September 15, 2026, 10:00:39 am
Hoffman Amps Forum image Author Topic: 6V6 pin 1  (Read 10007 times)
Offline Leevi
    • Rikstone
6V6 pin 1
« on: March 22, 2011, 04:51:55 pm »
Is the pin 1 of 6V6 normally connected to the pin 8 which is cathode?
If not can the pin 1 be used for other purposes like for grid resistor?
/Leevi
Offline bobmegantz
Re: 6V6 pin 1
« Reply #1 on: March 22, 2011, 04:59:45 pm »
pin 1 of the 6V6GTA is not connected to anything (according to my spec sheet).  Older versions may be different.
Re: 6V6 pin 1
« Reply #2 on: March 22, 2011, 07:50:51 pm »
Use it at your convenience if it's a glass tube. Here's what Fender did in the '60s. I like it.
http://www.el34world.com/charts/Schematics/files/fender/DELUXE_REVERB_AB763.pdf
Re: 6V6 pin 1
« Reply #3 on: March 22, 2011, 08:40:51 pm »
In a metal 6V6 (only), pin 1 is connected to the metal shell.
I bet most guitar players have never seen a metal 6V6 or 6L6 in person.
Offline RicharD
    • Toxic Water
Re: 6V6 pin 1
« Reply #4 on: March 22, 2011, 09:28:36 pm »
I think I just got disqualified as a geetar player.   :sad2:
If I'm not mistaken, I have a metal can 6F6 floating around somewhere.
Offline andrew_k
Re: 6V6 pin 1
« Reply #5 on: March 23, 2011, 12:32:02 am »
Ditto  :laugh:
I got a heap of metal RCA 6V6 for peanuts. They sound great to me, so long as you can keep them cool with conservative voltages
Offline darryl
    • ValveTone Amplification
Re: 6V6 pin 1
« Reply #6 on: March 23, 2011, 12:44:02 am »
If the amplifier was only ever going to see glass 6V6's, Pin 1 on the valve socket could be used as an extra tag. Good practice would dictate not using it though, just in case andrew_k bought the amp, and plugged in his metal 6V6's.
Also if someone decided to try some EL34's in that amplifier, the results might not be what they expected.
I'm sure Andrew wouldn't do that though . . .  :icon_biggrin:
Offline Leevi
    • Rikstone
Re: 6V6 pin 1
« Reply #7 on: March 23, 2011, 01:02:44 am »
That was one of the reasons why I asked this?
OK, the OT is not matched to EL34's but that can be fixed by changing the load (speaker).
/Leevi
Re: 6V6 pin 1
« Reply #8 on: March 23, 2011, 06:40:29 am »
/Leevi
You asked specifically about a 6V6. I think it's reckless to plug an EL34 into a 6V6 socket. The people who originally designed these amps would probably 'turn over' if they saw someone plugging in a tube just 'cause it fits the socket.   :huh:
Offline Leevi
    • Rikstone
Re: 6V6 pin 1
« Reply #9 on: March 23, 2011, 08:04:14 am »
Yes, I agree with you but you cannot know/prevent what people do with the amps you have built.
It's quite common that people switch tubes like EL34, 6L6, 5881, 6550... and even 6V6 with each other.
/Leevi
Offline alerich
  • This one goes to 11.
Re: 6V6 pin 1
« Reply #10 on: March 23, 2011, 08:41:25 am »
One of my mod platforms (some old Knight amp) came with KenRad metal 6V6 "tubes". They were not terribly impressive, as I recall and much more difficult to discern of the plates were red plating. Heh.
