September 17, 2026, 08:24:37 pm
Hoffman Amps Forum image Author Topic: OT question  (Read 8172 times)
Offline 12AX7
OT question
« on: January 21, 2012, 05:37:32 pm »
It's said 100 watters have a punchier more solid tone, and the 100 watt marshalls i've had did indeed sound different in a way i liked. Those adjectives may not be the best words to describe it, but you know what i mean. Anyways, the question is, if you use a 100 watt OT in a 50 watt EL34 amp, will you get the same effect as it it were 4 tubes? Also, besides using the speaker tap thats 1/2 the value  as your speaker load, is there anything i should know about trying this?
Offline panhead
  • Play it like your hair's on fire
Re: OT question
« Reply #1 on: January 22, 2012, 08:26:17 am »
I would think that unless the 100W transformer is run near saturation with the 4 EL34's, it shouldn't sound much different running at 50W with 2 EL34's. You are correct about only needing to change to OT tap.
Panhead
Offline LooseChange
    • Fix Your Darn Amps
Re: OT question
« Reply #2 on: January 22, 2012, 09:34:32 am »
Let's go another way.... Four power tubes sound rounder than two.
Call me Dan
www.fydamps.com
Offline 12AX7
Re: OT question
« Reply #3 on: January 22, 2012, 10:54:01 am »
Ok, then is there any difference worth noting having a 100 w OT over the 50?
Offline bluesbear
Re: OT question
« Reply #4 on: January 22, 2012, 12:22:55 pm »
I'm not an expert on Marshalls but here's what Ken Bran said. They built the first 50 watt prototype with a 100 watt OT because they had it on hand. After some trial and error, they made all the early 50 watters with 100 watt OT's because they thought it was fuller sounding with better low-end harmonics. He and Dudley Craven designed the thing so he ought to know.
That's all I know.
Dave
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
Re: OT question
« Reply #5 on: January 22, 2012, 01:37:31 pm »
Odd, I always preferred the sound of the 50w models.... :dontknow:
Open Minded But Fixed Bias
Re: OT question
« Reply #6 on: January 22, 2012, 04:43:24 pm »
Hi-fi amps use full band width OT's, most guitar amps don't. If you put a 100w OT in a 50w amp you'll get full band width frequency response from it or close to it.
You might like the sound better , but you might not. Hammonds standard line of OTs are rated at full band width.
                             Brad      :icon_biggrin:
