July 28, 2026, 09:30:35 pm
Hoffman Amps Forum image Author Topic: EF86 with morph control in PP gigging amp (finished)  (Read 23129 times)
« on: June 22, 2011, 10:52:51 am »
So much did I enjoy the EF86/morph control in the SE amp that I built a couple of months back, that I thought I'd take the same concept into more powerful gigging amp. (Chassis done on my recently acquired bar-brake)
Finished the (Ef86 concept) version of this amp tonight. Didn't get a chance to really blast it yet, but it sounds very promising.
Happy to say no buzzes or rattles or hums. Tone is EF86tastic! (Need to do some soundbytes). Tone controls need tweaking to get the scoop/hump concept improved upon.
(Edited/corrected) schematic of as-built version with measured idle voltages attached below. I think it needs a voltage tweak in the power rail. I'll chuck a 5AR4 in and see how that goes (or maybe drop the first supply resistor to 4k7).
« Last Edit: June 23, 2011, 07:02:29 am by tubeswell »
Re: EF86 with morph control in PP gigging amp (finished)
« Reply #1 on: June 22, 2011, 12:05:10 pm »
Wow! Looks beautiful.
You do real nice work tubeswell, very nice work indeed.
       Brad         :icon_biggrin:
Offline LooseChange
    • Fix Your Darn Amps
« Reply #2 on: June 22, 2011, 12:19:42 pm »
Nice work!  What's the morph control?
Call me Dan
www.fydamps.com
« Reply #3 on: June 22, 2011, 01:34:47 pm »
In the schematic in his first post.  Looks to be a cap into a 1M pot into a cap into the grid of a CF after the EF86.
Interesting idea!
Offline Tone Junkie
« Reply #4 on: June 22, 2011, 01:38:49 pm »
Nice tubswell you do good work, the morph control sounds cool.
Bill
Offline Tone Junkie
« Reply #5 on: June 22, 2011, 01:43:16 pm »
I also like your use of the 12dw7 tube i think that is an under utilized tube in guitar amps. expecially those with a blues flaver.
Bill
« Reply #6 on: June 22, 2011, 03:23:27 pm »
Interesting idea!
Correct.  Its in Merlin Blencowe's 1st book. At one end of the pot rotation the screen resistor is bypassed to ground (in this case via the 100nF), and the stage functions like a normal EF86 pentode. At the other end of the pot rotation, the 100nF is coupled to the plate via a bigger 470nF (to keep bandwidths about right). The screen is still at the screen voltage but there is screen compression effect and since the screen and the plate become effectively AC-coupled, it acts like a triode, so there is less gain overall. Somewhere in between, you get something akin to ultralinear operation, which sounds quite nice too.
Having the DC-coupled CF stage there is just an evolution of the same thing I did in an SE amp a few months ago.
« Last Edit: June 22, 2011, 03:27:00 pm by tubeswell »
Offline Fresh_Start
  • noob de Lux
« Reply #7 on: June 22, 2011, 03:36:12 pm »
Bill
I understand using Section 2 of a 12DW7 as the cathode follower if you need to push a lossy tone stack.  Did you design the circuit with that tube from the start or was 1/2 of a 12AX7 not giving you something you get with the 12DW7?  Does it do the compression thing that tubenit likes so much better?
Thanks for sharing.  NICE looking build.
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #8 on: June 22, 2011, 03:58:42 pm »
Bill
Chip
Hi Chip
I initially built a SE amp with this kind of EF86 stage and Big Muff tone stack, and it was very nice, but for this one I thought I'd try the DC-coupled CF with a 12AU7 to see how it sounded, and I'm liking it a lot.  The 12AT7 in the LTP makes it sound extra sweet as well (altho' the extra current draw does lower the HT voltage a wee bit, compared to if you plug a 12AX7 in there).
