September 18, 2026, 09:35:55 pm
Hoffman Amps Forum image Author Topic: bad oscillation  (Read 11356 times)
Offline Leevi
    • Rikstone
bad oscillation
« on: March 12, 2011, 04:18:15 am »
This amp starts to oscillate with big volume and when the treble pot is
turned to clock position 3 or more. It can be eliminated when turning the full
CUT on. I have noticed that the oscillation level is changing
when I move the shielded wires from PI to the coupling caps in the power amp.
Since it's quite difficult to change the layout I'm asking if there are some
other ways to get rid of it?
http://www.kolumbus.fi/risto.kivioja/RikstoneAmps/PowerAmpC15aReverb.pdf
http://www.kolumbus.fi/risto.kivioja/RikstoneAmps/PreAmpC15aReverb2.pdf
It might also be related to the problem described in this thread
http://www.el34world.com/Forum/index.php?topic=11207.0
/Leevi
Offline LooseChange
    • Fix Your Darn Amps
Re: bad oscillation
« Reply #1 on: March 12, 2011, 06:33:36 am »
You need to kill some of the ultrahigh frequencies. Like fender did on the 70's silverface amps.
I have that problem with one of my builds but you REALY need to crank it up and max out the treble. I left it because I'll never play the amp set like that and didn't want to kill the tone when played within reason.
Call me Dan
www.fydamps.com
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #2 on: March 13, 2011, 08:31:45 am »
I added a 220k resistor to signal way and 100k to ground after the tone stack
and got the oscillation disappeared.
/Leevi
Offline LooseChange
Re: bad oscillation
« Reply #3 on: March 13, 2011, 08:35:06 am »
How much gain did you lose?
Call me Dan
www.fydamps.com
Re: bad oscillation
« Reply #4 on: March 13, 2011, 08:57:14 am »
I added a 220k resistor to signal way and 100k to ground after the tone stack and got the oscillation disappeared.
That's equivalent to turning the master volume down a lot.
Re: bad oscillation
« Reply #5 on: March 13, 2011, 10:40:18 am »
Can you post a photo of the assembled amp?
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #6 on: March 13, 2011, 11:12:58 am »
There is some loss of course, but it's now more equivalent with Matchess DC30/Lightning.
They use similar voltage drop in their amp. I would say there was too much gain before.
You can find the picture in the following location (click Rikstone C15aR)
http://www.rikstone.com/
/Leevi
« Last Edit: March 13, 2011, 11:53:12 am by Leevi »
Offline phsyconoodler
Re: bad oscillation
« Reply #7 on: March 13, 2011, 01:19:06 pm »
Did you use any grid stopper resistors on the control grids of the power tubes?If so,what values? Sometimes oscillations can be from this area.
   Also lead dress is a big factor in a crowded layout amp.
You don't show an interior shot of your amp.That would help.
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #8 on: March 13, 2011, 01:31:55 pm »
Yes, I'm using 1.5k and I agree the grid stopper in this type of power amp is a must.
I think the removal of oscillation is very challenging if there is too much amplification.
Check my previous post, there is a link to the amp (also interior shot)
/Leevi
Offline Geezer
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #10 on: March 13, 2011, 02:43:20 pm »
Yes, it is. However it's working when the master is by passed. Maybe in this case a better
place for master is after PI?
/Leevi
Re: bad oscillation
« Reply #11 on: March 13, 2011, 02:50:11 pm »
Could the speaker mag. be causing a problem? It looks like it's very close to the chassis.
            Brad        :icon_biggrin:
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #12 on: March 13, 2011, 03:17:31 pm »
I think in this case not.
I have built plenty of VOX/Matchless based amps where the preamp has very high gain.
Especially the wiring must be planned carefully around the PI. All the longer wires
must be shielded and there are still very often challenges to get rid of the oscillation.
There are even more challenges if you have foot controls and loop jacks on the other side of the chassis.
Matchless is using in their Lightning similar type of voltage drop probably for the same reason.
http://www.freeinfosociety.com/electronics/schematics/audio/matchlesslightning15.pdf
/Leevi
Re: bad oscillation
« Reply #13 on: March 14, 2011, 10:25:28 am »
Quote:"Yes, I'm using 1.5k and I agree the grid stopper in this type of power amp is a must."
The minimum grid stopper on most all EL84 amps is 8.2k. 1.5k grid stoppers are for Fender amps with 6V6's and 6L6's.They are totally different tubes.It may be part of your issue.The rest might be lead dress and use of shielded cables in the right places.
  Too hot of bias will do nasty things too.I wouldn't run those tubes past 13 watts cathode bias and never past 65% fixed bias.
