September 17, 2026, 09:34:10 pm
Hoffman Amps Forum image Author Topic: 12BH7  (Read 6504 times)
Offline jeff
  • Need input
12BH7
« on: April 27, 2011, 10:32:09 am »
 I notice Doug sells 12BH7. Doing a search I found it was suggested to be good as a reverb driver tube. I notice(correct me if I'm wrong please) that the pinout is the same as a 12AT7. Can you drop one in as a substitute or do you need to tweak the circuit. Anyone have schematics? I'd like to try it out.
Anyone use these tubes?
Can I swap one in for a 12AX7 for a gain stage to try or do you need to tweak?
Schematics?
What are these tubes mainly used for?(in guitar amps)
« Last Edit: April 27, 2011, 10:43:17 am by jeff »
Re: 12BH7
« Reply #1 on: April 27, 2011, 11:19:43 am »
You can drop in, since the pinout is the same.
The 12BH7 has a mu much like a 12AU7. So you could simply try a 12AU7 first to see if you like what's happening.
Because of the low gain, you probably won't deliver as much power to the reverb tank as if you used a 12AT7. Another way to say that is that you'd have to have your reverb channel's volume quite a bit higher to deliver the same power to the tank.
You may not mind the change. Unless you really like a lot of reverb, you might have your reverb knob set to 3-4 to just get a little extra meat around your sound. You will therefore notice that you have to turn up the reverb pot quite a bit higher for the same channel volume setting, and the same amount of reverb. That's not a problem for most folks.
You may want to experiement with a larger cathode resistor. I wouldn't be surprised if you needed to raise it to around 8k or so for decent bias. I tried to guess the idle point with curves, and my estimate is around 9mA per triode with a 2.2k cathode resistor. That's a lot of current for this stage, and you might want to tame it down a bit.
Re: 12BH7
« Reply #2 on: April 27, 2011, 01:24:55 pm »
You should know that depending on your amp (and PT heater current rating/availability) this tube uses twice the heater current as the other 12a_7 tubes. Just something to be aware of when subbing various tubes is to know their specs.
Offline jeff
  • Need input
Re: 12BH7
« Reply #3 on: April 27, 2011, 01:29:38 pm »
Thanks guys