« Reply #9 on: June 22, 2011, 04:30:21 pm »
Very nice TW, that's one to be proud of and well thought out even w/ extra long ac chord. You've put a lot of things in there I like to see w/ good values too. I'm sure it sounds like it's designed and the speaker is one of my favorites too. It looks like you made the cab to go w/ that custom chassis? What, no finger joints? (just kidding you) I'd like to hear some sound bites of her.
« Reply #10 on: June 22, 2011, 04:30:35 pm »
Very Very Nice Job !  :bravo1:
which is the purpose of the double ganged pot ? have you a PPIMV ?
can you post a link to the schematic of the SE version amp ?
Kagliostro
« Last Edit: June 22, 2011, 04:38:25 pm by kagliostro »
« Reply #11 on: June 22, 2011, 04:34:02 pm »
can you post a link to the schematic you posted ?
Kagliostro
Thanks Kagliostro
That pot is just a (rare) double-ganged 5MRA pot that I'm using in parallel to get 2M5RA for the trem speed pot (using the 5G9 trem circuit for that off-your-face slam).
link is here: http://www.el34world.com/Forum/index.php?action=dlattach;topic=11813.0;attach=24182
« Reply #12 on: June 22, 2011, 04:36:35 pm »
Thanks jojokeo
As for the soundbytes, I'll get a man on it right away ;-)
« Reply #13 on: June 22, 2011, 04:49:30 pm »
Hi Tubeswell
Oh ....... I see
thanks for the schematic
have you posted also the SE version ?
I'll repeat, really a well build amp
Kagliostro
Offline Fresh_Start
  • noob de Lux
« Reply #14 on: June 22, 2011, 10:09:36 pm »
Taking a second look at the schematic as a whole, I really like your design.  You obviously put a lot of thought into it.  The color coded ground points on the schematic is a nice touch.
I can tell you've read the "Immortal Amplifier" articles (solid state diodes before the rectifier tube).  Is the second fuse on the HT line before the Standby switch?  (not shown on schematic)
Cheers,
Chip
Quote from: PRR
« Reply #15 on: June 22, 2011, 11:00:19 pm »
very nice work.  :icon_biggrin:
those bias test points are all going to read "0". hope it's just a schematic error.
--DL
« Reply #16 on: June 23, 2011, 01:33:29 am »
--DL
 :laugh: good eye. Funny how simple things like that can pass right by you but it is still understood. Like in an emial ocne wehre if the ltetres bceome jmubeld a sntence can sltil be itnrepetred.
« Reply #17 on: June 23, 2011, 06:05:47 am »
--DL
Indeed - thanks for spotting that! (How could I make such a clanger?). Of course they are actually wired properly (and they work the way I wired them) ;-) (Edit - I have now fixed that)
« Last Edit: June 23, 2011, 07:03:11 am by tubeswell »
« Reply #18 on: June 23, 2011, 06:06:52 am »
Cheers,
Chip
Thanks Chip
Yes the HT fuse is before the std-by switch
« Reply #20 on: June 23, 2011, 01:56:36 pm »
Thanks for the SE link Tubeswell
Kagliostro
« Reply #21 on: June 29, 2011, 08:40:13 pm »
Wow! I've just tried Merlin's 'Bone Ray' tone stack in this (using 1M pots and 1/2 scaled caps). Feckin' awesome! I've got to get some soundbytes up
Offline zendragon63
  • Vacuum Packed Tone
« Reply #22 on: June 29, 2011, 10:14:19 pm »
Very nice work tubeswell! Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
« Reply #23 on: June 29, 2011, 10:47:10 pm »
Updated Schematic (with voltages from 5AR4)
Offline Tone Junkie
« Reply #24 on: June 30, 2011, 02:29:00 am »
Thats definatly interesting tubeswell, i like the names on the function tilt and middle if Im reading it right, cool looking tonestack cant wait to hear the clips.
