September 14, 2026, 04:01:15 pm
Hoffman Amps Forum image Author Topic: 5670 tubes  (Read 5203 times)
Offline rzenc
  • TUBES RULE
5670 tubes
« on: June 10, 2011, 12:12:04 pm »
Hi,
I would like to know if you guys have experience with this tube type and what are/were your impressions about it. I have some and was thinking about messing with them. They seem to be a good candidate for 12AU7 type of application???
Thanks in advance
Best regards
Rzenc
« Last Edit: June 10, 2011, 12:15:06 pm by rzenc »
Re: 5670 tubes
« Reply #1 on: June 11, 2011, 08:09:20 am »
The amplification factor is about midway between a 12AU7 and a 12AY7. Might be a good low-gain tube for tweed input stages.
Offline rzenc
  • TUBES RULE
Re: 5670 tubes
« Reply #2 on: June 11, 2011, 09:27:24 am »
Thanks HBP!!!
I haven't noticed gain structure, however I did notice transconductance is around 5500uMHOS, which could be employed to achieve low impedance outputs via C.F.'s with around 180 Ohms.
I will give it a try on a FX loop.
Thanks!!
Best Regards
Rzenc
Offline Tone Junkie
Re: 5670 tubes
« Reply #3 on: July 18, 2011, 03:44:35 pm »
Has anyone learned anything more about this tube Im always looking for more tubes to plug in as Im dialing in an amp. I know tubnit has used a 12av7 iwhile playing around I guess this has about the same amplafication facter.
Thanks Bill
