September 15, 2026, 01:23:27 pm
Hoffman Amps Forum image Author Topic: which tool ?  (Read 11436 times)
Offline worth
which tool ?
« on: September 05, 2011, 07:36:08 am »
What do you guys use to tighten that round knurled ring on Carling toggle switches ?
Offline Cathode_ray
Re: which tool ?
« Reply #1 on: September 05, 2011, 07:40:40 am »
Masking tape on the jaws of pliers - and caution!
Offline worth
Re: which tool ?
« Reply #2 on: September 05, 2011, 07:42:53 am »
There must be a specialized tool for that ring ?
Re: which tool ?
« Reply #3 on: September 05, 2011, 08:06:09 am »
I usually put them on the backside and use the hexagon nut on the faceplate, to me no biggie. But, you can use a couple of different tools w/ caution. Also, Stew-Mac has a few items you might find that work? http://www.stewmac.com/shop/Tools/Wrenches/ESP_Multi_Spanner.html
http://www.stewmac.com/shop/Tools/Special_tools_for_Electronics,_pickups/Adjustable_Toggle_Switch_Wrench.html?actn=100101&xst=3&xsr=6929
Re: which tool ?
« Reply #4 on: September 05, 2011, 08:08:52 am »
What I did, was to tighten the hex nut from the back with a wrench. The knurled ring won't turn on you, and you can get the switch nice and snug that way.
Offline worth
Re: which tool ?
« Reply #5 on: September 05, 2011, 08:14:43 am »
Yeah.. I have been putting the ring in the back too , but I think it would look nicer in the front.
Offline worth
Re: which tool ?
« Reply #6 on: September 05, 2011, 08:18:17 am »
That StewMac adjustable switch wrench looks perfect.. thanks.
Re: which tool ?
« Reply #7 on: September 05, 2011, 08:44:06 am »
Agreed! I've never seen that tool before, but I'm gonna get one. Thanks jojokeo.
Offline TubeGeek
    • Glacier Amps
Re: which tool ?
« Reply #8 on: September 05, 2011, 01:30:37 pm »
Sweet! I have to get one too. :worthy1:
Re: which tool ?
« Reply #9 on: September 05, 2011, 02:00:43 pm »
actually ever seen and certainly to have
Kagliostro
Offline FYL
Re: which tool ?
« Reply #10 on: September 05, 2011, 02:17:09 pm »
A hammer. And for 15A models a sledgehammer.
 :angel
Re: which tool ?
« Reply #11 on: September 05, 2011, 03:47:35 pm »
pliers w/ sides of jaws taped. sometimes w/ a bit a blue locktite.
Re: which tool ?
« Reply #12 on: September 05, 2011, 04:39:58 pm »
I have "compromised" and put the ring nut over a hex nut.
Re: which tool ?
« Reply #13 on: September 07, 2011, 04:53:39 pm »
The tool that Stew-Mac sells is the exact tool that I used to install toggle switches when I worked in the Gibson factory. If you're in a situation where a lip on the amp chassis prevents you from grabbing the inside hex nut with standard pliers, that tool is the only sure way not to booger up the fancy nut.
Re: which tool ?
« Reply #14 on: September 08, 2011, 09:23:57 am »
In a previous life I took a Taiwanese open-end wrench and ground it down so that the two "prongs" that grab the nut are only about 3/32" thick. You have to be fairly careful not to chamfer (eg; round) the opening...that has to kept as sharp as possible...and you have to not allow the wrench to heat up too much during the grinding process or you'll anneal it and it will get a lot softer. If there's a special tool for this that gets around the lip found on many amp chassis and you need this tool more than once or twice, I'd pop for it. (Haven't seen the Stew-Mac tool)
Offline ThermionicEngine
  • ooops- Should have cut the blue wire first
Re: which tool ?
« Reply #15 on: September 10, 2011, 11:08:59 pm »
I use both iterations of the StewMac tool.  I like the newer one with the adjustable collar best.  The older tool does wear out (nylon or plastic molded tool).
V= IR; Everything else is derivative...
