September 18, 2026, 09:50:28 am
Hoffman Amps Forum image Author Topic: YSR1 Traynor 67-72?  (Read 6600 times)
YSR1 Traynor 67-72?
« on: January 23, 2011, 04:43:57 pm »
I just picked up this amp in trade for building a weber 6M18 TMD Kit
I cant believe this. The amp has never been cracked open / It was sealed so well i thought it might be the model that the top did not lift off from
All tubes are high end RCA including RCA EL34's with the dual top getters
I pluged it in and tested the bias and it is -37 ma @ 433VDC
I flipped the standby on and the amp is just incredible in tone / Not a crackle or noise what so ever / Reverb and Trem is sweet
It's the most quiet amp i have seen in a while. I at least expected the Mallory PS caps to need changing but there excellent
The sweet point here is the preamp stages are running at 132VDC & 146VDC & B+ is 433-35VDC
The pots are not date coded seeing as this was made in Canada so i have to find another way to date this amp
It has a 60's power cord on it with the small lines running the length of the cord
Anyone know how else to date the amp? Transformers is all i can think of when i can get to find the numbers
« Last Edit: January 23, 2011, 06:31:56 pm by plexi50 »
Re: YSR1 Traynor 67-72?
« Reply #1 on: January 23, 2011, 11:39:24 pm »
Rubber bumpers denote '70's, probably '72 or so:  http://www.0rigami.com/vb/models.html
There's probably a date code on the pots.
« Reply #2 on: January 24, 2011, 12:42:30 am »
those power resistors look like they may have a date code on them. i'm thinking the electrolytics probably will too.
nice find.  :smiley:
Offline LooseChange
    • Fix Your Darn Amps
« Reply #3 on: January 24, 2011, 04:17:17 am »
Don't know the date but great amp. I've seen a few of these and they all sound great.
Call me Dan
www.fydamps.com
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #4 on: January 24, 2011, 06:31:48 am »
Check out this site ton's of info on TRaynor amps :http://www.0rigami.com/vb/dates.html
« Reply #5 on: January 24, 2011, 10:35:20 am »
Thanks all for the info. I suppose it is a 1972 model. This resistor says so
