September 16, 2026, 02:57:13 pm
Hoffman Amps Forum image Author Topic: Using Amp Preamp Out  (Read 4544 times)
« on: April 18, 2011, 02:49:24 pm »
I have Peavey amp that has a preamp out. Do i have to use a dummy load if i choose not to have a speaker plugged in to the speaker out jack of the amplifier?
Re: Using Amp Preamp Out
« Reply #1 on: April 18, 2011, 03:05:34 pm »
Not necessarily. With a speaker connected just plug a cord into the preamp out jack. Does is interrupt the guitar signal to the speaker? If so, you don't have to have a speaker connected. However, for safety sake, put a d/l on it.
The point is that you can run a tube power amp all day long "IF" you don't send a signal thru it to the speaker. But how would you control access to the amp. Without a speaker or d/l connected, someone will eventually blow up the amp!    :laugh:
« Reply #2 on: April 18, 2011, 03:30:37 pm »
Thanks Steve. I had someone here ask me that question and i said to use a dummy load just for GP.
