August 29, 2026, 08:53:19 am
Hoffman Amps Forum image Author Topic: Hypothetical question  (Read 12199 times)
Offline jeff
  • Need input
« on: December 18, 2010, 05:38:51 pm »
I was reading over a previous post talking about matching OT's for maximum power. It said you want an OT that's equal to Va/(Ia/Va) For example a 6V6 at 12W at 250V you'd want around 5K.
It also went on to talk about running a tube at lower that its max plate watt dissapation. For example running a 6V6 at 6W at 250V. Using that formula you'd want ~a 10K load.
I'm just doing some educated guessing here but does this mean you could run a single 6V6 at 12W or two parallel 6V6's at 6W each with the same transformers? Now I'm not sure why you'd do that but this leads me to my real question.
Is it OK to run two different types of tubes in parallel into one OT?(6V6&EL84)
I was thinking of building a SE amp with a 6V6 and an EL84 whose sockets are wired in parallel but with seperate cathodes and cathode resistors. I was going to put a switch to ground one or the other to switch between the 6V6 and EL84. I thought it'd be cool to have a blend of the two. Is it possible to run both at the same time if I biased each to run at 6W. Each tube could have two cathode resistors, ground one for 12W or the other for 6W. You could ground each individual 12W resistor or both 6Ws at the same time. I don't have enough juice to run them both at 12W at the same time, and by doing it this way I could still use the same OT/speaker load.
Also could you adjust the balance? Running one at 3W the other at 9W?
« Last Edit: December 18, 2010, 05:42:25 pm by jeff »
Re: Hypothetical question
« Reply #1 on: December 18, 2010, 05:44:25 pm »
yes, take a peek at the link below...
http://www.egnateramps.com/Products/Rebel/Rebel20Head.html
-ISO
« Reply #2 on: December 18, 2010, 06:00:07 pm »
Hi Jeff, This is what i was thinking for my Little Booga Project but when it comes to what OT i will use it would be up to someone smarter that me. :huh:
« Reply #3 on: December 19, 2010, 01:25:33 am »
While the EL84 and 6V6 have different enough Gm (transconductance) to require different bias voltage or cathode resistors for a given plate and screen voltage, they operate into similar loads for maximum power. After all, they're both 12w tubes which pass similar cathode currents and operate with similar plate and screen voltages.
What supply voltage will you be using in your amp? Do you want the tubes to both output max power (for about 6-8w total from this amp with both tubes working), or do you mind if the power is lower?
The biggest issue if you want 2 tubes to be running single-ended into a common OT is the amount of unbalanced d.c. that the OT can handle in its primary.
Let's assume you want an amp that keeps the supply voltage low for the EL84, and operates at 300vdc. 12w / 300v = 40mA of idle current in 1 output tube. But you also have that 6V6, so the total idle current is 80mA. The Hammond 125ESE is rated at 80mA d.c., but I don't know how much lee-way their spec allows. I would probably select one of their bigger OT's just on the basis of that spec (even though the allowed power output is much higher than what our tubes can output).
Offline jeff
  • Need input
« Reply #4 on: December 19, 2010, 03:35:24 pm »
Yes but how does this work? Is it just sending less input signal to the grid of one and more to the other or is it shutting off the power tubes?
Offline jeff
  • Need input
« Reply #5 on: December 19, 2010, 03:39:48 pm »
What I'm talking about is running either at 12W by itsself or both at 6W each so the current would remain the same. 6V6 at 12w or EL84 at 12W or 6V6 at 6w & EL84 at 6W in parallel.
« Reply #6 on: December 19, 2010, 03:59:58 pm »
Just try it.
On chalkboard the '84 will clip first, unless you have individual drive adjustments.
On budget-sheet you are paying more for tubes and maybe adjustments than you have to to meet a specified output.
In the DIY world, the "excess" cost is trivial, specs are unimportant, and "flaws" MAY be "tone".
Yeah, ideally you adjust the load for optimum use of costly bottles. But it isn't that critical, "mis"-loading works too.
« Reply #7 on: December 19, 2010, 08:54:21 pm »
And I feel it would be easiest to feed each output tube's grid from an individual volume pot. That way, you can have all of either, none of either, or any mix in-between.
Offline jeff
  • Need input
« Reply #8 on: December 22, 2010, 03:12:11 pm »
 Am I correct in assuming that a tube run at 12W into a 7K load can be run at 6W into a 14K load?
 And that two tubes that need a 14K load run, would use a 7K load in parallel ?
 The reason I want to try this is because my OT and PT can only run one or the other at a time at 12W.
But I reason that I can run two at 6W with the same transformers. This way I'm drawing the same current(maybe a bit more for two screens) and have the correct load. If I ran both tubes at 12W each I kill my PT and my OT would be mismatched. I wanted to have a switch between 6V6 and EL84 but this seems like a nice way to use both at the same time without exceeding my transformer limitations or having to adjust speaker loads.
Let's just, for arguments sake, keep it simple and assume I'm running two 6V6's in parallel at 6W.
In what ways is this different than one 6V6 at 12W?
And what happens when one grid gets a signal and the other's is grounded?
Anyone got an Egnator schematic?
« Last Edit: December 22, 2010, 03:18:26 pm by jeff »
Offline Baguette
« Reply #9 on: December 23, 2010, 06:10:11 am »
Jeff, could you please tell us more about this rule of thumb?
