September 15, 2026, 12:41:42 pm
Hoffman Amps Forum image Author Topic: Drive voltage enough for SE el34, kt77, and 6L6 tubes?  (Read 17896 times)
« on: August 18, 2011, 01:54:41 pm »
Looking for help in figuring how many 12ax7 stages is needed to fully drive a single ended amp using any of these power tubes. I believe the EL34 data sheet says that for SE use, the grid no. 1 driving voltage needs to be 8.7 Vrms. On the 6l6-gc it says for cathode biased "peak AF grid no. 1 voltage = 12.7 volts"
Can a typical Fender-ish simple preamp w/ a single 12ax7 tube being - first stage > tone stack > second stage be enough to achieve this objective? Or if there was no tone stack, would that be enough to do it?
« Last Edit: August 18, 2011, 04:28:52 pm by jojokeo »
Offline rzenc
  • TUBES RULE
Re: Drive voltage enough for SE el34, kt77, and 6L6 tubes?
« Reply #1 on: August 18, 2011, 03:21:05 pm »
Do you have a building block topology?  Schema?
« Reply #2 on: August 18, 2011, 03:47:52 pm »
I'm not on home computer but this is close enough and typical. B+ = 280v
« Last Edit: August 18, 2011, 05:00:43 pm by jojokeo »
« Reply #3 on: August 18, 2011, 05:34:16 pm »
You're asking the wrong question.
Better question:
What is the amount of bias my output stage is using?
Look at the data sheets you cited again. The value of the "grid 1 driving voltage" or "peak input voltage" will be equal to the absolute value of the bias voltage of the output tubes. You will get all the power output  the stage is able to make (unless you have a class AB2 or class B2 stage, and a special driver) when you drive the grid momentarily to 0v.
You will note the same for push-pull stages, except they cite a voltage as "grid-to-grid" which is then double the bias voltage.
Ultimately, this question boils down to supply voltage available, and phase inverter topology.
And, it also means that you design your output stage first, then figure out what the inverter must be capable of delivering (allowing for excess capability), then deciding what your preamp will look like. The inverter design has to assume some fixed, relatively-low input signal level, such as 1v or so.
So that also means that to design your output stage, you have to have a solid idea of what power transformers are available, how much power can be drawn from them, and what supply voltage you will have to work with.
Offline rzenc
  • TUBES RULE
« Reply #4 on: August 19, 2011, 06:30:09 am »
I used Merlin's loadlineplotter with your figures and got the following results.
I believe you may be able to get a signal swing capable of driving either tube to max power out.
Hope this helps.
Rzenc
« Reply #5 on: August 19, 2011, 09:54:20 am »
I think I see jojokeo's point.  If you get a workable Mu of 50 out of a 12ax7 tone recovery stage; and after the tonestack there's only 200mV of signal; then the tone recovery stage makes only 10V of signal to drive the power tube.  However this is very rough figuring and all may work out well.  One alternative:  12bz7 instead of 12ax7.
« Reply #6 on: August 19, 2011, 11:49:07 am »
HBP - I was thinking you would have good info on this. I've seen prior posts where you've figured gain & signal voltages as it goes through the preamp stages. I was going to pm you on this but thought it would be far better for others to see and learn also.
I did use the Duncan calculator for load lines, calc'd out specifics on current damands, etc. when choosing the PT but I cut things too close trying to save $25 bucks or so on the minimun power tranny specs I could get away with in the meaning of "if I were to make more of these, how low could I go in costs to reproduce this amp" and also "how close to the fine line can I get this done with". I guess I pretty much achieved my design goals but now my desire has changed a bit as I want max performance out of the power tube and I don't think I quite got there?
It sounds great as is but, the tranny runs a bit hot for my liking when I bias it hotter and as it turns out, I'm hoping w/ a higher voltage PT upgrade that not only will the PT run cooler & use less current in doing so that I would be able to bias it hotter, get the full Pdiss from the tube, it may sing better and also make a bit more headroom and output power too? All positives! However, I want to be sure that there's enough signal voltage to drive the power tube properly also before I undergo the necesssary changes. This post is my one last confirmation before I dig back into the amp to modify things and I want to be absolutely sure I've got all of my information correct before I do so.
I've got SE el84 & 6V6 amps that are about as loud so I don't think I'm getting the most out of the larger el34/kt77 especially when I have to bias the Pdiss lower too (w/ my current PT I'm using). I'd like to use this amp in small venues and for it to be able to hold it's own with everyone else.
rzenc - awesome chart info
jjasilli - you got it for what I'm trying to understand. Even though I understand the charts, load line, I'm trying to better understand these as they (and the program) relates to output signal voltage to hit either the next stage or power tube with.
