August 29, 2026, 11:31:48 am
Hoffman Amps Forum image Author Topic: Baldwin Organ Amp Conversion to Carmen Ghia Clone  (Read 53545 times)
Offline Platefire
Re: Baldwin Organ Amp Conversion to Carmen Ghia Clone
« Reply #50 on: April 18, 2012, 09:59:51 am »
Hey HBP/sluckey
I didn't mean to run ya'll off! Like we say here in the South "I was just "funnen around".
I always appreciate your help and advice even if it comes in the form of a mild rebuke, as may be sometimes neccessary. You have my respect! So sometimes I say things jokingly because I'm a generally a happy camper---just wanted you to know I don't mean any disrespect by it. Platefire
On the right track now<><
« Reply #51 on: April 18, 2012, 10:22:48 am »
I ain't gone. Just don't have anything to say at the moment.
« Reply #52 on: April 18, 2012, 06:24:35 pm »
No worries here... I'm southern too!
In any event, my post wasn't meant as a rebuke. All of us amp-heads tend to go through a phase where everything seems like it "just has to be critical, right?" Kind of like the amp blueprinting idea, where if you just use 1% resistors for everything, then you'll have a great-sounding amp. Or unless you use the exact same waxed fiberboard as Fender, your amp won't have that "mojo".
It's somewhat the same with OT's, within some degree of reason.
There is a theoretically "right" primary impedance for a particular tube, supply voltage, class of operation and desired clean output power. But because the speaker doesn't exhibit a constant impedance, the primary impedance will not be constant in practice. So to a limited extent, worrying about anything much tighter than maybe a 20% or so tolerance is maybe not worth the mental stress.
I think from what Sluckey helped you figure out 4 ohms of speaker load should be ideal for this OT and build.  :icon_biggrin:
Offline Platefire
« Reply #53 on: April 18, 2012, 09:59:05 pm »
Well the amps going to a customer. So I wanted to be able to tell him what would be the best match.
John came in and tried to help me on the Ohms and sluckey came in and nailed it. So maybe John and I both learned a little.
For the same customer I built a tweed deluxe type head about three years ago thats clearly marked 8 Ohm speaker on the back of the amp. What did he do, he went and bought a 16 Ohm cab to go with it and thinks it sounds great!!?? Go figure??  :dontknow: Platefire
« Last Edit: April 18, 2012, 10:07:51 pm by Platefire »
« Reply #54 on: April 19, 2012, 05:44:05 am »
Heck yeah,that's why I jumped in!
Now if only I can remember it.
Offline Platefire
« Reply #55 on: April 23, 2012, 10:23:22 pm »
Question??? I just hooked up my heater wiring to two 100 Ohm artifical taps to ground to the two Orange PT heater wires. Same as on the Baldwin circuit except they used two 50 Ohm resistors.
My question is I'm getting continuity with ground on both sides of the 100 Ohm resistor--with the ground side and the PT wire side. I was thinking it shouldn't be continuity on the PT side heater tap?
Is there something wrong here or is that normal? Platefire
« Reply #56 on: April 24, 2012, 04:25:40 am »
Does the PT have the 6.3v heater wires grounded already making the artificial ground unnecessary?
« Reply #57 on: April 24, 2012, 04:35:14 am »
'Continuity' is kinda vague. Do you mean 0Ω, 50Ω, 100Ω, 1000Ω, etc???
The 6.3VAC winding is just a long piece of big wire. Wire resistance is probably only a couple ohms, maybe even less than one ohm. If you also have a real center tap connected to ground, then the resistance reading on both sides of the resistor to ground would be near zero (reading thru the winding). If no real centertap is connected, then the reading on one side of the resistor will be 50Ω and the other side of that resistor will be zero ohms. You could say the two resistors are connected in parallel by to long wire which is the secondary winding.
Offline Platefire
« Reply #58 on: April 24, 2012, 06:47:27 am »
sluckey
To my knowledge this PT has no heater CT. I carefully documented that the orange wires went to the heater wires grounded with two 50 Ohm resistors for artificial center taps in the original Baldwin circuit. I hooked the heater wires up the same way on the new circuit using 100 Ohm Metal oxide 1 watt resistors. On the new heater wiring/circuit with my MM set to Ohms, ground/black term connected to chassis and red/hot touching both sides of 100 Ohm resistors----I get "0" Ohms on grounded side of resistor and 50 Ohms on non-grounded side--just like you said.
