?  I am aware that I can spend a moderate amount on trannies, or a lot.  And, I know where to look for them.
Offline FYL
« Reply #16 on: November 19, 2010, 02:33:19 pm »
If you go for a 36, you need to juice 4 x EL84 @ 800 mA ea. plus 3 x 12AX7 @ 300 mA => 4.1 A
PT : 290 - 0 - 290 V @ 200 mA or more, 6.3 V @ 4.0 A, 5 V @ 2 or 3 A depending on the recto you want to use.
OT : primary app. 4 K, secondaries depending on the speakers you intend to use.
Offline Coastie99
« Reply #17 on: November 19, 2010, 05:18:01 pm »
Thank you FYL.
Concise and to the point.  Or ......... easy for a dummy to understand !
Offline Coastie99
« Reply #18 on: November 20, 2010, 04:43:54 pm »
Almost have the green light from friend.  Here's the clincher ...........
Dirty !  Gotta have dirty !!
Will this do dirty real good ?
Found our OT ............. http://www.torresengineering.com/ham50watoutt.html
Offline FYL
« Reply #19 on: November 21, 2010, 07:53:36 am »
Depends on what you mean by dirty. A 36 will go up to nice hard disto, but not up to überdisto modern metal-style.
Not the best option IMO. Try a 1750V if you want to stay with Hammond. Doug's 018343 would work very nicely.
Offline RicharD
    • Toxic Water
« Reply #20 on: November 21, 2010, 10:32:18 am »
He wants EL84's.
You just described the Matchless DC30.  Absolutely a great amp.
http://www.el34world.com/charts/Schematics/files/matchless/matchless_dc30_old.pdf
Ceriatone makes a kit.
http://www.ceriatone.com/productSubPages/Muchle$$DC30/Muchle$$DC30.htm
Offline Coastie99
« Reply #21 on: November 21, 2010, 12:05:13 pm »
We're old geezers FYL ........ metal ain't spoken here.   :grin: :grin:
Thanks for the OT advise.  There's no burning desire for a Hammond OT ....... I'd rather buy from Doug.
{EDIT-- untangled quotes -- PRR}
« Last Edit: November 21, 2010, 02:07:25 pm by PRR »
Offline Coastie99
« Reply #22 on: November 26, 2010, 12:59:25 pm »
Well, things have moved right along, and I have some components on the way from Doug to begin building a Ceriatone 36W.
http://www.ceriatone.com/images/layoutPic/marshallLayout/36WNewCeriatone.jpg
Mostly clear to me, but for a question regarding the rectifier. I'm "seeing" a diode connecting P7 (NC) and P6 (the plate) and the same at P5 and P4.  Surely not !!
Offline FYL
« Reply #23 on: November 26, 2010, 01:14:14 pm »
The diodes are in series between the HV winding and the GZ34, with a shunting HV cap. The diodes protect the valve, the GZ34 still brings some sag/compression. You may omit them if you wish, with suitable rewiring of course - HV straight to plates at pins 4 and 6.
Offline Coastie99
« Reply #24 on: November 26, 2010, 01:19:36 pm »
So, I was right.  Good heavens !!
Thanks FYL.  Is there a compelling reason for their removal ?
Offline FYL
« Reply #25 on: November 26, 2010, 01:29:33 pm »
They aren't required in a 36 but offer a degree of protection. Silicon is cheap, PT's and valves are expensive.
Offline Coastie99
« Reply #26 on: November 26, 2010, 01:38:10 pm »
Not too hard to see the logic in that !
Do you consider this "good practice" in a 5Y3 - rectified amp. ?
Offline FYL
« Reply #27 on: November 26, 2010, 01:47:42 pm »
Ditto: the diodes aren't required but add some protection.
Here's what Ceriatone does in their 5E3 clone:
Offline Coastie99
« Reply #28 on: November 26, 2010, 01:52:15 pm »
Thanks FYL.
I'm mighty obliged to you.
Gary.
Offline Coastie99
« Reply #29 on: November 27, 2010, 03:57:45 pm »
Bit embarrassed to be asking this question, but here goes.
I can see that I need two SPST switches for power on / off and standby.
But, what do I need for the half-power switch ?  I'm in uncharted waters here.   There will be no 16 ohm facility on this amp., so no feedback switch.  OK ?
« Reply #30 on: November 27, 2010, 04:10:48 pm »
DPDT
Offline Coastie99
« Reply #31 on: November 27, 2010, 04:14:37 pm »
On - off - on ?
On - none - on ?
« Reply #32 on: November 27, 2010, 04:17:19 pm »
Just a standard ON/ON DPDT
Offline FYL
« Reply #33 on: November 27, 2010, 04:20:07 pm »
I'd use a DPST for on/off in order to switch live and neutral. Just a precaution.
Looks like a standard DPDT. Two switchable inputs, one output x2.
Nope, the feedback switch allows you to choose between two levels of NFB, giving a looser or tighter sound depending on it's position. It uses the 16-ohm tap, that's all. If the OT you're going to use has no 16-ohm tap ou'll have to scale component values accordingly: using the 8-ohm tap will reduce NFB levels if you don't.
Offline Coastie99
« Reply #34 on: November 27, 2010, 04:32:45 pm »
OK.
DPST for power on / off
SPST for standby
DPDT for 1/2 power. 2 position. On - none - on.
I believe that I will retain the 16 ohm facility to keep things easy !!
Many thanks, yet again.
Offline Coastie99
« Reply #35 on: November 27, 2010, 04:37:54 pm »
Doggone !
Since I'm retaining the 16 ohm outlet, what switch do we have there please ?
« Reply #36 on: November 27, 2010, 04:52:22 pm »
same as all others