This is the one thing that I always fine tune for after the amp is finished since I'm not good at designing this ahead of time. It's time consuming when I have multiple stages to try to dial in the right amount of signal w/ voltage dividers and doing this by ear. Ultimately I want to know my output signal swing or drive voltage better as it relates to what the next stage's input maximum it can accept and then know what split-load resistors to use for this rather than voltage dividers. I want to minimize reistances in my signal path as much as possilbe but this subject, even though related, is getting off point a bit to my current question of hitting the power tube w/ enough signal voltage to drive it completely/properly. I haven't thrown in a 12bz yet on this to see what difference it would make, but I'll give one a try and what it does.
As always everyone, thanks for your time, your patience, and your help!
Offline panhead
  • Play it like your hair's on fire
« Reply #7 on: August 19, 2011, 11:49:49 am »
I've built several SE EL34 amps and a KT66 version, and I find I have plenty of drive with two series stages (one 12AX7) with a 5F2 style tone cut control between them. I've sometimes added cathode resistor bypass cap switches as gain reduction switches to clean things up a bit.
Panhead
Offline VMS
« Reply #8 on: August 19, 2011, 01:10:28 pm »
I've been wondering the same thing, but i haven't figured out yet how much the tone stack loads down the gain of the first stage and how much it attenuates the signal.
Rest of the things are explained in this 5E1 example at the amp books site:
http://ampbooks.com/home/classic-circuits/fender-champ-5e1-preamp/
http://ampbooks.com/home/classic-circuits/fender-champ-5e1-power-amp/
http://ampbooks.com/home/classic-circuits/fender-champ-5e1-negative-feedback/
http://ampbooks.com/home/classic-circuits/fender-champ-5e1-power-supply/
« Reply #9 on: August 19, 2011, 08:37:19 pm »
Okay, then. Counting on fingers...
It seems to me that a good rough guess for the load imposed by the tone circuit is to look at the slope resistor; it's 100k in this case. If the wiper of the mid pot is at the "top" in the schematic, then the 100k resistor is grounded by virtue of the 0.022uF cap. So I seeing this as, best-case, a 100k load on the previous 12AX7 stage.
A "real calculation" involves plotting the loadline of the 12AX7 stage given the cathode resistor and supply voltage, then finding the actual internal plate resistance (and mu, cause it's not exactly constant) at the operating point. But we'll simplify by assuming 62k internal plate resistance and a mu of 100.
Taking those numbers, the actual amplification of the gain stage is dependant on the internal resistance of the tube and the parallel combination of the plate load resistor and external load. 100k ll 100k = 50k, and so that's the total load the tube sees.
Amplification = mu * [50k/(50k+62k)] = ~44
So that's all we can expect from the input stage (but we're not done yet).
What is the bias on the output stage? I skipped over seeing that we're probably talking about a SE output stage, but the comments still apply. For 6L6, EL34, KT77, we won't be as high as the -45v or so needed in a higher-voltage class AB amp, but it would be likely to have a bias of as much as -25 to -30v. The grid reference resistor will likely be ~220k (though in some cases you could use 470k). We'll figure on the lower value.
Again, assuming 62k internal resistance, a mu of 100 for the second gain stage, and 100k ll 220k = ~67k, we get:
A = 100 * [67k / (62k + 67k)] = ~52
To comfortably drive our estimated output stage (we should verify what the true bias and supply voltage will be), we need 30v peak / 52 = 0.58vpk.
We could now divide by the estimated 1st stage gain, but we're forgetting something... you need a volume control. You want to be able to use the volume to compensate for various pickup types and outputs, and you want it to distort before the volume is full-up. By the time you turn up a 10% audio taper pot to "7" it is only at 20% of it's total resistance. That means the signal out is 1/5th the signal in.
So, 0.58vpk * 5 = 2.9vpk
We have not assumed yet the loss presented by the tone stack, we simply figured how hard it would slug the gain of the first stage. As quick guess based on the Duncan Tone Stack Calculator, with pots set midway (and ignoring the need to figure dB based on specific input and output impedances), the tone stack will likely result in about 16dB of loss. That means 1v in gives 0.025v out, which is 1/40th the input signal.
2.9vpk*40 = 116vpk
Let's back-up for a sec. We've been working in peak voltages, and there is a good reason for that, if we figure the true capability of each stage based not only on gain but also on loadline and supply voltage. Let's convert to RMS for the sake of looking at needed input signal. 116vpk = 82vRMS.
So we need 82vRMS from our input stage, but the gain is ~44. 82v/44 = 1.86vRMS input
Somehow, your guitar needs to make more than 1.8vRMS, while still allowing for the voltage loss in the input resistor network on the input jacks. That is, if we want to comfortably drive an output tube biased with -30v, while distorting the output tube with a volume control between the tonestack and the 2nd gain stage, which is set to 7. It also assumes an average loss for the tonestack, which still may not be total worst-case.
There is no 1 answer to this stuff. You calculate, and reality-check to the degree you're willing, find the problem areas (stage gain, topology issues, needed supply voltage, etc) then go back and start the whole process over until you get what appears on paper as a workable answer. Then you build and carefully test, and find out that your calculations didn't catch everything.