When I say "Continuity", I'm using the continuity setting on my MM where you don't get a reading but a "Beep" when you have continuity. So I was saying that I was getting a "beep" on both ends(ground and heater tap) of my 100 Ohm resistors. This confused me a little because I was expecting continuity to chassis on the grounded side of the 100 Ohm only. Also when I connect my MM ground to chassis I get a continuity "Beep" with all heater wiring on tube pins(with no tube connected).
Just as a second check, I pulled the back off my DIY champ that has a PT CT instead of a artifical CT. On all the heater wiring tube pin connections I also got a continuity "beep" to chassis ground on both runs of heater wires going to each tube. So I'm assuming that having continuity "beep" to ground throughout all heater wiring is normal and at least that aspect of my hookup is correct??!! Yes? No? Thanks, Platefire
« Last Edit: April 24, 2012, 07:08:20 am by Platefire »
« Reply #59 on: April 24, 2012, 07:50:23 am »
Don't overthink this. Remember the KISS factor.
Offline Platefire
« Reply #60 on: April 24, 2012, 08:12:09 am »
I think what we have here is a senior moment because I've done this Bokoo times. At least that sounds like a good excuse. I use to just hook-um-up, move on and not think about it!  :laugh:
Offline Platefire
« Reply #61 on: April 24, 2012, 11:13:38 pm »
OK, Demo/Gutting Phase--Done
      Chassis Prep Phase--Done
>>>>On to Circuit Build Stage!
The chassis is kind of hard to handle picking up and moving around, so I added some handles.
Added feet on the bottom plate. Platefire
Offline Platefire
« Reply #62 on: May 08, 2012, 10:18:11 am »
I've been wiring in the CG circuit. This old style point to point without a board is pretty tedious----give me a good turret board and plenty of chassis space any day! I sure hope everything works well when I get it done----I would sure hate to tear some of this tangled mess out.  :sad2:  Platefire
« Reply #63 on: May 08, 2012, 11:28:05 am »
I was just reading this Sunday, and wondering how you were doing with it. :smiley:
Offline drgonzonm
« Reply #64 on: May 08, 2012, 12:22:56 pm »
Finishing the chassis metal.
Get some naval jelly, and rub it on the steel.  The naval jelly contains phosphoric acid and converts the surface to iron phosphate.  It won't rust and gives a nice dark finish.  By the same token you can sign your work using naval jelly. then clear coat it.
Other places to get similar stuff is an auto body shop supply store.
Offline Platefire
« Reply #65 on: May 09, 2012, 12:19:17 am »
Got the power section, output stage and PI wired in. Just lack the input, tone stack and power cord.
I've been taking my time double checking everything along the way. I should have it ready for initial fire up by the end of the week. Platefire
Offline Platefire
« Reply #66 on: May 10, 2012, 05:50:07 pm »
Finished wiring and fired it up today. It works but not good! Found two wiring mistakes---resistor in wrong location and one resistor value incorrect. My fault, but I really think this reverse engineered schematic is not all together correct. I got some really crazy stuff going on here that's kind of got me aggrivated. So I'm going to take a break from it and refresh myself before I resume. Platefire
« Reply #67 on: May 11, 2012, 05:37:49 am »
It's not. Comparing the Ghia schematic to the original AO-35 you'll notice there is a 25µF filter cap missing from node D on the B+ rail. This is the 24v supply for the fixed bias PI circuit. I bet that's an oversight on the drawing and I believe the Ghia really has that cap in place. Real easy to stick one in the circuit. All you need is a 25µF/50v cap. Bet it will sound much better. If this cap doesn't fix it post tube voltages as well as B+ rail voltages.
That PI is an unusual circuit and with the fixed bias supply to the grids and cathodes, it could be easy to make a wiring error too. So, just be careful and precise.
I've compared the two PI and power supply circuits. They are identical except for that missing filter cap. I've attached the orig AO-35 schematic for comparision just in case you don't have it...
Offline Platefire
« Reply #68 on: May 11, 2012, 06:05:29 pm »
sluckey
I got a good nights rest and hit it again this morning. I had put R3 behind the R2 which should have been right behind R1 which cut the voltage on everything downstream plus R5 should have been 82K and I had it 8.2K. So that really had my voltages screwed up. I relocated R3 and the only 82K R I had on hand was a 1/2 watt, so I put it in there until I can get a 3 watt metal. WoW!  when I did that all my voltage readings straightned out. I'm now within 1 to 7 volts difference at every point of distribution throughout the whole circuit. I couldn't of found a better match for a PT if I had tried for this circuit. It's sounding so much better. I don't know what a Carmen Ghia circuit is suppose to sound like but the things I've noticed is as follows:
1-Pretty bright circuit!
2-Tone control adds more bass clockwise and more treble counter clockwise??? backward than normal! I'm pretty sure I've got it wired like the schematic. I can get close to my tone at about 4:00 oclock and volume about 8:00 oclock.
3-Very little clean headroom. Circuit starts to get into pretty heavy breakup a 9:00 or 10:00 oclock on the volume and continually gets more distorted until the last 1/8 on volume and then goes into cut off. Good thing is the distortion had good harmonics :icon_biggrin: I used the 3.3 Meg feedback resitor. Might need to try the 2.2 meg for more headroom. That would be customers call. It will be used in a recording studio--he might like the early breakup.
I didn't add C10 that was marked optional. I'm wondering if I should add it? I had not caught the missing 25/50 cap at node D until you mentioned it! I've got to order R5, so I guess I could order that cap with it. All and all the amp sounds and responds pretty good. It's running pretty quiet too. Thanks, Platefire
BTW-Regarding the 25/50 bias cap, here is what is suppose to be a gut shot of the Carmen Ghia and there is no visable 25/50 cap accross the 8.2K resistor. What do you think?
« Last Edit: May 11, 2012, 11:44:52 pm by Platefire »
« Reply #69 on: May 12, 2012, 11:28:43 pm »
Here's another one and it does have the cap.
Offline Platefire
« Reply #70 on: May 13, 2012, 12:50:54 am »
I had to get the schematic out and study it awhile because the layouts and lead dress of the two pictures are so different--hard to believe both of them are Dr. Z's? So I finally figured out the big silver cap is the 25 uf on your pic. Well I've already put in an order with Doug and included a 25/50 with it. Do you think both pictures are Dr Z amps?
« Last Edit: May 13, 2012, 12:54:21 am by Platefire »
« Reply #71 on: May 13, 2012, 08:54:18 am »
I don't know if either of those amps were built by Dr. Z. I doubt they were built by the same person. I have both those pics in a folder for Carmen Ghia. I had searched for info on the CG several years ago but lost interest. I have some schematics called Pheonix and others called Botany Bay. They're both the same, but not exact copies. I never did find any info claiming to belong to Dr. Z.
My gut logic says the cap is needed. The lower grid on the PI needs to be at signal ground to function as Hammond designed. Don't know what effect omitting the cap will have. Could be part of the CG magic. But it's very easy to tell if you think it's necessary just by patching it in. You can clip it in and out while the amp is running and decide which way you like it better. Give us a report and let us know what you decide.
Maybe PRR or HBP will ring in with some circuit analysis theory.
« Reply #72 on: May 13, 2012, 03:17:46 pm »
A little photo forensics first.
The photo that Platefire posted looks like what I believe is a Dr Z-made Carmen Ghia. I say that because the wiring and board mounting is just slightly better than the chassis in Sluckey's picture, and the chassis is yellowish. Dr Z used to (maybe they still do) use an aluminum chassis which was given a chromate dip; the chromate gives the chassis the yellowish look. Additionally, the red glyptal marking the turrets which have been completed is something Dr Z did (again, I don't know if they continue to do this).
So it looks like the chassis more-likely to be a Z doesn't have the cap (at least in this one example).
But Sluckey's right. This phase inverter (probably the one I'm least familiar with) is a differential amplifier, or basically a fixed-bias long-tail. There is one grid directly driven by the preamp signal, and normally a large-valued resistor over to the other grid, which then usually has a cap to ground. This circuit needs an input signal which represents a difference between the two grids, as a typical gain stage has an input which is a difference between the grid and cathode voltages. Most commonly, this is done by driving one grid while keeping the other at a.c. ground (via the cap), which then results in a difference between the two grids.
You might be tempted to think the resistor between grids makes both grids see the same signal. Assuming no current flows through the resistor, it really keeps both grids at the same d.c. voltage. The cap to ground then looks to signal like 0v, which you could think of as a voltage divider like a volume control turned to 0.
