August 29, 2026, 09:40:50 am
Hoffman Amps Forum image Author Topic: 12AX7 Balanced XLR Out  (Read 8636 times)
Offline blown240
« on: October 31, 2011, 07:20:41 pm »
I am going to have 1/2 of a 12AX7 to play with in a preamp build I am planning.  I found this schematic for a balanced XLR out and was wondering if there was a way to use the 1/2 12AX7 instead of the TL072.
Re: 12AX7 Balanced XLR Out
« Reply #1 on: October 31, 2011, 07:45:50 pm »
If you really want an XLR output driven by a tube, you will very likely need a transformer between the tube and jack. Most tubes have simply a too-high output impedance for driving long lines.
Offline stingray_65
« Reply #2 on: November 01, 2011, 01:39:08 am »
Weber sells a nifty little transformer that's great for XLR.
https://taweber.powweb.com/store/balun.jpg
I try to put one on every amp I build that's less than 30 W
$2 a pop! I usually order 5 at a time. https://taweber.powweb.com/store/magnetic.htm all the way to the bottom.
I try to use these neutrik 1/4" XLR panel sockets.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=092-045
get the switched kind and you can run a bal/unbal out.
Offline blown240
« Reply #3 on: November 01, 2011, 10:09:08 am »
That little webber tranny is cool.  Its ALOT smaller than I thought it would be.  And for $2, you cant go wrong!
Offline stingray_65
« Reply #4 on: November 01, 2011, 10:36:33 am »
Just to be clear!
These Webers are low impedance, 150 -150
Offline terminalgs
« Reply #5 on: November 01, 2011, 10:42:41 am »
you want to look to vintage studio gear of preamps and limiters/compressors for examples of tube driven balanced output circuits.  a lot of them are push-pull in the final stage of output,   but a few are "single ended",   here are some schematic excerpts of the tube & OT:
EMI's redd 47,  a little different than what you'd do with a single 12ax7 section,  but similar.  driven by a gain stage :
Telefunken 72A,  driven by a CF stage:
Universal Audio LA2A,  a complex CF driver   where the cathode load resistor is replaced with another triode section (not for you if you only have a single 12ax7 section,  but interesting nonetheless):
the above LA2A idea that is a little easier to read (taken from Bill Whitlock's Audio Transformers Chapter... from "Handbook for Audio Engineers" ):
Offline blown240
« Reply #6 on: November 01, 2011, 01:31:03 pm »
Those are cool. Thanks for posting them!
