September 16, 2026, 11:20:33 pm
Hoffman Amps Forum image Author Topic: Tone stack losses with a cathode follower  (Read 6942 times)
Offline Tone Junkie
« on: December 31, 2010, 01:29:17 am »
I was curious OK here is the thought does a typical TMB tonestack with a cathode follower would it be considered neutral or not adding any boost to circuit,. Adding a slight boost or still negative in gain on the circuit. Im talking a standard fender marshall type . Thanks Bill
Offline JayB
Re: Tone stack losses with a cathode follower
« Reply #1 on: December 31, 2010, 12:29:13 pm »
Slight boost. I'd say about 3 to 5 decibels more. It's hard for me to hear a difference in perceived volume but I could hear that it's brighter. You get more treble, high mids.  A cathode follower has a lower output impedance that makes driving a load with out lose of highs better.
You're going to hell faster than Britney Spears running to a Barber shop
« Reply #2 on: December 31, 2010, 01:44:44 pm »
It definitely adds a boost and when you put a cathode cap on it, it's enough to be used as a lead switch.
Offline phsyconoodler
« Reply #3 on: December 31, 2010, 02:25:08 pm »
What are you guys talking about?
Offline Tone Junkie
« Reply #4 on: December 31, 2010, 07:53:56 pm »
What type of cathode cap are you talking about I say schematics anyone. No just joking,
The reason i asked .I have let several of my friends use my TOS . They asked me Bill would you build us that with two clean channels. because they all use pedals for there overdrive. But they just wanted a standard TMB type tonestack. I dont know why the OD channel is killer but thats what they asked. So my question was really About that because I like the buttery smoothness of the clean channel with the added paralleled tube onto the second gain stage but if the TMB with cf was neutral i would leave it like that . But Tubnit also has it in the TOS light with just two gain stages and still gets the bloom so i could go either way. Better yet one the first way one the second way, one using fender tone stack values the other using marshall. Thanks Bill
« Reply #5 on: January 01, 2011, 07:18:17 am »
Something like this?
« Reply #6 on: January 01, 2011, 07:40:21 am »
OR ........ like this????
Not sure if the Fenderish clean channel would work when switched to the Marshallish clean channel?
Offline Tone Junkie
« Reply #7 on: January 02, 2011, 11:29:46 pm »
Both look like killer idea,s Tubnit . Thanks Bill
