September 15, 2026, 07:32:39 am
Hoffman Amps Forum image Author Topic: rectifier tube, Resistors on which side ?  (Read 5773 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: December 09, 2011, 08:11:25 am »
Hi,
is it best to put resistors on the AC or DC side of a rectifier ?
Colas
P.S.: call me Alvin.
Re: rectifier tube, Resistors on which side ?
« Reply #1 on: December 09, 2011, 08:52:22 am »
either way will work, but neither is absolutely necessary
Merlin recommends them on the plate side (as a belts and braces approach) to enhance the longevity of a tube rectifier (at the expense of a bit of B+ voltage) http://www.freewebs.com/valvewizard/fullwave.html
Others use them in the B+ rail to create sag
  • MAKE LOVE NOT WAR
« Reply #2 on: December 09, 2011, 02:41:27 pm »
Do the diodes toward the recto tube remove the ''tone'' of the tube, the voltage being already rectified ?
Colas
« Reply #3 on: December 09, 2011, 06:02:48 pm »
No.
If the solid-state diodes are nearly zero resistance when that particular tube rectifier plate is conducting, then the apparent resistance of the tube (which causes the voltage sag you want) dominates the situation.
The solid-state diodes only come into play if the tube rectifier is short-circuited. If the sand diodes weren't there, filter caps will pop due to high negative voltage being applied to them (which the tube rectifier would have blocked). The solid-state diodes keep the amp working. *If* you can hear a difference between the tube and solid-state diodes, then you know to go back and check the health of your rectifier.
« Reply #4 on: December 10, 2011, 03:30:39 pm »
The forward voltage drop of a 1N4007 is about 0.6V, which makes diddly squat difference to the power output when combined with a tube rectifier. I use SS diodes for protection against tube rectifier shorting on all my tube-rectified amps. Makes no difference in sound or power output and is only a few cents worth of extra insurance.
« Reply #5 on: December 10, 2011, 03:57:41 pm »
What Tubeswell said.  :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #6 on: December 10, 2011, 07:09:45 pm »
thanks for the explanations !
