September 18, 2026, 08:43:38 am
Hoffman Amps Forum image Author Topic: AB763 in a box?  (Read 6044 times)
Offline Searing
  • All's well that sounds well
AB763 in a box?
« on: March 03, 2011, 07:14:28 am »
So, I want an AB763 in a box, like the project Doug has on his site.  I will be using a solid state amp with it.  I just need an input, V2, and the tone circuit, Volume, Treble, and Bass.  A master may be helpful also.  I think?!?  I want to put all of this into the box Doug used for his project.  I don't think I need 2 tubes do I?  So I will send this out to a solid state amp.  Will this work?  Any suggestions on doing this?  Thanks!
Chris
Re: AB763 in a box?
« Reply #1 on: March 03, 2011, 07:31:44 am »
One tube will work for a single channel AB763 preamp. The output would be meant to feed into a power amp, not the instrument input of another amp (ss or tube). But you could pad the output way down to feed into the instrument inputs.
Offline Searing
Re: AB763 in a box?
« Reply #2 on: March 03, 2011, 10:23:08 am »
So, looking at the Schem for AB763 I would tap it out right before the 2 220k's?
Offline Searing
Re: AB763 in a box?
« Reply #3 on: March 03, 2011, 11:19:22 am »
And, I would only need power for the heaters in the one tube right?  No other power would be needed?
Re: AB763 in a box?
« Reply #4 on: March 03, 2011, 11:44:15 am »
No, you still need the B+ for the plates of that tube, also.
            Brad        :smiley:
« Last Edit: March 03, 2011, 02:26:14 pm by Willabe »
Offline Searing
Re: AB763 in a box?
« Reply #5 on: March 03, 2011, 12:55:44 pm »
Ah, and with that B+ I would need a couple of filter caps.  How many?
Offline thermion
  • Repeat Of Fender
Re: AB763 in a box?
« Reply #6 on: March 03, 2011, 01:11:45 pm »
I've used: PT -> 2x 1n4007 -> 2x 20uf for single dual-triode preamps and it works nicely.