The idea is to make as many maistakes as possible on paper, and figure out the answers before you spend money.
You will also find out there are standard parts available at reasonable cost, and therefore everything tends toward an average answer that's repeated in a lot of amps.
« Reply #10 on: August 20, 2011, 01:08:01 am »
Class A SE power amps at "reasonable" B+, Vg2, and Pdiss, the peak-to-peak G1 drive voltage is Vg2/Mu, where Mu is the Mu of the power tube in triode connection. EL84 is near 20, 6L7 6V6 EL34 6550 etc Mu=10.
So pick a Vg2, find Mu, compute Vg1 p-p, convert to RMS (divide by 3 {or 2.828 for academic work}).
You "usualy" want 20mV at input jack to make full power. 50mV for old mellow stuff, 5mV for over-over-drive work.
Gain of a classic 12AX7 stage is close-enuff to 50 for any reasonable loading.
Loss of a Fender B-(M)-T tonestack may as well be estimated as "1/10" or "0.1".
Simple amp, 300V main B+, 6V6
300V/10= 30V p-p, 10V RMS.
Driver: 50 -- needs 10/50= 0.2V input
Tonestack: 0.1 -- needs 0.2V/0.1- 2V input
Preamp: 50 --- needs 2V/50= 0.04V or 40mV input
20mV target input --- amp will be pleasant but hard to over-drive
EL84 will hit 20mV sensitivity (no wonder all the cheapest amps are EL84).
For simplicity/economy, try a less-lossy (no-"boost") tone control scheme.
For full BMT tone plus headbanger gain, add a stage. Now you have too MUCH gain. Also a possibility for overload before the final stage. Resistor dividers between stages are popular.
Offline VMS
« Reply #11 on: August 20, 2011, 03:54:12 am »
Thanks HBP & PRR!
Just the info I was looking for. I Have to save this to my scrapbook for future ponderings.
« Reply #12 on: August 20, 2011, 02:28:30 pm »
Isn't the higher the mV voltage the stronger the signal? So 50mV would be the "largest" or "most" signal strength? Sorry I'm confused - it seems 5mV signal would be the least overdriving therefore good for mellow stuff?!
« Reply #13 on: August 20, 2011, 02:43:33 pm »
Interesting, I tried to upload a small 50kB .gif schematic file and it woulnd't allow it saying, "The upload folder is full. Please try a smaller file and/or contact an administrator."
« Reply #14 on: August 20, 2011, 10:58:41 pm »
I mean the amplifier, not the performance.
A 1939 Hawaian/swing amp will have 50mV sensitivity. Overdrive was considered rude. You can not accidentally overload these amps. (But you can: listen to some Texas Playboys.)
A 1990 mega-grinder amp has sensitivity of 5mV or less. Gentle strums can come out way past maximum clean output, so (if dimed!) you are CONSTANTLY distorting the power stage, even if you let notes decay some.
20mV is typical of late 1950s-1960s Fenders and Anpegs. That's the "real" amps; Champ usually needs more. Some Twin Reverbs have a shade more gain due to an extra stage added to compensate reverb mixer loss. But in that ballpark.
I just uploaded a couple files and did not hit the error. For future reference, "Administrator" is "EL34"; send a PM and he'll look into it.
« Last Edit: August 20, 2011, 11:44:59 pm by PRR »
« Reply #15 on: August 21, 2011, 01:30:07 am »
I understand what you mean now. I'm still a little fuzzy on prior info but I'll let it sink in more and re-read Kuehnel, Aiken, or Blencowe related chapters again.
Got 'er dunn!!! If I'd waited any longer I'd never have got it changed out.
Can't play it LOUD at the moment as it's late here but everything tests where I want & passing signal, preamp voltages adjusted to where they were but I now have over 100 volts more on the plate & screen from before! I took a bunch of voltage measurements before putting it back in the cab.
el34: a=378v, g2=368v, k=21.5v, Pdiss=29.3w
6l6gc str: a=379v, g2=372v, k=22.7v, Pdiss=30.4w
kt77: a=380v, g2=373v, k=22.9v, Pdiss=30.9w
I know I'm running a little hot except for the 6l6 but no red-plating on any of the tubes.
« Last Edit: August 21, 2011, 01:43:39 am by jojokeo »
« Reply #16 on: August 22, 2011, 11:22:38 am »
Here is an example of a Garnet  SE "champ style" amp using a 12AX7 and a 6L6
http://www.el34world.com/charts/Schematics/files/garnet/garnet_g15tr_gnome.pdf
Even has vibrato and reverb.
« Reply #17 on: August 22, 2011, 10:48:33 pm »
Thanks for the schem tubenit. Shows only two stages also besides the tremolo & reverb. What poor filtering they used on their amp. Only three filter caps total for the whole thing! The B node has 6l6 screen and four stages of reverb & tremolo duty plus no pi filter prior to the "A" node.
