September 18, 2026, 10:52:09 am
Hoffman Amps Forum image Author Topic: Doubled triode?  (Read 7758 times)
Offline 67polara
  • Here is my Guild 67 polara
Doubled triode?
« on: September 04, 2011, 03:33:16 pm »
In a doubled triode preamp circuit how can you turn one 1/2 off and on without a pop or to much change of tone?  Can I just put a switch in between pins 2 and 7 or do I need to do something else also?
« Last Edit: September 04, 2011, 03:35:48 pm by 67polara »
Re: Doubled triode?
« Reply #1 on: September 04, 2011, 08:04:15 pm »
You can put a switch between pins 2 and 7, to turn off the signal to one grid. Place a large-value resistor across the switch, such as a 10M.
Offline 67polara
Re: Doubled triode?
« Reply #2 on: September 04, 2011, 08:46:06 pm »
Thank you that is what I thought I had to do.
Tony
Re: Doubled triode?
« Reply #3 on: September 04, 2011, 09:08:52 pm »
Make sure you have a 1meg from each grid to ground.
Re: Doubled triode?
« Reply #4 on: September 05, 2011, 12:21:04 am »
Re: Doubled triode?
« Reply #5 on: September 05, 2011, 06:33:04 am »
Another option to consider is Geezer's "Fatness" Control.  You can use a mini-pot if you want as I did.
with respect, Tubenit
Re: Doubled triode?
« Reply #6 on: September 05, 2011, 06:42:23 am »
Hi Tubenit
please can you share your experience with the use of that pot, I'd like to know if the use is quiet or using the pot a bit of scratch noise is to be expected
Many Thanks
Kagliostro
Re: Doubled triode?
« Reply #7 on: September 05, 2011, 06:48:22 am »
It worked fine for me with no issues. And the description "fatness" is applicable. The advantage of it, from my perspective, over a switch is that I found a "sweet spot" that was less than "10".
IIRC, Geezer made a similar comment about using the fatness control and finding a sweet spot.
Offline 67polara
Re: Doubled triode?
« Reply #8 on: September 05, 2011, 10:30:35 am »
I love the fatness control on my TOS except I only use it in two positions.  Off and at 9 or so.  I was thinking since it sounds like a mild form of OD only "FAT" I would try two gain stages in a row doubled with a foot switch to cut them off just for fun. I would leave the controls as trimmers so I can tweak it a bit.
Tony
Re: Doubled triode?
« Reply #9 on: September 05, 2011, 01:38:18 pm »
Thanks for the answer
Kagliostro
Offline Fresh_Start
  • noob de Lux
Re: Doubled triode?
« Reply #10 on: September 05, 2011, 02:39:48 pm »
A question about the "Fatness control" circuit:  Is the 250K pot in parallel with the 1 Meg "Volume" pot in terms of serving as a grid return resistor?  Doesn't that reduce the gain of the primary triode versus not having the 2nd triode and 250K pot?
I don't doubt that the circuit works nicely - just want to understand how the circuit works as a whole.  Reducing the combined gain probably is a net benefit anyway.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Re: Doubled triode?
« Reply #11 on: September 05, 2011, 03:12:08 pm »
The 1st stage's plate resistor, the 1M vol, and the tone control, and the 250k fatness control, are all in parallel as far as the AC load on the 1st stage is concerned.
