September 15, 2026, 12:20:04 am
Hoffman Amps Forum image Author Topic: Capacity of the second and following caps in Tube rectified PS ???  (Read 6932 times)
We know that if a Tube Rectifier is used the first capacitor capacity must respect the needs of the Tube Rectifier
so we look to the Tube Rectifier data sheet and know what to use
but what about the second capacitor in the PS chain ?
assuming to use, as an example, a GZ34, the max first capacitor must be 60uF
if we use the max usable value (60uF) than an inductor or a resistor, the following capacitors must be within a stated value or can have the values we like more to use ?
Kagliostro
Re: Capacity of the second and following caps in Tube rectified PS ???
« Reply #1 on: November 29, 2011, 04:38:41 pm »
Without looking to be sure, I believe the second filter cap can be whatever you want.
For instance, on mine I used a 22 coming off the 5y3, then my second one is a 47.
« Reply #2 on: November 29, 2011, 06:21:12 pm »
The capacitance is not limited. The Peak Current must be limited.
You can put 10,000uFd on a 5V3 if you have 2,000 ohms resistance between (may be PT winding resistance).
You can be in trouble with 10uFd and some rediculously low series resistance at higher voltage.
The "second" cap is isolated with more impedance (resistor or choke). As long as there is enough impedance to make a 2nd cap useful, the peak current will not be large.
Offline chocopower
« Reply #3 on: November 29, 2011, 06:39:40 pm »
Now you talk about this, time ago i bought and old Selmer amp with a GZ34 and a 100uf cap as first one, BUT with a 50 ohm-5w resistor between them.
Everyone said to me that the tube rectifier was in problems with that capacitance, but it worked like that for DECADES (1966), so i always suposse that the 50 ohm resistor keep the GZ34 alive.
Is my presuntion ok?
David
« Reply #4 on: November 29, 2011, 07:06:21 pm »
More good info, thanks! I had only read about "the rush of current" to charge the first cap.
« Reply #5 on: December 02, 2011, 08:53:10 pm »
Funny enough, only the european GZ34 data sheet ever states a "maximum capacitor value." The american 5AR4 data sheet does not. Neither does the 5U4GB data sheet.
Notice that the Philips data sheet keeps the same maximum cap value, but shows the supply voltage raising, as long as you keep increasing the series supply resistance to limit the peak current.
« Reply #6 on: December 02, 2011, 11:56:35 pm »
Along with a "minimum winding resistance".
They are detailing how (one reasonable way) to get the claimed output voltage and current without violating the 750mA peak current rating.
« Reply #7 on: December 03, 2011, 02:57:42 am »
MANY THANKS for explanation & detailed infos
Kagliostro
