August 29, 2026, 11:28:58 am
Hoffman Amps Forum image Author Topic: Proper grounding on vintage amps  (Read 4463 times)
Offline P Batty
  • Flippism Is The Key
« on: February 05, 2012, 10:21:43 am »
I know that everyone here is aware of the need for retro-fitting vintage amps with a proper chassis ground, but here is a brilliant essay which should be read by anyone ( i.e. a repair customer who doesn't want to pay for a new power cord) who isn't:
http://deadspin.com/5881337/feet-in-smoke-a-story-about-electrified-near+death
When I used to work sound I always checked outlets for proper wiring  and also took voltage readings between amplifiers and microphones just to be safe, especially with venues or bands whose equipment I hadn't previously inspected.  There isn't as much vintage equipment being used on stage now but there are still plenty of garage and basement bands using funky gear, still some mis-wired outlets and still a few "collectors" who are misguided. As a repair tech you can't control all external situations, but  you can make sure that every old amp has a proper chassis ground.
Re: Proper grounding on vintage amps
« Reply #1 on: February 05, 2012, 12:12:35 pm »
powerful stuff.