So with no cap, we have a divider made of 470k and 8.2k. Not the same as a.c. ground via the cap, but that keeps what in-phase signal which does leak to the "non-driven" grid relatively small.
I think all-in-all, losing the cap would make the phase inverter have less gain and output swing. The "right way" is to use the cap. I'd be curious to see how large the phase inverter output is with the cap, and whether it drives the EL84s to overload to easily. Maybe Dr Z wanted to hamstring the phase inverter just a little bit to have more range on the volume control.
The easy way is just to try the amp with and without the cap. If you anticipate building more than just this amp, you can probably find a use for extra 25uF/50v caps hanging around.
Offline Platefire
« Reply #73 on: May 13, 2012, 06:09:28 pm »
Thanks sluckey and HBP
I tell you what, if I had enough room I would put the cap on a switch but I'm already very tight roomwise. I might could work it in with a midi switch SPST. When the part comes in I'll just try it out. I don't think I want to loose anymore headroom unless I can make it a switchable option. My customer is in Georgia, so he can't exactly drive over to the house and test. I'll have to make the right choice myself. Thanks a bunch for your help. I'll post the effect the cap has on the amp when my parts come in. I've been jamming on the amp and I'm liking it more and more. I think Randy is going to be happy with it. Platefire
« Reply #74 on: May 13, 2012, 10:51:00 pm »
> regarding the 25/50 cap parallel to the 8.2K resistor to ground on the +24V to PI grid. .... needed or not?
Not needed. I do not know why Hammond has it. I suspect the design changed several times.
The "loss of gain" mentioned is valid... but in the ratio 470K/(470K+8K) or 0.98, truly insignificant.
The 8K does NOT have to be 3 Watt. Tenth-watt is fine, use 1/4W or 1/2W. (The 82K dissipates 0.66W, so a 1W won't live forever, 2W is safe, 3W seems to be common these days.)
BTW: on Hammond if you un-strap points 8 and 9 the PI goes dead fairly benignly. I suspect this was a remote mute so the organ could go dead silent yet be ready to play in a split second. Unlike the guitar-amp custom of de-powering all the plates, this leaves the power tubes cooking, but no signal can get through except the really inaudible hiss of the power tubes.
« Last Edit: May 13, 2012, 10:54:34 pm by PRR »
Offline Platefire
« Reply #75 on: May 14, 2012, 01:32:21 pm »
Well Good and thanks PRR. That solves the riddle of the 25/50 cap. Meantime I've been working on other issues with this amp while waiting on the 82K 3 watt to arrive. I could use some help and would appreciate your input on these issues:
1-Got a very slight humm through the speaker on standby with the power on. Heater taps are grounded with two 100 Ohm artificial CT. I pulled the tubes, still there. My first thought was heater wires too close to OT plate wire. Moved those around with no change. I've moved heater wiring feed from PT in realation to any other close wires and no change. I've tried plugging it in at another room/outlet, no change. Heater voltage measured 6.65VAC under load. You can't hear this hum until you turn the TV off and all other stuff off but I don't have this on any of my other amps--- I think it shouldn't be.
Edit: #2 below was the preamp tube. A brand new EH. It will now go full blown gain with my GE vintage 12AX7.I had tried swapping all the other tubes except the V1.
 2-When cranking the volume up on this amp it goes into complete cut off of sound/volume from 85% to 100% of volume. I've tried different tubes, moving wires around to get seperation and double checked component values/connections---no change. I know it will probably never be used at that volume level but---it shouldn't be cutting out.
3-Tone Stack. I've got it hooked up just like the shematic but counterclockwise increases treble and clockwise increases bass/lows. This is completly backwards from normal but it's wired like schematic!
Hope ya'll have some answers for this. Thanks, Platefire
« Last Edit: May 14, 2012, 03:34:03 pm by Platefire »
« Reply #76 on: May 14, 2012, 04:08:28 pm »
I did the same thing. You have to watch which side of the resistor symbol the <--- wiper symbol is on, I think it changes which side is the CW or CCW. Simple enough to change the components though.
Of course, if I could memorize (without looking it up) what makes a low-pass and high-pass filter, I wouldn't have that problem! :smiley: I need to buy a second Merlin book to keep on my bench.
« Reply #77 on: May 14, 2012, 07:07:49 pm »
This looks like how the tone control works. The interior picture posted before also look like the control is wired as yours is wired.
