September 14, 2026, 07:07:40 am
Hoffman Amps Forum image Author Topic: Power Supply - one other question  (Read 7861 times)
« on: July 30, 2011, 04:04:38 am »
Is near impossible to find Power Transformers (for preamp circuits) that can fit in U1 rack units
So the use of small PCB transformers (10VA) back to back
220v – 9v / 9v – 220v that rectified give near 300v B+  ( 220v x 1.4 = 308v)
But there are circuits that need higher B+
Someone tried to obtain more B+ using different rating transformers back to back
220v – 12v / 9v – 220v  (220v/9v = 24.4 than 24.4 x 12v = 293v) that rectified gives near 410v B+
But this way there is core saturation and the transformer must be oversized or became hot quickly (also oversize with U1 rack don’t match)
To use two back to back arrangements in series (220v – 9v / 9v – 220v + 220v – 9v / 9v – 220v) will give an AC voltage of 440v that rectified is 616v, too high for preamp purpose
So I’ve think to use a different back to back arrangement  like this
220v – 6v / 9v – 220v + 220v – 6v / 9v – 220v that will give 146v + 146v = ~293v AC that rectified will give near 410v
The question is:
Giving to the second transformer a lower input voltage (6v instead of 9v) will be a safety way to obtain the needed B+ voltage avoiding core saturation & other problems ?
Re: Power Supply - one other question
« Reply #1 on: July 30, 2011, 04:24:38 am »
I think this could work for you, have you seen these before?
http://www.antekinc.com/details.php?p=655
or this one
http://www.antekinc.com/details.php?p=639
« Last Edit: July 30, 2011, 04:37:26 am by jojokeo »
« Reply #3 on: July 30, 2011, 08:20:44 am »
How about these from Hammond?
http://www.hammondmfg.com/229.htm
        Brad      :think1:
« Last Edit: July 30, 2011, 08:24:44 am by Willabe »
« Reply #4 on: July 30, 2011, 12:13:42 pm »
Many thanks friends
Jojokeo
the price is good and also transformers seems to fit U1 space and needed current and voltages
Unfortunately I live in Italy so I'm looking for Europe market suppliers
VMS
the first transformer is a bit expensive for a preamp need but may be nice for a little amp
the second one (Torodial 27VA Preamp / Engl 520) seems to be a good choice (240v x 1.4 = 337v DC) also if not perfect for High Voltage request of some preamp
Willabe
Hammond 229 series, I know that (and can buy it directly here in Italy) but the B+ voltage isn't so high (220v x 1.4 = ~308v)
Kagliostro
p.s.: technical question
using the 220v - 6v / 9v - 220v + 220v - 6v / 9v - 220v to obtain the ~293v AC I think I loss current, isn't it ?
« Reply #5 on: July 30, 2011, 12:54:45 pm »
Just a suggestion. They will ship as many transformers in a box as possible for one shipping fee and could utilize flat rate int'l shipping which combined w/ the low pricing of the tranny's would make things more do-able & reasonable for you and justify the higher shipping cost? Medium flat rate is about $45 but you may get away w/ small flat rate for $13.95 US and they may still be able to fit in 7 or 8 easily? But if you only needed one or two then the shipping fee is still reasonable.
« Reply #6 on: July 30, 2011, 01:24:07 pm »
Jojokeo
there isn't only the shipping problem
you must (unfortunately) consider also TAX ( :sad2: don't want say more about :sad2:)
Kagliostro
« Reply #7 on: July 30, 2011, 01:33:38 pm »
How much would that be? Sorry, I have no idea what it would be for you, what would you have to pay in Italy?
« Reply #8 on: July 30, 2011, 01:58:20 pm »
I'll pay the tax applied in the USA (VAT) more the tax applied in Italy (I.V.A.) more the customs duty
the I.V.A. will be 20% and custom duty 4.2% (EDIT someone told me there is a more, not better specified 4% to be paid)
to consider also that sometime ago I ordered a book in the USA (Guitar Amplifier Power Amps - Richard Kuehnel) and I wait for it 3 months
So you can understand I am compelled to prefer european suppliers  :dontknow:
Kagliostro
« Last Edit: July 30, 2011, 02:36:45 pm by kagliostro »
« Reply #9 on: July 30, 2011, 11:36:22 pm »
6V applied to a "9V" winding is safe.
The current rating is unchanged. So the total VA or Watts-DC is 6/9 or 2/3 of what you paid for. This is a "tax"; but much less than the man in the uniform would take for importing luxury goods that compete with your home industry.
You don't need a lot of current. Caps are cheaper. Use the Voltage Doubler.
« Reply #10 on: July 31, 2011, 12:03:27 am »
I have to ask since I've been on a cap info mode recently: would balance resistors be used across the caps to even the current between the two like when used is series situations?
« Reply #11 on: July 31, 2011, 12:12:16 am »
In this type voltage doubler, no. It works as two half-wave power supplies. Each cap is *forced* to 205V, no matter what's happening on the other cap.
In conventional supplies that don't have a half-voltage connection: yes.
« Reply #12 on: July 31, 2011, 03:03:36 am »
Thanks PRR for your intervention
the PCB transformers I have are rated at 10VA
(I got it on the cheap, € 2.00 each, initially thinking to use only for filament purpose, they fit near exactly the U1 available space)
so I can have near 0.03A (6/9 = ~0.7 -- 10VA x 0.7 = 7 -- 7/220 = 0.03A)
than I must consider losses of the transformer ........... may be 0.025A .......... is that correct ?
using a doubler I loss half of the current, so ~0.013A ........... I think is too poor, isn't it  :w2:
can you give a rule of thumb as to estimate VA requested in relationship to the kind of tubes usually present in the preamps (such as 12ax7 - 12at7 - 12au7 - 12ay7 - 6sn7 - 6au6 - 12sn7 - ef86 - 5879 - 5751 .........) ?
don't know if that is possible but this will be of GREAT help
Kagliostro
p.s.:
Hope one day this will be only a bad memory, but I think we must wait much before that happens .................
« Reply #13 on: July 31, 2011, 11:07:15 pm »
The biggest problem with shipping from the US to Italy isn't even the tax (although it is bad). The problem is customs.
I sold something on ebay one time to an italian buyer. I shipped it promptly. It sat in customs for 4 months(!) with the buyer unsure if I stole his money. He did eventually get his item, but I swore off shipping anything to Italy after that.