The gain from an EL84 can be too much and backing off on PI values and attenuating preamp circuits is necessary too.
  If you look at a typical EL84 Pi you will notice how it differs from a 6L6/6V6 design.
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #14 on: March 14, 2011, 11:12:06 am »
phsyconoodler,
Traditionally almost all EL84-VOXs (AC30, AC15, AC10) and the copies of VOXs like Matchless Lightning/DC30
are using 1.5k grid stoppers. I would say 1.5k is more popular than any other grid stopper what
comes to EL84 amps.
/Leevi
Re: bad oscillation
« Reply #15 on: March 14, 2011, 11:43:58 am »
That's on original designs yes.But when you alter lead dress and use higher voltages all bets are off.It couldn't hurt to try a larger grid stopper and see what it does.
  Case in point: Fender 5F6A amps have no grid stoppers at all on the original amp schematics but nearly all new builds need them.They oscillate otherwise.I have had to go as high as 50k on some 5F6A builds with no change in layout from one to the next.
  The oscillation came in the form of a distortion through the speaker.
But in my experience most unstable amps are lead-dress related.Your amps look neat,but some wires may cross in odd ways that can set up an oscillation.
  PI wiring is the most prone to this in my opinion.i had a princeton reverb once that howled at certain volumes levels and a move of a couple of PI wires completly eliminated it with no other changes.
  I find i have the most problems when I deviate from known working layouts to fit the amp into odd chassis.Grid wire length is a reall issue.Sometimes a grid wire that is too long will set the amp up for an oscillation.Simply shortening all the grid wires can make a huge difference.I mean ALL the tube grids,not just the power tubes.
  Contrary to popular belief,I have had less issues with amps crammed into small chassis vs amps put into oversize chassis.
 Long wire runs seem to cause me grief.
Re: bad oscillation
« Reply #16 on: March 14, 2011, 02:28:37 pm »
You're reminding me of advice from Weber's books where he says, plate wires can be as long as you need but grid wires must be kept as short as possible due to the sensitive nature of tube grids' sensitivity and how the wire acts like an antenna. Also, as soon as the plate output wire hits a coupling cap, it then becomes part of the next stage's grid wiring. This is why putting all of the components on a tag or eyelet board (ala Fender et al) looks so pretty but electronically and functionality-wise - this isn't wise to do for these exact reasons especially in a high gain amp. You may get away w/ things in normal gain amps but the higher the gain w/ more stages the more important this subject (& technique) becomes.
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #17 on: March 14, 2011, 02:43:19 pm »
I don't use bigger than 1.5k grid stoppers in the VOX based EL84 amps.
Furthermore the power tubes normally operate quite hot. I agree with you that there is a risk for
oscillation which now and then requires extra effort. Small chassis works better but is
not so nice to wire.
/Leevi
« Last Edit: March 15, 2011, 01:07:49 am by Leevi »
Offline Leevi
    • Rikstone
Re: bad oscillation
« Reply #18 on: March 14, 2011, 03:35:21 pm »
A real point-to-point using terminal strips
/Leevi
This is the guts of a Matchless DC30 custom made by Phil Jamison for Simple Minds guitarist Charlie Burchill. The Matchless point to point system looks wild but it makes for one of the best sounding amps on the market. This is one of three that Charlie uses in his live setup and was just needing a few minor tweaks to get it ready for the Simple Minds tour with the Blue Nile.
Re: bad oscillation
« Reply #19 on: March 14, 2011, 05:42:07 pm »
That looks pretty but also very busy and a bit out of control err lack of orgainization according to layout principles. But, it does illustrate many coupling and tone stack caps soldered directly to their respective pots which likely makes for minimizing grid wire lengths - btwn that and all of the shielded cable runs. He isn't using the philosophy of keeping the filter caps at their respective stages' grounding points though.
That chassis looks just like the demo amp chassis' of what I've seen at the NAMM show in their booth - not a real used amp to be installed inside a "normal" head/cab. Why? Look at all of the 6v bulbs lit up and installed. Why would anyone include all of those for a "normal" giggin' amp unless there was a special plexi front for all of them to light up? But then why all of that for a "giggin amp"?  :dontknow:
Re: bad oscillation
« Reply #20 on: March 14, 2011, 06:31:23 pm »
I have seen a few Matchless amps that have those bulbs inside and they were indeed for lighting up a transparent front faceplate.
  That one looks like it a a couple of modded items inside but it's largely Matchless all the way.
You can get away with lots of stuff with point to point amps,but as the previous poster suggested,the grid wires are all really short.
