August 29, 2026, 08:52:07 am
Hoffman Amps Forum image Author Topic: capcover, needed ?  (Read 9247 times)
Offline brett
capcover, needed ?
« on: December 09, 2010, 03:59:47 pm »
Hi all,I am building a fender tweed bassman  and using the series filter caps as per the reissue  ( 2x 100 uf in series instead of 2x 20 uf in parallel ) . This is mounted on a board on the back, but wont fit under a cap cover
Does the cover serve any shielding purpose or is it just there to stop fingers poking the caps ( and providing a mounting )
thanks Brett
Offline rafe
  • I have tube amps
Re: capcover, needed ?
« Reply #1 on: December 09, 2010, 04:07:05 pm »
Caps aren't sheilded when they are placed inside the chassis, I think the cover is there to protect from shocks only .... :shocked: touching them can KILL
Rafe
Offline Geezer
« Reply #2 on: December 09, 2010, 04:18:19 pm »
Offline phsyconoodler
« Reply #3 on: December 09, 2010, 04:31:52 pm »
Indeed! Death is pretty final,at least for your body.
« Reply #4 on: December 09, 2010, 04:41:38 pm »
Aside from lethal shock: caps occasionaly burst, spew acid-taint paper wadding. I've had to clean this out of a powered mixer; if it happens, you wish the mess had been contained.
But that's only happened once in decades.
« Reply #5 on: December 09, 2010, 04:51:26 pm »
Look in the Library of Information for Doug's tips on putting the caps in a bassman chassis. You may need to utilize some ingenuity to get everything to fit.
I've touched high voltage d.c. before (about 450v worth). I was lucky in how the situation went down. I promise you that you don't ever want to experience it.  :wink:
Offline Dave
« Reply #6 on: December 09, 2010, 05:09:31 pm »
I've touched it too. I think everybody should experience touching it and not dying at least once. Only trouble is..... how would you know whether you are going to die or not?
Oh well, I'm still here.
Dave
Offline sandford
« Reply #7 on: December 10, 2010, 03:21:26 am »
I watched a kid pee on an electric fenc do you think that compares to your cap experience? Although extremely funny when your young. So not cool for your junk.
WWW
 {_?_}
Offline supro66
« Reply #8 on: December 10, 2010, 05:05:42 am »
They tried it on Mythbusters
The slow motion camera showed not a solid stream lot of dots and dashes
Offline Geezer
« Reply #9 on: December 10, 2010, 08:02:03 am »
Offline 3choplex
« Reply #10 on: December 10, 2010, 08:42:56 am »
The first time I ever worked on an amp, I was changing filter caps. I replaced one, then for some reason pulled it back out without ever having turned the amp on. I touched both ends and the wires burned little holes in 2 of my fingers as well as gave me a good shock.  :huh:
Offline sandford
« Reply #11 on: December 10, 2010, 12:57:38 pm »
 My Buddy Hamiltons pee must of been solid because he ended up on the ground peeing all over himself. I don't think he could of faked that. Mythbusters how do you explain this? huh! Well come to think of it he could of faked it but who intentionally pees on themselves? I suppose one who's intentions initially were to pee on an electric fence. Ham it's been all these years, were you faking? My life is all a lie I don't even know who I am.
WWW
 {_?_}
Offline billcreller
  • 1934
« Reply #12 on: December 10, 2010, 07:54:03 pm »
Seems like a metal cover could be fabricated to cover those.......
« Reply #13 on: December 10, 2010, 09:55:28 pm »
Mythbusters was trying to find out if you could be killed by peeing on a 3rd rail.
That 3rd rail is at the height of the ground you're standing on (or recessed even lower). By the time the stream falls that far, it breaks up.
Maybe your friend was peeing on fence significantly higher than the ground, and didn't get the good stream break-up.
Offline rafe
  • I have tube amps
« Reply #14 on: December 10, 2010, 10:28:42 pm »
OR   :laugh:
&feature=related
Rafe
