August 29, 2026, 11:25:17 am
Hoffman Amps Forum image Author Topic: Where to add Reverb  (Read 5080 times)
Where to add Reverb
« on: February 23, 2011, 01:21:36 pm »
Hi guys, I just read Tubenits post on the FX unit.Again something simple but effective. :smiley: I'm in the process of building the circuit board for the Silver Jubilee and had thought of having a reverb. Looking at the schem i was unable to find a good position for the injection.Thanks
Offline OldHouseScott
    • Old House Recording Studio
Re: Where to add Reverb
« Reply #1 on: February 23, 2011, 02:11:42 pm »
If you're talking about built in reverb, I'd put it right between your FX loop return and the input cap to your V2B stage. I wouldn't go higher than, say, 470k for the direct signal/reverb bypass resistor or you'll lose too much signal through the voltage divider. 220k might be a good place to start. You may also need to play with the mix resistor coming from the reverb level pot to get the correct max reverb level.
OldHouseScott
"We put a little quality in everything we build..."
« Reply #2 on: February 23, 2011, 02:56:26 pm »
This will give you a good idea of what goes where
« Reply #3 on: February 23, 2011, 06:46:59 pm »
I am installing my on board reverbs after the last preamp gain stage just prior to the LTPI.
Essentially in both the Tweed Overdrive and Tweed BluezMeister, I have a passive effects loop going into the LTPI after the preamp and OD gain stages. I use the outboard FX-Reverb in that passive effects loop.
I am happy with reverb insertion just prior to the LTPI. My preference is not to overdrive the reverb, but instead to reverb the overdrive. Each to his own.
« Reply #4 on: February 24, 2011, 12:04:18 am »
Thanks Guys, there seems to be a few options here and all can be easily inserted. I think the plan is to do the build and try the different positions. Thanks
