September 14, 2026, 04:18:31 pm
Hoffman Amps Forum image Author Topic: Peavey Triumph Switching issue - Help please  (Read 10371 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: February 04, 2011, 11:21:20 am »
See the attached schematic.
The fuse blows only when the footswitch is connected.
Trial and error could blow lots of fuses.
What might be the problem??
Thank you!
>>>>I updated the schematic and attached to a reply below.
« Last Edit: February 04, 2011, 12:57:16 pm by LooseChange »
Call me Dan
www.fydamps.com
Re: Peavey Triumph Switching issue - Help please
« Reply #1 on: February 04, 2011, 12:12:33 pm »
Somehow I'm not finding the footsw on the portion of the schematic posted.  But, meanwhile, maybe use a circuit breaker, instead of a fuse, until the problem is resolved.
Offline LooseChange
« Reply #2 on: February 04, 2011, 12:34:27 pm »
The foot switch circuit is the circuit just the the lower right of the bridge rectifier. It says "6 PIN DIN" at the top of the connector.  Don't have a circuit breaker device. Thanks!
Call me Dan
www.fydamps.com
Offline Geezer
« Reply #3 on: February 04, 2011, 12:42:41 pm »
Do you have a light bulb current limiter?
Offline LooseChange
« Reply #4 on: February 04, 2011, 12:47:53 pm »
Yes. Do you think that will work and actually give me some visual feedback?  The fuse just protects one small part (27v) of the circuit.
Call me Dan
www.fydamps.com
Offline Geezer
« Reply #5 on: February 04, 2011, 12:52:40 pm »
Oh, sorry.....thought it was blowning the mains.......no, that won't help.
Offline LooseChange
« Reply #6 on: February 04, 2011, 12:56:13 pm »
Here is the schematic with the Foot Switch circuit in the red box.
Call me Dan
www.fydamps.com
« Reply #7 on: February 04, 2011, 01:06:33 pm »
lamp limiter will likely still pop fuse - ckt is limited to <30 watts.
with S7 norm/bypass open or closed? if either way there is likely a short in the cable.
look for a short between pin 3 and the shield pin 5 otherwise i'd suspect C33-37  or CR3-5, but that just doesn't seem possible - there are 470 ohm Rs in series with each relay ckt. so the most current that would flow if there were a short behind R54,55, or 56 would be 27V/470R or ~60ma hardly seem enough to blow a 1A fuse. look for cable/connector problem.
Offline rzenc
  • TUBES RULE
« Reply #8 on: February 04, 2011, 01:15:50 pm »
Does it work - switches - without the footswitch? I mean switching thru pannel switches?
Maybe C48 went south?
« Last Edit: February 04, 2011, 03:11:00 pm by rzenc »
« Reply #9 on: February 04, 2011, 09:58:13 pm »
I didnt see this thread until now. Let me go look at that schematic. I have worked on a lot of those peavey amps. I made this circuit breaker 5 years ago or so. Fuses are too expensive to go through them until you find a problem
« Reply #10 on: February 04, 2011, 10:29:07 pm »
plexi, whats the part #/ spec's on it?
            Thanks,     Brad      :smiley:
« Reply #11 on: February 05, 2011, 08:11:29 am »
The parts in my red square are all i can see in the circuit that could cause that fuse to pop. I have heard a pop when switching using the footswitch before and changing those caps was the cure for me
« Last Edit: February 05, 2011, 08:16:11 am by plexi50 »
« Reply #12 on: February 05, 2011, 08:24:11 am »
There is no part number on this one. I got it at my local parts house here 4 years before they closed up
There was a box of about 50 of them. I knew then i should have bought at least 3 of them but i was in a hurry as usual
It was one of those 75 year old electronics part houses that had everything from tubes, testers to scopes and speakers,cloth wiring you name it
What a bummer it is that they closed up. You can get a small breaker like this a from Newark or Mouser im sure
« Last Edit: February 05, 2011, 08:27:23 am by plexi50 »
