September 18, 2026, 03:04:14 pm
Hoffman Amps Forum image Author Topic: Questions about doubler - triplers - quadruplers and so on ......... ???  (Read 8321 times)
Which are the differences about a B+ obtained via a standard bridge with condenser
and B+ obtained via doubler - triplers .................
naturally the consumption seen from the transformer is duplicate, tripled and so on
but which other differences ? different ripple ............. different frequency of ripple ?
and also
with SS bridge and condenser the assumption is to multiply for 1.4 so AC100v * 1.4 = DC140v
but what happen if is used a doubler, a tripler, a quadrupler ?
AC100v * 2 = DC200v
AC100v * 3 = DC300v
or instead it is
AC100v * 2 = DC240v
AC100v * 3 = DC340v
Very confused about the math is back to this way of rectify  :rolleyes:
Kagliostro
Offline RicharD
    • Toxic Water
Re: Questions about doubler - triplers - quadruplers and so on ......... ???
« Reply #1 on: January 18, 2011, 03:46:07 pm »
http://www.play-hookey.com/ac_theory/ps_v_multipliers.html
A doubler for all intents and purposes:  Vout = 2Vpeak-(voltage drop of the diodes)  Of course you may need to factor in some loading drop too.  Have you played with Duncan's PSU Designer 2?  It has a doubler circuit but no tripler.  Doublers are cool but get wonky fast under higher current conditions.  For example if you ave a 25V 20mA transformer, you should be able to get 49VDC at 10mA using a doubler constructed from 1N4007's but if you're really demanding 10mA, you're gonna have additional sag.  Yeah we like sag in guitar amps up to a point.  It's probably safe to assume that doublers double the sag too.  IMO, triplers and beyond should be avoided 99 times out of 100.  Suppose you needed 300V @ 100mA.  Your PT would be 100V @ 300mA.  It's like trying to seesaw with a fat man.
Offline moody
« Reply #2 on: January 18, 2011, 05:23:15 pm »
The doubler is a combination of doubling / smoothing and full wave bridge.  Therefore it is double the voltage x 1.4 and then add sag.
I've quite a bit of experience with quadruplers.  From experience, a measured 68volts through a quadrupler should be 381ish.  In reality it is closer to 360 volts.  When run near the edge there is significant sag which approaches the sag you would get from a valve rectifier.
At the same time, the current is divided by the level of doubling and divided by 1.4.  So if you needed 100ma through a quadrupler then you would need 560ma to begin with.
Offline darryl
    • ValveTone Amplification
« Reply #3 on: January 18, 2011, 05:47:21 pm »
I have used voltage multipliers in many amplifier builds without problems, most recently in a set of four amplifiers I called the "holiday family". Details of the first in the series are here: http://www.guitargear.net.au/discussion/index.php?topic=26388.0
The power supply used in these amplifiers was a voltage quadrupler:
The following calculations will be rounded to sensible levels of accuracy, and will ignore effects such as diode voltage drops and transformer regulation.
The power transformer is 56VAC @ 2.4A.
So in a quadrupler, the output voltage is 56 * 1.4 * 4 = 314 volts DC.
The available output current is 2.4 / 1.4 = 1.7  Then 1.7 / 4 = 0.425  or about 420mA.
Actual B+ voltages measured in the amplifier mentioned above were:
1. At turn-on with cold valves:           334
2. Quiescent - valves warm:              319
3. At maximum sine-wave output:       315
4. At max clipping - i.e. square wave:  311
So the theoretical figure matched the observed results fairly well.
« Reply #4 on: January 19, 2011, 09:15:36 am »
MANY THANKS Butterylicious - Moody - Darryl
about math and real world test I think I've understand
but what about noise & Co. ?
In my mind a simply SS rectify gives ripple at the same frequency of the AC Line - 50Hz here in Italy
but which is the ripple frequency using a doubler or quadrupler ?
the 50Hz will rise to 100Hz and 200Hz ?
this higher frequency ripple isn't more difficult to be eliminated than a lower frequency ripple ?
Are these only my conjectures ?  :rolleyes:
Kagliostro
Offline moody
« Reply #5 on: January 19, 2011, 01:28:19 pm »
Darryl, may I ask what the measured voltage of the 56 volt transformer is when actually plugged in?  I have noticed that many of the 30v transformers for example are in real life 34 or 35 volt even when wall voltage is very close to 240 volt exactly?
Offline Merlin
« Reply #6 on: January 19, 2011, 03:05:01 pm »
There are different kinds of voltage multiplier.
Some are half-wave, so the ripple will be 50Hz.
Some are full-wave, so the ripple will be 100Hz.
However, there are some multiplier circuits that are combinations of full-wave and half-wave, so you can get asymmetrical ripple which is both 50Hz and 100Hz!
I devoted a chapter to voltage multipliers in my book.
http://www.freewebs.com/valvewizard2/book2.html
{EDIT -- untangled "/quote" -- PRR}
« Last Edit: January 19, 2011, 05:12:15 pm by PRR »
« Reply #7 on: January 20, 2011, 09:15:10 am »
MANY THANKS Merlin
That is OK
That of my order for your second book was becoming a "Never End Story"
I ordered it to my supplier the 18/12/2010
here:
http://www.libreriauniversitaria.it/c_power_search.php?shelf=BEN&q=merlin+Blencowe&submit=
the 14/01/2011 they sent me a message : "the book at the moment is not momentarily available from our suppliers"
the 14/01/2011 I reordered the book, hoping it will be soon available
the 17/01/2011 I received another message: "the book you previously ordered is now available"
today (20/01/2011) if I look to my order I read: Open, but not delivered  :sad:
Really I'm waiting to read that book, but it seems I must wait some other time ..............
Kagliostro
« Last Edit: January 20, 2011, 09:17:17 am by kagliostro »
« Reply #8 on: January 25, 2011, 01:50:18 pm »
Today I got the new Merlin's PS Book  :grin:  :grin:  :grin:
I think I've something to read for the next days
Kagliostro
« Reply #9 on: January 25, 2011, 07:07:35 pm »
kagliostro,
Hey, you got it.     :grin:     One of these days I've got to get around to ordering that book too.
      Brad
