September 16, 2026, 07:28:19 pm
Hoffman Amps Forum image Author Topic: Have you ever used or seen a shield in the board like this ?  (Read 9762 times)
« on: January 18, 2012, 03:58:41 pm »
Does someone has used, in Audio Frequency, a shield like that in the attached image ?
can this be of some practical use ?
the designer may be is Larry (Larry Amps) but I'm not sure
Kagliostro
« Last Edit: January 18, 2012, 04:09:07 pm by kagliostro »
Re: Have you ever used or seen a shield in the board like this ?
« Reply #1 on: January 18, 2012, 04:10:35 pm »
I've not seen a shield on a board like that. However, I have seen and made a shield to do something similar before on a point to point wiring inside several Bogen amps.
Offline tdvt
« Reply #2 on: January 18, 2012, 04:34:21 pm »
I just had my Pro Jr apart & there is a metal shield between the pots & the filter caps, grounded as I recall.
Not a great photo (not mine), but you can see it above the black filter caps, running from left of the input jack to the left end of the board
Offline thermion
  • Repeat Of Fender
« Reply #3 on: January 18, 2012, 04:52:11 pm »
I've seen this kind of shield around the power transformer in an old masco-fanon PA head.
what are the little silver boxes on the board?
« Reply #4 on: January 18, 2012, 05:36:38 pm »
There relays. But if one burns up you would have to pull the whole eyelet board to replace it because he chose not to use a socket for it. :w2:        :BangHead:    :cussing:
           Brad      :laugh:
Edit; I should have added his work does look great.
« Last Edit: January 18, 2012, 06:42:17 pm by Willabe »
Offline Tom_Hull
« Reply #5 on: January 18, 2012, 06:21:53 pm »
hi ..
i seen them on the isolated  reciever section in old tube stereos that i had ..off the chassis boxed around
and sheilds  on tube sockets connections .....in the reciever section ,, sorry no pictures .
on my daughters amp i have something built  for the preamp tubes isolating it from the pt ..but i took it off made the  quick cap holder ..for the alamo,,temperary
tom
Offline LooseChange
    • Fix Your Darn Amps
« Reply #6 on: January 19, 2012, 06:47:41 am »
That's a sun shield.. The amp is so cool it needs sunglasses. :-)
Call me Dan
www.fydamps.com
« Reply #7 on: January 19, 2012, 07:32:58 am »
 :icon_biggrin:
Kagliostro
Offline stingray_65
« Reply #8 on: January 19, 2012, 09:01:09 am »
Shielding like that in my opinion is used to correct a problem that could have been avoided with proper lead dress.
it is a patch at best.
Just my opinion, not saying its poor construction or that anyone who has used it built something sub standard, we all do what we have to to get by and make it work.
« Last Edit: January 19, 2012, 09:05:46 am by stingray_65 »
« Reply #9 on: January 19, 2012, 09:53:07 am »
may be he has reconsidered the relays placement in other amps
yes, may be, or bay be is a sophisticated refinement for a boutique amp that wink to HiFi builds
about shields around pots and transformers I've seen before may be not on the board
Kagliostro
« Reply #10 on: January 19, 2012, 10:00:34 am »
Yeah, maybe K.
He does do very nice work.
        Brad      :icon_biggrin:
Offline birt
« Reply #11 on: January 19, 2012, 12:21:21 pm »
i have used a shield like that around an input that was really close to the mains/PT. it was a conversion build and this was the only possible place for that input. it works.
« Reply #12 on: January 20, 2012, 09:18:23 pm »
That's tone-stack caps, right? My Champ's oscillations changed when I just waved a pencil in that area. I just pushed the wires around to get distance; but a shield would work.
