August 29, 2026, 11:28:35 am
Hoffman Amps Forum image Author Topic: understanding chokes  (Read 4330 times)
Offline Tone Junkie
« on: March 07, 2012, 01:49:13 pm »
Ok Im building a 100 watt amp I dont build many of those I would like to use a hammond 159q choke i like the way they sound in a marshall style build but the specs are 7H 150 MA. 500vdc is a 150 MA to low because the power transformer is 290 MA.
Thanks Bill
Re: understanding chokes
« Reply #1 on: March 07, 2012, 02:00:01 pm »
Most typical 100W amps don't run the output tube plate current through the choke so you will be fine unless you're building something unusual.
Offline Tone Junkie
« Reply #2 on: March 08, 2012, 01:32:00 am »
Thanks Steve just standard marshal type power amp.
« Reply #3 on: March 08, 2012, 05:24:59 pm »
I've got a project going right now which has 2 chokes. One handles the whole-amp current, and is rated for 200mA (for 2 6L6-style output tubes, 3 preamp tubes).
The other choke handles only preamp current. It is vastly overrated at 75mA (again, handling 3 small tubes), but much cheaper than a sensibly-rated part custom-made. It might even be vastly overrated for your amp, in the typical Marshall position feeding the screens.
Offline Tone Junkie
« Reply #4 on: March 09, 2012, 01:41:30 am »
Cool HotBluePlates tell us how its coming along as you go.
Bill
