September 16, 2026, 02:28:45 pm
Hoffman Amps Forum image Author Topic: How to troubleshoot ground hum?  (Read 12168 times)
Offline JustMike
« on: September 19, 2011, 09:11:20 am »
 I've got a home built Ceriatone JCM-800 2204. I used the Hoffman grounding scheme but it still hums. I put an effects loop in it (between treble & MV) and when I insert an external pre into the return, there is no hum. But I can't figure out if it's because of multiple ground paths or something else. Any suggestions?
I'm learning...
Offline firemedic
Re: How to troubleshoot ground hum?
« Reply #1 on: September 19, 2011, 09:58:38 am »
You sure it's not your heater wires?
Offline stingray_65
« Reply #2 on: September 19, 2011, 10:48:29 am »
One trick I learned is that I had to identify between 60 and 120hz.
120Hz hum is post rectified HT. 60Hz is heaters or an errant signal.
If you take another amp, plug in a guitar cable and touch the tip of the cable, thats 60Hz.
JCM 800 is a high gain amp, Lead dress COULD be at fault, chopstick your leads, especially near the tube sockets and your FX loop mod. Making it worse is almost as good of a sign as making it better,gives you a place to start.
Did you phase the heater wires? with the tubes pulled you can check continuity and make sure one wire supplies pins 4-5 and the other pin 9. It is my understanding that this provides a sort of humbucking effect for heater hum.
Parallel wires?
OH! does the hum increase with the volume control? what controls affect it?
And double check the ground scheme. Doug's method has proven itself time and again.
How is Doug's grounding scheme different than what Cieratone suggested? PRR has suggested many times to build a proven design. I've never read a bad review of Cieratone, so why would we want to change their grounding scheme?
Just a few thoughts, Good Luck! and as Tubenit has advised me, "Go SLOW, be patient, DON'T GET DISCOURAGED!"
Ray
Offline Leevi
    • Rikstone
« Reply #3 on: September 19, 2011, 11:52:56 am »
This is a valid question. If not, you can try the following (do one change at a time):
- Insert temporarily another filter cap parallel to the first filter cap
  and compare the hum
- Insert a new filtering stage (cap + resistor) before the first filter cap
- If there is no choke used replace the resistor with a choke
- change the grounding of the PI sector to somewhere else
- change the grounding of the power amp to somewhere else
/Leevi
Offline JustMike
« Reply #4 on: September 19, 2011, 12:14:30 pm »
 Thanks guys. Lots of good points to check out. I'll keep you updated.
I'm learning...
« Reply #5 on: September 19, 2011, 12:35:26 pm »
Hey JustMike,
Read up on it in Dougs library.              :library:
Try this also, look in tech info,
http://www.aikenamps.com/Home.htm
One more, Merlins site,
http://www.freewebs.com/valvewizard2/grounding.html
You'll find it.       :grin:
                   Brad       :icon_biggrin:
Offline archaos
« Reply #6 on: September 19, 2011, 02:46:37 pm »
Hey JustMike,
                   Brad       :icon_biggrin:
+ 1
Merlin's grounding scheme is one of the best ever anyway : success every time !
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline JustMike
« Reply #7 on: September 27, 2011, 02:33:49 pm »
 Thanks for all of the reading...But it turned out to be a bad preamp tube! WTF?!?
I'm learning...
« Reply #8 on: September 27, 2011, 03:24:15 pm »
 :laugh: But think of all you've learned!
« Reply #9 on: September 27, 2011, 07:17:19 pm »
Tube swap is the 1st thing to check when you get hum.
Offline stingray_65
« Reply #10 on: September 28, 2011, 01:24:13 am »
I will ASSume that it was in position V1?
Does the tube hum in other positions? V2? PI?
« Reply #11 on: September 28, 2011, 10:23:34 am »
Ditto. [Rule 1:  Always suspect tubes first; Rule 1.a. This inlcudes new tubes.   :icon_biggrin: ]
