August 04, 2026, 03:00:35 am
Hoffman Amps Forum image Author Topic: 6L6 cathode bias  (Read 23673 times)
Offline rzenc
  • TUBES RULE
6L6 cathode bias
« on: June 16, 2011, 02:18:33 pm »
Hi guys!
I would like suggestions on what O.T. you are using for a pair of 6L6** running cathode biased. I wanna build a standard AB763 - no vib no verb - preamp + P.I. and P.A. but running cathode bias.
RCA chart calls for 9Kohms plate to plate with 360V @ Plates and 270V @ G2.... :w2:
Thanks in Advance
Best Regards
Rzenc
Re: 6L6 cathode bias
« Reply #1 on: June 16, 2011, 03:31:49 pm »
6L6** vs 6L6GC:  Are you sure your chart is for the GC??  9000Kp-p seems wrong.
Offline rzenc
  • TUBES RULE
« Reply #2 on: June 16, 2011, 04:04:42 pm »
Yeah, it's from RCA 6L6GC. File is too large to post.
Offline phsyconoodler
« Reply #3 on: June 16, 2011, 04:39:44 pm »
Look at some other 6L6GC charts.They all say 4.2k or 6.6k or very close to that.
  Does this not mean both tubes add to get 9000 ohms? So 4.5k + 4.5k.  Makes sense to me.
« Reply #4 on: June 16, 2011, 04:47:51 pm »
Ditto.  And, here's some more info:  http://www.thegearpage.net/board/archive/index.php/t-678299.html
But those early Bassmans & Twins were not yet using GC's.  They probably get the large voltage drop from the plate supply to the screen node by using the rather large 10K dropping resistor.  I still suspect that  9000Kp-p spec, along with the max power output.
Output Wattage = Plate voltage2 / OT primary Imp.  Assuming the OT prim imp. matches the plate-to-plate imp. shown on your chart, then:
per your chart Fixed bias @ 360V should yield only about 19W; Cathode bias only abnout 14W.  This does not match your chart.  Something seems to be wrong somewhere.
« Reply #5 on: June 16, 2011, 05:58:12 pm »
What is your proposed supply voltage? The OT primary impedance is not selected in isolation.
Also, cathode bias does not lend itself to deep class AB, high supply voltage or high power output for the tubes. The large current variations of deep class AB mess up the operating point when you sit the tubes on top of a cathode resistor, which ruins the possible output power.
Also, if you run class AB that's not very deep into AB, you tend to use a lower supply voltage, and a smaller current swing. That means you need to use a higher primary impedance to have a big enough voltage swing to get close to maximum output power for that configuration.
No-calculation examples: A higher voltage (450v) deep class AB amp might use a 4k primary (possibly smaller), while a lower voltage (350v) hotter class AB amp might use a 6.6k primary.
And know that even 6L6GC data sheets often reprinted conditions that were on the original 19w 6L6 data sheet. They may not show a condition that takes advantage of all that the 6L6GC is capable of.
Your equation is handy for quick sanity check, but also guesses output power well above real circuits. For your equation to work, the tubes need to have perfectly horizontal curves, equally spaced (perfect linear and no distortion), and the tube must be capable of pulling the plate all the way down to 0v.
It also ignores the fact that watts are calculated using RMS voltages and currents; normally peak plate voltage swing is found from the curves and multiplied by 0.7071 to get RMS/effective voltage swing for power calculation.
But the errors won't be so bad as to confuse 10w output with 1w output, and is close enough for figuring a design on a napkin. It won't help you make sense of data sheet numbers.
« Reply #6 on: June 17, 2011, 10:27:47 pm »
> cathode bias does not lend itself to ...high supply voltage
High voltage is fine; except it leads to awkward high load impedance and suggests G2 voltage awkwardly lower than plate.
Correct. Cathode-bias is upset if current changes from idle to full output, which essentially means Class A, much less output power than possible in Class AB.
(The sheet-snip above says "Class AB", but the cathode current rises only 25%, which is a lot closer to A than to B.)
Look at the page before that. Class A push-pull cathode bias. 250-270V 5K and 14W-18W.
The 270V condition has a nice side-effect: the ~~150mA total cathode current is just about what a 12AX7's heater needs. Free DC for preamp heater.
_______________________________
For marketing reasons, as HBP says, 6L6GC suggestions are mostly old 6L6 suggestions, not taking advantage of the GC's higher G2 and Pd ratings.
Look at 7027. Different pinout, same guts. Middle of page 2 shows P-P self-bias operation.
http://www.mif.pg.gda.pl/homepages/frank/sheets/049/7/7027A.pdf
Offline rzenc
  • TUBES RULE
« Reply #7 on: June 18, 2011, 10:50:11 am »
Cool guys!!! Many thanks for all the information!!!
It's a first time with 6L6** cathode biasing....I have built tweed types - 5E3; 5E9-A - with 6V6 and really liked the sounded. Don't know how much of it's sound comes from output being self vs. fixed. Have you ever have the opportunity to do such test?
I remember some years ago, El Guapo Loco (former member) built a TWIN 5D8 and I had the opportunity to hear him playing harmonica thru it...I must say it was one really fine sounding amp indeed!!!!
I have a 6550 p-p amp (my fav big bad tube) with ability to switch from fixed to cathode bias and although they behave differently, in fixed bias mode there seems to be a kinda punch which is not present on cathode bias mode. On the other hand, cathode bias shows a more smooth amp - biased on the hot side ~ 100mA's per tube @ 430V on plates - with none of the agressive character of  fixed mode.
