September 14, 2026, 04:21:27 am
Hoffman Amps Forum image Author Topic: Variac for both AC & DC use?  (Read 6287 times)
Offline GuitarPilot65
  • Music by Lee/Lifeson; Lyrics by Peart
« on: February 15, 2012, 02:21:07 pm »
Is there such an animal out there?
1993 Brown Fender '63 Vibroverb RI (6G16)
1994 Blonde Fender '65 Deluxe Reverb RI (AB763, modified [by me])
Re: Variac for both AC & DC use?
« Reply #1 on: February 15, 2012, 02:28:19 pm »
Why do you need that?
If you have a DC sup. just use the variac to feed the primary of the PT or use a variable DC sup.
                Brad
Offline FYL
« Reply #2 on: February 15, 2012, 02:54:40 pm »
A Variac is an auto-transformer and only works with AC (well, it also attenuates DC because of it's winding resistance but not significantly).
(From Wikipedia)
The DC version is a rheostat, a really big wire-wound potentiometer.
« Reply #3 on: February 15, 2012, 05:06:29 pm »
When I was looking for a variable AC supply, I ran across lots of the DC as well, and they were pretty cheap. But don't recall seeing one that did both.
« Reply #4 on: February 15, 2012, 06:48:14 pm »
Yes, you can have a variable DC power supply, but it's not a variac.  A variac is called a variac because it is used to VARy AC.
