September 15, 2026, 08:56:54 pm
Hoffman Amps Forum image Author Topic: paralleled SE output tubes  (Read 5553 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: September 29, 2011, 10:07:06 pm »
Hi,
I'd like to add an output tube to my new SE build. Can I just run wires straight from the first tube to the other ?
Colas
P.S.: call me Alvin.
Offline RicharD
    • Toxic Water
Re: paralleled SE output tubes
« Reply #1 on: September 29, 2011, 11:16:20 pm »
You can parallel SE output tubes but your Zout goes down by 1/2.  Assuming cathode bias, you either need separate cathode resistors or 1/2 that too.
  • MAKE LOVE NOT WAR
« Reply #2 on: September 30, 2011, 08:23:13 am »
I gotta check the filament supply current to see if it can feed another power tube though.
What about the grid stopper and coupling caps? Is it better to use 2 coup^ling caps or just one ?
Thanx
Colas
Offline RicharD
    • Toxic Water
« Reply #3 on: September 30, 2011, 08:13:22 pm »
Individual grid stoppers so you form a summing network is how I've done it in the past.
  • MAKE LOVE NOT WAR
« Reply #4 on: September 30, 2011, 09:52:22 pm »
thanx
regards
« Reply #5 on: October 01, 2011, 10:17:42 am »
Depending on what you're already using, the grid reference resistor ( from grid to ground) may need to be lowered. This is more an issue in fixed-bias amps than cathode bias. In such a case, you might halve the resistor and double the coupling cap value.
« Reply #6 on: October 01, 2011, 03:57:26 pm »
FWIW here is the schematic of a parallel SE I did at the beginning of the year. I used a switchable 470R in parallel to change the bias. The amp can also run 1 x 6L6 etc
