September 20, 2026, 02:23:39 am
Hoffman Amps Forum image Author Topic: wiring paralleled triodes  (Read 4629 times)
Offline Matty_V
  • I'll take a beer
« on: September 14, 2011, 10:20:17 pm »
How do you run the wiring for a parallel triode? You've got 3 wires crossing paths, whats the best way to route them? I've got a beastly parasite to tame and might as well start here (the start!)
Danke
Re: wiring paralleled triodes
« Reply #1 on: September 14, 2011, 11:12:21 pm »
Three short wires connecting the pins directly placed on the socket itself.
Pin 3 to pin 8, pin 2 to pin 7, pin 1 to pin 6.
This is the same manner in which the paralleled triodes of a reverb driver are wired.
Offline stingray_65
« Reply #2 on: September 14, 2011, 11:14:12 pm »
Hey Matty,
Beastly!?
is it a Push Pull power section?
may need to swap the plate lead on the OT.
Have you chopsticked the leads in your suspect area and have noticed a difference better or worse?
I've paralleled a few triodes, even had one that switched in and out in a high gain, but haven't had oscillations (that I know of).
Ray
Offline Matty_V
  • I'll take a beer
« Reply #3 on: September 15, 2011, 01:00:53 am »
Oh ok, I took a look at dougs picture of the reverb stout to check out how its done. I guess I was making too big of deal of keeping the grid wire up above the plate and cathode. The way I had it was making the grid wire into an antenna for noise.
It starts its vampire hissing around 1/2 up on the volume. Not sure why I haven't tried switching the plate leads yet. Maybe cause last time I had them swapped it wailed mercilessly right as it was turned on. How come one configuration causes such awful oscillations?
« Reply #4 on: September 15, 2011, 01:28:38 am »
Hi Matty V, This is how i did it, kept the heater wire low with the plate wire over, then arched the cathode last.i used two grid resistors and each has its own 1M to ground. Thanks