Look back at the schematic you included in your first post. R24, R25, C16, C17 form a bridged-T filter; C11 is just a coupling cap into the circuit. You could look at C17 as rolling off highs by shunting them to ground, while C16 tends to cut lows and pass highs around the resistors and C17. So the circuit has both high-pass and low-pass parts, and mids are scooped out where the two cross-over.
When the tone control wiper is moved towards the "top" of the pot as drawn, the highs that had been preserved by C16 get shunted to ground through C17. When the wiper is moved towards ground, C17 is shunted which removes the frequency-dependent part of the low-pass filter; this leaves trebles dictated by C16.
I haven't played a Dr Z Carmen Ghia, but the photos posted seem to match your wiring. My best guess then is that the original amp also has a tone control which seems "backwards".
That would be helpful, but isn't the case. Some schematics will place small symbols by the "resistor" of the pot, to indicate which end is the clockwise and counterclockwise ends. Interestingly, the diagonal arrow through the "resistor" of a pot wired as a rheostat might indicate which end is which, but I can never remember how that works.
If the tone control operation bothers you, you could swap which ends everything is wired to. But at least you should know that you're wired correctly according to your schematic.
Offline Platefire
« Reply #78 on: May 14, 2012, 08:54:59 pm »
Thanks HotBluePlates
Good explination on how the tone stack works. I really good with the way it works as far a movment of the knob. With one tone knob it's a no brainer. You turn it to you get the sound you like. For my purposes about 3:00 to 4:00 Oclock is my tone.
Since I've learned the cut off problem was the preamp tube I've expermented with several tubes for best sound and the Baldwin 12AX7 that came in it sounds best so far. I wonder who made those for Baldwin?
I guess there isn't any explination for the low volume hum through the speaker from just AC unloaded operation. I was really trying to get the noise down low as possible because this will be a recording studio amp. I guess he can do what I do and use a noise gate on the amp mic. Downward Expansion works best for me on that.
On hind site I guess we can now confirm that the Phoenix schematic is pretty much right for the Dr. Z Carmen Ghia! We've gone over it pretty thoroughly. Only mistake I found is voltage reading to PI 330K plate resistors at 235V. If you look down in the power supply section at point "C", you see the voltage is 290V which is correct and should be 290V before the 330K resistors. The 235V is correct for the plate voltages on the PI after the 330K resistors.
Thanks a bunch!!! Platefire
« Reply #79 on: May 15, 2012, 09:02:52 am »
Well dang. And here I thought I was so smart.  :laugh:
Offline Platefire
« Reply #80 on: May 15, 2012, 10:17:05 am »
Hi John
Well I didn't even know some pots have symbols to show the movement---first time I heard that!
So I will probably tell the customer how it works and if he has heartburn with that, I can wire the tone pot backwards from the schematic.
  One thing weird I've noticed about this tone stack is even when you have it set on the dark side there is a treble peak or bell tone that breaks through the underlying lows. So even though you may have you neck pickup set for jazz tone when you pick it's going to cut through. This is just jamming by myself, I haven't tried this with a band yet--where the rubber meets the road.
   Both extreams settings of the tone stack are unusable---treble way hollowed out, Bass all flubbed out but to be honest most one knob tone stacks are like that. I keep wondering if a 500pf might be more usable than the present 250pf?
« Reply #81 on: May 15, 2012, 11:51:12 am »
I think a lot of guys end up tweaking the values to get the sound they want.
So far, I've found the simple Big Muff "shift" control to be good with me. But I tend to use the tone knobs on the guitar a lot more to start with, and my ears aren't edumicated enough to pick up subtle differences anyway.
« Reply #82 on: May 15, 2012, 12:17:57 pm »
Well, do you have a clear large photo of the inside of the amp now that it's complete? We might spot something that could be leading to hum.
Be sure to try tube swapping, if possible. Some tubes are just more prone to hum. Likely culprit will be your phase inverter tube; if this tube is prone to heater-to-cathode leakage, the large unbypassed impedance from the cathode of the phase inverter will lead to hum. The solution, since you can't bypass these resistors in the inverter is to select a tube with naturally lower leakage and hum.
Of course, there may be something else that we could spot in the picture.
« Reply #83 on: May 15, 2012, 12:24:11 pm »
Well, you don't want to do that without modeling it some way, or calculating (I'd hate to go through calculations for this circuit). That's because the value of the resistors interacts with the specific values of both caps to define the mid notch. Willy-nilly changing values to alter highs will also change how wide the mid notch is, how deep and what frequency it is centered on.
There are other ways to turn that circuit into a tone control of sorts, but it would require more parts and not give you direct control over the bass or treble alone.
Another thought is that few tone circuits are have extremes that are "usable". Or they might be useful for a novelty sound. As long as something in the middle of the control's range is useful, that's probably good enough. I don't think anyone expects a single-control tone circuit to sculpt the sound like a razor.
« Reply #84 on: May 15, 2012, 10:43:36 pm »
So I did what I suggested and modeled the circuit.
Original values have a mid notch centered around 800Hz. If you raise the 250pF cap to 500pF, the center of the notch drops to ~600Hz; increase that cap further to 0.001uF (or 1nF), and the notch will again move down further to ~400Hz. That will put the mid notch closer to Fender-like values.
The extreme settings of the tone control may still seem less than useful, because they'll try to strip bass or throw away all treble.
There might be some tricks to try with resistors to slightly isolate the tone pot to reduce the tendancy towards the extreme settings, but then it's not a Carmen Ghia anymore, right? What I mean is it might be a good thing to try if it's your amp, but maybe you don't want to muck with a customer's request.
I sim'd a few scenarios to tame the extremes, but I'd need to actually hear what it sounds like to know how to tinker it best. Tweaky stuff like this isn't solved by plotting curves but by trying and listening.
(In case your customer wants suggestions for wrangling the tone control, I see interesting stuff when the 250pF is rpelaced with a 0.001uF cap, a 15k resistor is inserted between the pot and its connection to ground, and a 10k resistor is added from the wiper to the 0.01uF cap. But this shifts the midrange notch down an octave, and may not fiddle the extreme settings the way they might want.)
Final thought: It seems to me Dr Z arranged this tone control to sound most-right near the middle of the tone control sweep. After all, this simulates the tone pot out of the circuit. I think the envisioned use of the tone control was slight changes to either side of center, rather than ever really using the extremes.
Offline Platefire
« Reply #85 on: May 15, 2012, 11:11:21 pm »
I've been jamming on this amp with all my guitars-tele, strat, LP and more and more think the tone stack is fine. Just subtile movements make a big change. So if you are close to your sound and you want a little more treble---a 1/16" movement CCW might do it or for more bass--the same thing CW. I did some google searches about the CG tone stack and from what I read, it is normal to operate the way mine is doing. So I will leave it alone--it's just the CG personality. Main thing is, am I able to find a usable tone setting for all my guitars? answer--yes!
As far as the light hum. It does it with all the tubes removed--no DCV at all. The only way I could imagine the hum getting in the speaker is somehow the live heater wire too close to the OT plate leads that go to the power tubes. They are kind of close (1/8" in one place at 90 degrees in crossing) but when I moved them around with a chop stick there was no change. Can the OT generate any output without any DC power to it?? Other than that--some kind of current in the chassis somehow effecting the speaker through the speaker jack?? I've tried a bunch of things but nothing effects or changes the sound at all. This hum is not an irritating noise but all my other amps go dead silent when the standby is on, so I know it's not normal.
I am going to take a full set of pictures and post them but I've been kind of waiting for my 82K 3 watt resistor to come in and when I open it up again--take the pictures. I'm not really proud of some of my soldering and lead dress on this one. It was so close together, it was hard to make it look nice.
I'm really suprised that it is working as good as it is. It operates pretty quiet with single coils and really quiet with my humbucker guitars.
I was just wondering?? Am i the first one on this forum to build this ciruit?? Platefire
« Last Edit: May 15, 2012, 11:16:46 pm by Platefire »
Offline Platefire
« Reply #86 on: May 17, 2012, 11:48:26 am »
Got the parts in today, thanks Doug!
On attached Phoenix shematic it showns cap C10 (optional .001) in parallel with plate resistor R20 on V1b. Also on attached Dr. Z layout the optional C10 is not there. So if the he copied this from his Dr. Z amp, I am thinking on some amps they included it and some they didn't or how did he determine it was optional?
I recall previous amp discussions paralleling a cap with a plate resistor to stop oscillation--but not sure?  I got the cap, so I guess I could clip it in to see what it does.
