August 29, 2026, 02:49:10 pm
Hoffman Amps Forum image Author Topic: OT for AB763  (Read 5487 times)
Offline duke of earl
  • Bird is the Word
OT for AB763
« on: February 01, 2012, 08:28:44 pm »
a few years ago I built my first amp-A Hoffman AB763 circuit for 2x6L6 tubes. I used a 100 watt PT and a 100 Watt OT for more headroom. I also used a GZ-34 Port Arthur Rectifier (Gerald Weber Mod) to get a little compression on the front of the note which works very nicely. I am toying with the idea of going with a 50 watt OT as I want the amp to breakup moderately but still maintain descent clean headroom. I have actually put some EH 6v6"s in the amp and put a 15k feedback resistor in and I'm not really digging the overdriven tone with this setup. The speakers are 1 Weber Legacy 12"and 1 Weber California Alnico 12". The speakers are not broke in yet and I wonder should I wait for the speakers to settle in before making any changes to the topology? Your thoughts are much appreciated.
  • Bird is the Word
Re: OT for AB763
« Reply #1 on: February 02, 2012, 04:32:35 pm »
speakers are 16 ohm each run in parallel. The circuit is a Hoffman Board layout for the most part with some tweaks.
  • Bird is the Word
Re: OT for AB763
« Reply #2 on: February 02, 2012, 07:29:33 pm »
If you look in Doug's circuits, you will see an AB 763 that he tweaked. It is found under the Hoffman Board Building Section in the Library.
Re: OT for AB763
« Reply #3 on: February 03, 2012, 06:36:19 am »
018343
It's a great OT. I sell alot of them and people really like them.
http://www.hoffmanamps.com/MyStore/catalog/parts1.htm
I have one in my Super Vibrolux Reverb with a pair of EH 6V6's but I have also used it with 6L6's
  • Bird is the Word
Re: OT for AB763
« Reply #4 on: February 05, 2012, 08:50:06 pm »
Thanks Doug. How do the 6v6's respond to this model?
Offline Dave
Re: OT for AB763
« Reply #5 on: February 05, 2012, 09:38:04 pm »
You said you were using a 100 watt PT. So, you intend to use a pair of 6V6's with a Twin Reverb PT and a Super Reverb OT?
First, are you looking to find out how quickly you can kill a pair of 6V6's?
Second, you will create a 100 percent mismatch between your OT and your speakers by using 6V6's.
It will work, but it seems pretty, hmm, unorthodox.
Ever see a Volkswagon Beetle with a V12 and a power glide transmission?
Dave
  • Bird is the Word
Re: OT for AB763
« Reply #6 on: February 06, 2012, 08:55:14 pm »
Dave,
I originally used 6l6's and by using the bigger OT, doubled the speaker impedance to match the reflected impedance. Doug says the Electro Harmonix 6v6's can handle the plate volts in a Twin Reverb so I thought I'd give em a try. I'm still a novice to amp building and am trying different things to feel out what works and what doesn't. When I had the 6l6's in the amp, I blew my California speakers so I wanted lower wattage output tubes after the recone job. You could say I am adventuress in my endeavor! Thanks for your advice and to all who are posting here.
Weber speakers
Getting the Eric Johnson Tone
Re: OT for AB763
« Reply #7 on: February 06, 2012, 09:46:42 pm »
Yes tell me, Why does love have to be so sad?
You sound good Duke.
                  Brad    :icon_biggrin:
Re: OT for AB763
« Reply #8 on: February 06, 2012, 11:57:35 pm »
The Weber California? That's suggested to be "like a JBL" and really should eat ALL the output of a couple 6L6. I wonder what went wrong?
  • Bird is the Word
Re: OT for AB763
« Reply #9 on: February 07, 2012, 02:51:30 pm »
I played the amp on "11" with overdrive and humbuckers for a couple of years. Yes they are weber alnicos @ 65 watts a piece.
