August 29, 2026, 08:51:18 am
Hoffman Amps Forum image Author Topic: Non-matched pair?  (Read 8038 times)
Offline Leevi
    • Rikstone
Non-matched pair?
« on: December 21, 2010, 12:51:35 am »
I'm wondering a weird behaviour of a pair of 6550s.
If I measure the tubes with a measuremt instrument I get about similar cathode current for both tubes.
When I measure the cathode current during the operation (when idle) in the power amp over 1.2 Ohm resistors
the first tube shows 71 mA and second one 64 mA cathode current which means that the deviation is about 10%!
Bias voltage is the same, UL tap voltages show same value as the plate voltage (450V). The cathode resistor values have been
measured and they are same. What could be the reason?
/Leevi
Re: Non-matched pair?
« Reply #1 on: December 21, 2010, 02:52:24 am »
What happen exchanging tubes each other  ?
Kagliostro
Offline Leevi
    • Rikstone
« Reply #2 on: December 21, 2010, 06:44:39 am »
I have not yet tested that. It is the next thing I'll do
/Leevi
« Last Edit: December 21, 2010, 10:45:11 am by Leevi »
« Reply #3 on: December 21, 2010, 10:14:54 am »
May be a stupid question
the 1.2 Ohm resistors (you use as to read the voltage to deduce the current) are perfectly matched ?
Kagliostro
Offline Leevi
    • Rikstone
« Reply #4 on: December 21, 2010, 10:49:14 am »
I switched the tubes and it seems that they behave in different way.
So they are not really matched. To find a real matched pair is the solution.
/Leevi
« Reply #5 on: December 21, 2010, 11:30:12 am »
You can double the bias circuit and give each tube exact drive
Kagliostro
« Reply #6 on: December 21, 2010, 11:49:27 am »
10% deviation is within normal.
« Reply #7 on: December 21, 2010, 12:15:22 pm »
Question:
If you have two bias pots to independantly adjust each tube for evenly matched ma, wont each tube have a different plate voltage on it?
One tube drawing more current than the other? Does that really matter?
« Last Edit: December 21, 2010, 01:33:31 pm by plexi50 »
« Reply #8 on: December 21, 2010, 12:35:15 pm »
I forgot what jjasilli told
If you have two bias pots to independantly adjust for evenly matched tube in ma, wont each tube have a different plate voltage on it?
With not matched tubes the intention is to avoid different prerformances (of the tubes)
Kagliostro
« Last Edit: December 21, 2010, 12:39:21 pm by kagliostro »
Offline Leevi
    • Rikstone
« Reply #9 on: December 21, 2010, 02:44:55 pm »
Yes, that is a solution but since I have installed the trimmer pot in such a way that it is adjustable outside this would cause too much extra work.
Btw. VOX AC50 is a good example of that kind of bias setting.
http://www.webphix.com/schematic%20heaven/www.schematicheaven.com/voxamps/ac50_2.pdf
Leevi
« Reply #10 on: December 21, 2010, 04:49:34 pm »
Question:
What is the d.c. resistance of 1/2 your OT's primary? Could we say 100-200 ohms is typical?
What amount of current difference would be reasonable to balance? Could it be as much as 20-30mA?
If each of these seems okay, then 30mA through a 200 ohm 1/2-primary results in 6v of IR drop. I wouldn't be concerned with 6v of difference in plate voltage.
Most of the impedance that is likely to result in B+ drop is more likely in the B+ line itself, especially the rectifier (if tube) and the PT.
« Reply #11 on: December 21, 2010, 10:05:12 pm »
Thanks HBP. Good explaining. I could live with a B+ or tube plate variance better than a 13ma mismatch
All these years i have had really good tube matches. Now for the last 6 months all i have been getting when i buy the used tubes off Ebay is wide variances between -33ma & -48ma