Thanks Bill
« Reply #25 on: July 01, 2011, 02:47:56 pm »
I looked in the preamp book but it wasn't there. Where'd you find this please? Is this a combo of the tilt and shift controls? Thanks TW
Offline Fresh_Start
  • noob de Lux
« Reply #26 on: July 01, 2011, 03:56:08 pm »
Searching for "bone ray tone stack" on AX84 turned up a discussion from 16 months ago where Merlin presented this circuit.  I can't figure out how to link to a specific thread on that forum though.
Happy Independence Day!
Chip
« Last Edit: July 01, 2011, 03:58:22 pm by Fresh_Start »
Quote from: PRR
« Reply #27 on: July 01, 2011, 06:17:07 pm »
FYI
« Reply #28 on: July 01, 2011, 06:31:33 pm »
Thanks FS & TW. I like how he came up w/ the new name, word playing the "other" stack's letters.
TW - what caused you to change the values that you came up with? How does it differ from Merlin's?
« Reply #29 on: July 02, 2011, 12:00:20 am »
I just scaled the resistances x 2 (and correspondingly reduced the capacitances by half) because I only had 1M pots on hand. (I could've gotten some 500k pots from the local shop but I couldn't be bothered). Same freq roll-off point, but smaller AC load in mine version (although probably quieter with Merlin's version - even so, mine doesn't have too much noise in the S:N ratio)
« Reply #30 on: July 02, 2011, 01:04:17 pm »
Hi Tubeswell
I've one other curiosity
Wich is the AC voltage of the bias tap in the transformer you used ?
Kagliostro
« Reply #31 on: July 02, 2011, 01:12:37 pm »
Hi Tubeswell
Kagliostro
45 or 50VAC IIRC (a wee while since I measured it) The PT I'm using for this actually has a separate bias winding.
« Reply #32 on: July 02, 2011, 01:17:44 pm »
I asked because of that diode connected to the 82K resistor and 10uF without any indication about
as allways you were very kind
Many Thanks
Kagliostro
Offline Tone Junkie
« Reply #33 on: July 18, 2011, 03:47:27 pm »
tubeswell how are you enjoying this amp now after it has had time to break in a bit.The morph control sounds very interesting would this work on a 5879 tube.
Thanks Bill
« Reply #34 on: July 18, 2011, 04:25:38 pm »
It will work w/ virtually any pentode set up correctly. All it does is transition from pentode to triode mode where a switch does one or the other.
Offline Tone Junkie
« Reply #35 on: July 19, 2011, 12:11:02 am »
Cool I will study more.
Bill
« Reply #36 on: July 19, 2011, 12:47:40 am »
The screen bypass cap (going from the screen resistor to ground) needs to be big enough (in conjunction with the R value of the screen resistor) to bypass all the relevant frequencies of concern to you (i.e.: to ensure that those frequencies are boosted at the roll-off point desired). And the other cap needs to be about 5 x more capacitance than the bypass cap, since the two caps will end up in series when the control is in 'triode mode', and you don't want only high frequencies to be triode connected (which is what would happen if the two caps were close in capacitance value).  The screen stays at 'screen voltage' throughout, but in triode mode it is connected at AC to the plate and not bypassed. With the pot set at 'in-between' settings, you get ultra-linear operation, which can sound quite funky.
Offline terminalgs
« Reply #37 on: July 20, 2011, 10:25:31 am »
very cool.
how did you select the  values of the 100K and the 15K resistors on the plate of the High-Mu section of the 12dw7 ?
Is it the idea that it forms a 115k plate resistor for the tube, and a voltage divider for the signal that cuts the signal to about 10%?
« Reply #38 on: July 20, 2011, 02:12:06 pm »
That stage, and the stages after it, are simply lifted from the 6G3.
Offline Tone Junkie
« Reply #39 on: July 20, 2011, 11:43:39 pm »
I notice it has one of your favorite vibrato, is that a 5g9 type, and after some time playing how are you feeling about the bone ray tone stack.
Thanks Bill
