September 18, 2026, 03:35:39 am
Hoffman Amps Forum image Author Topic: 1M Pot + On/Off Switch  (Read 7035 times)
Offline J Rindt
« on: January 22, 2011, 07:50:23 pm »
Doug sells 2 of these. The CTS is twice the price of the Alpha. All other CTS and Alpha Pots are about the same price. Any of you guys have any experience with these.?
Re: 1M Pot + On/Off Switch
« Reply #1 on: January 22, 2011, 08:05:31 pm »
I've used lot's of switch/pots before, but not those particular ones. You did notice that the Alpha switch opens when the shaft is rotated max CCW and that the CTS switch is push/pull operated?
Offline J Rindt
« Reply #2 on: January 22, 2011, 08:23:06 pm »
Yeah, thanks. I would rather have the "turn to make it go on" pot anyway. Was just wondering why there is such a large price gap compared to the others. Looks like the Alpha wins both times for me.
Thanks Again
« Reply #3 on: January 22, 2011, 11:07:20 pm »
23 billion radios were made with turn-to-click volume controls. I remember that the snap-on switch used to cost 6 cents in quantities.
Pull-switch pots were never that common, and require more complex shafting.
And retail pot-prices are largely arbitrary. If you order a truck-full you get a decent price. When you order one from a guy who buys a few dozen at a time, prices will be all over the map. Sometimes he must order 1,000 even if he will only sell 300. And other times you find a guy who has 700 leftovers he will never be able to unload who would rather have a buck, any buck, now.
« Last Edit: January 25, 2011, 01:26:48 pm by PRR »
Offline J Rindt
« Reply #4 on: January 22, 2011, 11:56:46 pm »
PRR -
Those are good/interesting points that we do not normally consider. The funny thing is, all I need is a rotary On/Off switch. Not sure if those are even made any more. I assume either the Alpha or CTS are designed with Mains Current in mind.
Offline rafe
  • I have tube amps
« Reply #5 on: January 23, 2011, 02:46:45 am »
I have used the alpha from Doug in an old 30's type amp as a replacement. On off and volume, works as it should.
Yes it's an on off switch with a pot stacked under it.....
Rafe
« Reply #6 on: January 23, 2011, 09:47:54 am »
Sure they are. You just have to buy from a big electronics distributor (or maybe from a specialty retailer, like a vintage pro audio dealer) and figure out what part meets your needs.
« Reply #7 on: January 23, 2011, 10:02:25 am »
Radioshack used to sell just the switch to make any of their pots switchable. I've still got a couple in a bag of pot stuff.
