September 17, 2026, 10:54:11 am
Hoffman Amps Forum image Author Topic: baffle material  (Read 8080 times)
Offline CraigB
baffle material
« on: January 06, 2011, 12:46:56 pm »
I've built a dovetailed poplar box for a 1x12 cab.  The baffle will be bolted to wooden cleats.  I've used 5/8 or 3/4 plywood in the past, but wondering if there's other materials you all might recommend that you also prefer over plywood and your reasons for that.  Particle board?  MDF?  Thanks!
Offline FYL
Re: baffle material
« Reply #1 on: January 06, 2011, 02:55:10 pm »
Good quality plywood is purrfect. Particle board isn't very resistant and chips very easily. MDF is usually too heavy and dead sounding when it comes to MI apps.
Offline supro66
Re: baffle material
« Reply #2 on: January 13, 2011, 12:08:40 pm »
Try to find some plywood with at least 5 plys or more
Luan Plywood  is a good choice
Baltic plywood would be the best
prices
http://www.woodcraft.com/Family/2004113/2004113.aspx
Birch  is also a good choice
The less voids the better
This might help
http://reviews.ebay.com/Multi-Ply-Baltic-Birch-Plywood_W0QQugidZ10000000002787534
« Last Edit: January 13, 2011, 12:19:28 pm by supro66 »
Offline stingray_65
Re: baffle material
« Reply #3 on: January 14, 2011, 12:25:56 am »
I've always used Baltic birch.
3/8" (10mm) for 25 W or less
1/2" (13mm) for single 12's 50 watts or less
3/4" (17mm) for 2x 12's 4x12's and high watt 1x12's
3/4" I like to front mount and use a separate grille cloth frame.
Ray
Offline drumslinger2000
Re: baffle material
« Reply #4 on: February 01, 2011, 05:17:06 pm »
Very helpful, thanks Ray.
Offline Frankenamp
  • What does this button do?
Re: baffle material
« Reply #5 on: February 04, 2011, 11:21:48 pm »
+1 for BB
This problem calls for a bigger hammer!
