September 08, 2026, 04:40:22 pm
Hoffman Amps Forum image Author Topic: Traynor DarkHorse 15H Tonestacks  (Read 9245 times)
Offline Boots Deville
« on: June 05, 2011, 07:14:59 am »
Recently kagliostro posted a link to a collection of Traynor service manuals. (thanks for that!)
I've been looking over the Darkhorse 15H schematic:
http://www.traynoramps.com/downloads/servman/smdh15h.pdf
...and trying to make sense of the tone stacks.  The basic idea is this - there are two dual-ganged 100K pots (Treble and Bass) along with a three position toggle (on-on-on) controlling relays which change the tone stack component values and also its location in the signal chain.  They call the settings "Brit", "USA" and the middle position lifts both stacks for maximum gain which they call "Pure".
I'm intrigued by the tone stack as I haven't seen anything like this and I'd be curious to know how it works, from anyone who has played one.
To get my head around it, I redrew the schematic "dumbing down" the tone stack switching so I could see what was going on a little better.  I've attached that below.  I'm not 100% sure I got it right, but I think it's close.
So is this tone stack a new design, or does it exist elsewhere in amp history?  How effective is it?
Also notice the 100K resistor in series with the bright cap on the gain control.  What do you think the design goal is there?
Offline Geezer
Re: Traynor DarkHorse 15H Tonestacks
« Reply #1 on: June 05, 2011, 08:20:48 am »
To reduce the effect of the HUGE 470p bright cap. The largest cap I use in that position is usually 120p, but more often 47p to 68p.
$.02
G
« Reply #2 on: June 05, 2011, 09:06:59 am »
Yeah, I had that thought too, but then why not just use a lesser cap?  Lesser parts count, etc.  Would that resistor alter the taper at all?
« Reply #3 on: June 06, 2011, 07:04:21 pm »
Resistor limits the _height_ of the boost.
Sets the _start_ of the boost.
Both _in conjunction_ with all other parts in the area.
Their values without the 100K would continue to rise in the highest octaves of guitar: ice-pick and hiss. 100K leaves the heavy boost in the harmonics zone without TOO much of the brittle hash.
Note that this network has no effect at full-up or full-down.
Phooey. What an over-stuffed PCB. Obviously they were not trying to reduce part-count.
Offline The_Gaz
« Reply #4 on: June 12, 2011, 07:34:48 pm »
Thanks a lot for the graph, PRR. I think this is a really smart way to tame the brightness that goes a long with a bigger cap, while keeping the voicing the same. I just tried it on a Plexi's bright channel, and am really happy with the results. I used a 470k resistor in series with the typical 470p bright cap, and it cured the 'icepick' while retaining the overall tone.
I had previously tried to reduce the bright cap on the bright channel to 100p, which helped, but made the voicing to similar to the dark channel (where I had already added a 100p to get rid of some muddiness). The 470k in series with the 470p really did the trick. Thanks to the OP and PRR!
« Reply #5 on: June 12, 2011, 08:11:23 pm »
The tone networks are called "T-filters," named in a manner not unlike pi-filters.
The treble (high-pass) network is made of 2 series caps with a resistor to ground; the bass network is the exact opposite (has a cap to ground). To be more exact, the high pass T is a "bridged-T filter" as there is a cap shunting the resistors from input to output.
You see these types of networks in "engineered amps" from Gibson and some others. Treble/bass is normally all you get, and the networks are often fixed with a supplementary tone control.
Offline severthee
« Reply #6 on: January 14, 2026, 10:25:57 am »
Good day, was debating on starting a new topic or zombiefying this 15year old thread. But since some of the info I needed for my inquiry is already here thanks to Boots Deville.
Got this amp on a trade. I like pushing the master with attenuators. There is a bit of brightness being maxed at certain point of the master. It is more evident with the 12au7 than the 6v6. A shrillness nothing a guitar tone can not tame.
I mainly use this for the US and pure setting.
Wondering how to go about modding the tonestack as it is so alien to me compared to the usual tmb.
If i were to convert this to usual fender ab763 values,
I assume the 470pf tied to the gain is what i lower to 250pf for fender specs. But which is the slope resistor and caps for the bass and mids?
I appreciate any suggestion or if not allowed to resurrect, I will gladly make a new thread