I was preparing to do the finishing touches on this amp and was just wondering about it. Any help appreciated. Thanks, Platefire
« Last Edit: May 17, 2012, 11:52:33 am by Platefire »
« Reply #87 on: May 17, 2012, 03:59:02 pm »
That cap would reduce the treble response of that gain stage. The person drawing the schematic might have felt the amp was brighter than he'd like, and drew in an optional way to tone it down.
I think most folks would agree that Dr Z amps are a little brighter or "more present" than some other amps, but I bet performers would agree it helps them cut through on stage it a good way.
Offline Platefire
« Reply #88 on: May 17, 2012, 08:56:40 pm »
  I talked to my Son on the phone today because he once had a Dr. Z Carmen Ghia several years back and ask him his take on it. He said that he got rid of his because of that brighter/more present tone that he said he couldn't seem to tone down. He said the gain structure worked great as far as break up. I recall him bringing it by the house when he first got it and had it running through a 2-12 cab but can't remember what it sounded like--to long. He did say it was normal for the tone stack to work like my conversion is working. Well I got some soldering and picture taken to do :icon_biggrin:
Platefire
BTW-Thanks HBP for the info on the cap on the plate resistor---now I know! I did clip the .001 cap in parellel with the plate resistor for V1b for a test and I couldn't hear any difference in tone regarding less treble. If any, too subtile for me to tell. I also clipped in the 25/50 cap on the 27V supply to PI and I couldn't detect any difference in gain or tone. So I'm leaving those two components out.
EDIT: Tagged some gut shots on this and next post. This is rough 40's/50's style P to P wiring. Not Pretty but it works!
« Last Edit: May 18, 2012, 09:07:35 am by Platefire »
Offline Platefire
« Reply #89 on: May 17, 2012, 11:40:46 pm »
A continuation of gut shots started from last post. I will be posting some completed exterior shots maybe tomorrow.   :icon_biggrin:
« Last Edit: May 18, 2012, 12:20:57 am by Platefire »
Offline Platefire
« Reply #90 on: May 18, 2012, 08:58:16 am »
OK, Here are the finished exterior pixs.
« Reply #91 on: May 18, 2012, 11:55:54 am »
Plate:
You have your red screen supply node wire running parallel to a (yellow?) OT primary wire. It's where that OT wire has to loop out and back before running to the EL84 socket closest to the sidewall of the chassis.
My guess is ripple at that screen node is being coupled into the OT primary wire running paralle to it. Try moving the OT wire with a chopstick (or other insulated tool) and see if that reduces the hum. If it does, you might have to cut that wire shorter to create a straight run perpendicular to the screen wire.
Offline Platefire
« Reply #92 on: May 18, 2012, 01:28:28 pm »
HBP
I've tried to explain but somehow you have not read or understood my explination of this problem and that is this: ! The hum occurs with all tubes pulled and no DCV in amp whatsoever. Adding the tubes in and putting it under a load has no effect on the hum--it doesn't get louder or quieter.
So in my opinion the hum is somehow ACV--either heater or other AC somehow getting in to the speaker outlet and effecting the speaker. I don't know if the OT can have any output without any DCV into it?? just in case I moved heater wires around in close relation to the plate and cathode wires with no change. Only other thing I can figure is some kind of AC being transfered through the chassis? It's got me bumfuzzeled  :dontknow:  and I can't come up with an explination. Platefire
« Reply #93 on: May 18, 2012, 05:49:05 pm »
Do you mean with the rectifier pulled as well? I guess the EL84 heater wires have a point at the terminal strip where they run parallel to an OT primary wire, which is on the other side of the terminal strip.
Or, maybe the power cord is too close to the OT. Or too close to the OT secondary wires.
Try dressing those secondary wires towards the corner of the chassis, away from where the power cord enters. If that helps a little, but doesn't resolve the hum, you may have to relocate the point the cord enters the chassis... probably where the "Remote Cabinet" octal plug is now.
Offline Platefire
« Reply #94 on: May 18, 2012, 10:40:44 pm »
HBP
Yep with rectifier pulled also. Those secondary wires on the PT really have no where else to go. I have tried moving them around to see if it effected the sound, but no effect. To be honest the slight hum is so minimul, it's almost not worth worrying about. Once the amp is turned on, the amp noise actually drowns it out. Not that this amp ideling noise is loud but the noise don't get louder as you turn the amp up--so it is not noticable once you flip the standby to play.