I think I did not understand what you meant... :w2:
RCA 7027A data sheets shows variations around 30% of cathode current from no-signal to max-signal conditions. Max power varies ~ 37% from condition 1 to condition 3. Effective Load resistance varies a lot. The higher the load, the lesser amount of power output in watts it's seems capable of generating.
Heat generated between specs - heater power was not included - :
condition 1> MAX-SIGNAL POWER OUTPUT: 32W.
no-signal: plate @  44,8W D.C.; G2 @ 2,1W D.C.>>>>TOTAL DCWATTS: 46,9W
max-signal: plate @ 51,2W D.C.; G2 @ 4,8W D.C.>>>TOTAL DCWATTS:  56W
condition 2> MAX-SIGNAL POWER OUTPUT: 36W.
no-signal: plate @   52,44W D.C.; G2 @ 2,128W D.C.>>>TOTAL DCWATTS:  54,56W
max-signal: plate @ 64,6W D.C.; G2 @ 7,6W D.C.>>>TOTAL DCWATTS:  72,2W
condition 3> MAX-SIGNAL POWER OUTPUT: 44W.
no-signal: plate @ 63,75W D.C.; G2 @ 3,4W D.C.>>>TOTAL DCWATTS:  67,15W
max-signal: plate @ 83,3W D.C.; G2 @ 8,5W D.C.>>>TOTAL DCWATTS:  91,8W
Except for condition 1, it seems that audio power output is roughly 50% of generated heat (I'm not considering necessary power from driver).
According to the data sheet PRR provided for RCA 7027A, the most common part I can find down here is 425V @ plates and G2 with 3K8 load, so I will give it a try.
I would like to hear your opinions on how big P.T. needs to be..
Secondary: H.T.> 330 - 0 - 330 @ 350mA's; Fil.1> power tubes 4A's; Fil.2> preamp 2A's. Choke: 20H/50ohms @ 150mA's D.C.
Many thanks in Advance!! You guys rule!!
Best Regards
Rzenc
Offline jbefumo
  • Technical competence is the servant of creativity
« Reply #8 on: March 20, 2017, 08:04:32 am »
Ahh -- I KNEW if I searched long enough I'd find the answer I WANTED .....
I'm building an ultra compact 45-Watt amp using a pair of 6L6s. Would like it to come in around 45-55W.  My initial assumption was that I'd have to go with fixed bias, but I generally prefer cathode biasing.  Just glancing at the 7027A datasheet, and adding a bit of hand-waving, it seems like I should be able to get away with 450V plate I was already planning, coupled with a 4.2k OT load.  Is this reasonable, and more importantly, will it be safe in terms of not destroying power tubes?
Joe
Technical competence is the servant of creativity.
Offline jbefumo
« Reply #9 on: March 20, 2017, 08:05:29 am »
Oh, neglected to mention that I'm thinking in terms of ~45W.
Joe
Offline drgonzonm
« Reply #10 on: March 20, 2017, 03:46:44 pm »
Hi guys!
Thanks in Advance
Best Regards
Rzenc
I have the same datasheet in my collection.  dated 8-60
« Reply #11 on: March 20, 2017, 04:28:58 pm »
Yrs ago, I have used a 20w (1620)  Hammond OT in a couple of 6L6 builds.  I compared volume once between my 23w 5881 cathode biased amp with a Marshall 50w plexi.  The amp heads were side by side played thru the same speaker cab and same guitar.  Not much difference in useable volume, IMO  and in the opinion of the guy who owned the Marshall.  He agreed the 23 watt amp I had would have enough headroom to play in the local clubs in our area.  Just a thought to consider.  Doubling the wattage only gets you a few more decibels.
« Reply #12 on: March 20, 2017, 05:07:03 pm »
I got about the same comment comparing my 23wattish against a 45watt fender, although speaker cabs were different, otherwise same guitar, same player, He even argued my amp was NOT 23watts :icon_biggrin:
« Reply #13 on: March 20, 2017, 11:09:44 pm »
Then why not copy the 44w cathode biased condition on the 7027 data sheet?  425v plate & screen, 200Ω cathode resistor, 3.8kΩ OT.  Plate idles at 75mA each tube (150mA total) and 4mA screen (8mA total).
200Ω * 0.158A = 31.6v
425v - 31.6v = ~393v
393v * 0.075A = ~29.5w
Perfect for maxing out class A in a pair of (true) 6L6GC's.
Offline jbefumo
« Reply #14 on: March 21, 2017, 12:21:43 am »
Pretty much what I'm going to do -- only that 4,2k OTs are easier to find -- I suspect that the difference doesn't amount to much, and figured a slightly higher plate would compensate?
« Reply #15 on: March 21, 2017, 06:47:09 pm »
It's already very close to 100% dissipation, so you would not go higher on plate current.
Rather, you'd just accept very slightly less clean power output by keeping everything else the same except the OT primary impedance.
Offline jbefumo
« Reply #16 on: March 21, 2017, 07:42:07 pm »
Yeah, been cypherin' and simulatin and came to the conclusion that was a bit too close for comfort.  I am, however, going to use Tung-Sol 7581As, which will give me a bet more margin of safety. Else I may just go with fixed bias.
Offline drgonzonm
« Reply #17 on: March 22, 2017, 06:52:44 pm »
.......  Just a thought to consider.  Doubling the wattage only gets you a few more decibels.
Sound like pH is measured in logarithms.
Offline jbefumo
« Reply #18 on: March 22, 2017, 07:31:06 pm »
Yeah -- all marketing ...
