September 17, 2026, 09:23:19 am
Hoffman Amps Forum image Author Topic: Ampeg B-25b Standby POP - Can't seem to fix.  (Read 4705 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: December 17, 2011, 09:20:04 am »
Got this B-25b on the bench. Changed the standby switch thinking that was the problem but still pops.
The standby lifts the center tap of the HV winding.
Any thoughts on a fix?
Schematic:
http://www.el34world.com/charts/Schematics/files/ampeg/Ampeg_B25B.pdf
Thanks!
Call me Dan
www.fydamps.com
Re: Ampeg B-25b Standby POP - Can't seem to fix.
« Reply #1 on: December 17, 2011, 09:31:18 am »
Due to the huge d.c. shift that results from essentially "turning off" the PT high voltage secondary, I have a hard time thinking of a case where this would not cause a pop.
Perhaps a small-valued high voltage cap would help; I'm thinking something in the 0.01uF range.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: December 17, 2011, 09:48:01 am »
That standby switch looks like bad news to me. The bias supply is going to spike way negative when the switch opens. I would re-wire the switch to the B+.
Offline ernie_jr
  • gimme a banana
« Reply #3 on: December 17, 2011, 04:47:55 pm »
I built a b25 WITH 6550'S  Put the standby on the B+ like fender and sunn.  No issues with pops
Ernie
