August 29, 2026, 11:28:36 am
Hoffman Amps Forum image Author Topic: Wire wound R placebo effect?  (Read 8246 times)
Offline 12AX7
« on: February 03, 2012, 05:06:27 pm »
I tried some wire wounds for my EL34 screens in place of the sand 5 watts that were there. Both 1k. Seems to sound different. Is it my ears or is this typical? I'm seriously asking....i don't know! Just don't see why it would cause any difference.
Re: Wire wound R placebo effect?
« Reply #1 on: February 03, 2012, 05:57:52 pm »
Maybe the wire-wounds have more inductance or capacitance.  See:  http://answers.yahoo.com/question/index?qid=20081109052907AAj9bGw
Offline 12AX7
« Reply #2 on: February 03, 2012, 07:01:18 pm »
Wow, sounds like they well could have some capacitance,  and that would make sense considering they are more or less a coil right? Maybe thats it. I'll swap then out again and see if what i'm hearing is definite and which i like better. Thanks.
« Reply #3 on: February 03, 2012, 07:31:33 pm »
The 5w "sandbox" resistors are wirewound as well.
Offline 12AX7
« Reply #4 on: February 03, 2012, 07:54:59 pm »
That would mean less chance of a difference, tho still a chance because each would create different degrees and values of capacitance i imagine.
« Reply #5 on: February 03, 2012, 08:16:14 pm »
A coil of wire is more likely to result in inductance, since an inductor is a coil of wire. Some stray capacitance is possible, but should be very minute in a resistor.
« Reply #6 on: February 03, 2012, 09:06:57 pm »
I've seen one which was a carbon-film cast inside a ceramic shell.