I don't quite get your formula
Offline bluesbear
« Reply #10 on: December 23, 2010, 07:34:03 am »
I made a single ended amp with a 6V6 and an EL84, each with it's own drive. It worked great... except there was absolutely zero difference in sound between the two tubes. As my idea was to have an amp where you could choose between the different tones or mix them, I just switched to a single 6L6. It was a disappointment... but it's still a great little amp.
Dave
« Reply #11 on: December 23, 2010, 08:50:38 pm »
Presenting the Can of Worms:
A SE 6V6 or EL84 won't make more than 4-5w, so the pair of them won't make more than 8-10w. BUT... they will draw 12w of power at idle each, or 24w total. That could stress your PT.
To get less output power with a given load impedance, you'd need less supply voltage to land at less idle current and less power; you can't just bias to less idle current easily. That implies a different PT, but this might be offset by a different consideration; see below.
The load imposed by the OT primary results in a loadline that the tube will follow when a signal is applied. To get simply less power, you would apply a smaller input signal to the grid. You get less power, but the sound is also cleaner (maybe not what you want in a small SE amp). To get less power with the same percentage of distortion at a lower power, you need less supply voltage. That automatically results in less plate current with the same cathode resistor, and less current x less voltage = much less power. This method keeps approximately the same character to the sound.
If you use any load other than the optimum load for max power, you'll get less power. But it doesn't work to say double load -> 1/2 power; that would be true if the tube were perfectly linear, like an ideal resistor. If you use the "wrong load" (either high or low), you'll get less output power, maybe a lot less (depending on how non-optimum).
If you just try to use a crazy-high cathode resistor to bias for less d.c. power, the tube will try to self-adjust to stay at the same idle current. Ask Tubenit (or others that have tried) how easy it is to reduce the idle current by changing the cathode resistor value. The way-big cathode resistor might eventually get the idle current down low enough, but you'd have to be pretty close to cutoff, and now the tube won't accept much input signal before serious distortion. Perhaps this could offset the problem of smaller input signal leading to cleaner output.
There's a couple of key assumptions, and maybe a mis-application here.
The first assumption is that the tube behave like an ideal resistor, which it doesn't. But that would lead to an estimate of power which is greater than what you'll actually get, so the error works in his favor, for what he's trying to achieve. The misapplication is that when this is normally used, you solve for power using the RMS value of the plate voltage swing (total plate voltage swing dvided in half, then converted to RMS by multiplying by 0.7071) and plate current swing (max current - min current divided by 2, and times 0.7071). The 2nd assumption tied to this is that in use, the plate will swing from the idle voltage to 0v and back up to 2x the idle value, due to the inductive kick provided by the OT. The shortcut is to use the value of supply voltage, but the actual RMS swing will be quite a bit less in a class A amp. This also means output power will be less than predicted; that doesn't help our issue with power drawn from the power supply, though.
I think there is an error in the formula as-written. When I manipulate the formula for power and the formula for ohm's law, I get R = Va2/(Va*Ia).
Give us at least your proposed supply voltage. We can step through the back-of-napkin process, and maybe check against a real loadline to see what you'll really get/need.
« Reply #12 on: December 23, 2010, 11:20:07 pm »
Reduces to V/I.
An inductor (transformer) loaded SE amp with a high-efficiency device (Pentode or transistor working at reasonable values) may be loaded with V/I and be very close to optimum power output.
From some popular tubes' datasheet suggestions:
« Last Edit: December 23, 2010, 11:28:20 pm by PRR »
Offline Baguette
« Reply #13 on: December 24, 2010, 05:17:55 am »
Neat trick!
Thanks for clearing this out.
Offline jeff
  • Need input
« Reply #14 on: December 24, 2010, 06:41:46 pm »
MERRY CHRISTMAS
Thanksfor the input. I don't have much time right now but let me digest what you're saying.
I meant biasing them to draw 6W not to put out 6W
« Last Edit: December 24, 2010, 06:43:51 pm by jeff »
« Reply #15 on: December 25, 2010, 06:57:35 pm »
Gotcha.
B+ voltage of your existing PT setup?
Offline jeff
  • Need input
« Reply #16 on: December 25, 2010, 07:36:18 pm »
I can vary the B+ from 330 or 360 depending if I use a real 5Y3 or a Sovtek 5Y3. Keep in mind the drop of the Xformer and cathode resistor. So I think(don't have the amp here) I'm operating one 6V6 at ~300V.
Right now ~300V plate to cathode. My OT is 7K.
« Last Edit: December 25, 2010, 10:22:57 pm by jeff »
Offline jeff
  • Need input
« Reply #17 on: December 25, 2010, 07:41:52 pm »
This is what I thought.
Suppose I use two 6V6's instead of a 6V6 and a EL84
If I run one 6V6 at .04(12W@300V) then the 7K load line would be ~center biased so if I added another tube at .04 It'd be center biased at 3.5K. No prob, change the load. That'd be ok if I had bigger Xformers.
So if I biased one at .02(6W@300V) I'd be ~centered biased with a 14K load. If I used two in parallel I'd need a 7K. Prefect I don't even have to switch loads.
So I'd use a switch: 6V6@.04, EL84@.04, or 6V6@.02 and EL84@.02.
But rethinking it that may not be necessarly true.
« Last Edit: December 25, 2010, 09:44:42 pm by jeff »