  You might have something about the power cord location because usually the OT is on the other side of the amp from the power cord but on the other hand--the OT should be non-operational without any power running through it---unless the ac normally transmitted from OT to speaker is being picked up somehow from the power cord and generating enough to make a hum. It seems though that moving those wires around like I've already done would change the intensity of the hum to some degree---but the intensity, however slight remains the same level whatever I do. Would the interrferance/hum be transmitted in the air or through the chassis? Could it be shielded? Platefire
« Reply #95 on: May 19, 2012, 12:00:19 am »
Well, it's like how an OT can pick up hum radiated from a power transformer. The large a.c. on the power cord can radiate a field around it's wires, which can be picked up by the OT and transferred to the speaker.
That seems like the only mechanism for hum when the rectifier is pulled. If it's minimal, and everybody's fine with the level of hum, then okay. If not (or for future reference), you want to keep the entry for wall power as far from the OT and speaker jack as possible.
Offline Platefire
« Reply #96 on: May 19, 2012, 02:17:04 am »
I used the same hole Baldwin used for their power cord, seemed they would have known better--so because of that, I used it too but I see what your saying. I think I'll let this one go as is and try to do better in the future.
I expermented with speakers tonight. Since my OT calculates with it's TR to be 5.26 Ohms, I hooked it up to my Silvertone 1482 Alinco 12" Fisher 4 Ohm that actually reads 4.1 Ohms, also my 10" Patriot Emenance Ragin Cajun cab rated 8 Ohms that reads 7.5 Ohms and a 10" Weber feromax rated 8 ohms in my DIY Champ and reads 6.5 Ohms.
The Weber 6.5 Ohms sounds the best. The notes were more compressed or touch sensitive. The tone was less harsh and more rounded. For some reason the noise factor raised a little bit on this speaker and there was a little overall volume loss in overall loudness in comparason to previous volume knob travel. Even with those two issues this speaker was more fun and enjoyable to play to the point it made me feel better about the amps performance.  Platefire
« Last Edit: May 19, 2012, 02:22:10 am by Platefire »
Offline Platefire
« Reply #97 on: May 20, 2012, 08:04:06 am »
Gave this amp thorough workout last night going through all my songs lineup with the wife on piano and my JamMan backing tracks going through the PA.
The amp worked great. With the volume at about 9:00 Oclock and tone at 3:30 Oclock, my favorite tone was nailed with my Hwy 1 Tele. I had a little amp noise but when I switched my looper box to cut the two pedalboard loops out and go staight to the amp the noise disappeared--so the noise was in my pedals/pedalboard. Practiced a good 3 hours last night with no issues. The amp does seem to get pretty warm. Don't know if that's because of the compactness of it or not. The amp's touch responsiveness was very good, took my pedals with no problem and tone/sound coming through my 1-10 Ragin Cajun(7.5 Ohms) cab was very pleasing to my ears. This amp has a certain thickness and chime somehow all at the same time. Also this amp has a clarity of notes that just stands out. Put me on the list of a Carmen Ghia fans now with consideration for possibly building one for myself--but if I do it will be a larger chassis, turret board with plenty of room for a good layout. Platefire
« Reply #98 on: May 20, 2012, 10:36:07 am »
Excellent!
Regarding the chassis heat: if something didn't seem obviously wrong with the amp, you're probably fine. If I play my Deluxe or Super copies for 3 hours, they get pretty warm, too!  :laugh:
I was in a little Nashville shop one afternoon when Brad Paisley came in to try out some amps. A good part of how his sound is distorted but dynamic, thick yet cutting, is the Dr Z amps. I was there when he bought his first Dr Z. It wasn't long after that other, bigger Nashville shops suddenly became Dr Z dealers (this was in 2000, when Dr Z had few dealers, and you still commonly bought your Carmen Ghia through ads in the back of Guitar Player magazine).
Offline Platefire
« Reply #99 on: May 21, 2012, 11:55:10 am »
Thanks HotBluePlates, Sluckey, PRR, John for helping me on this. I couldn't have got this far successfully without you! But----please don't quit on me yet! As much as I would like to be done with this project and move on, I feel like I must persevere with these other noise issues previouly mentioned/discussed. Knowing Randy is going to be using this in his studio I just can't feel right about it until I've done all I can do to make it silent as possible.
I had before mentioned that with the slight humm with all tubes removed I couldn't find anything that would effect the hum. Well this morning I took the cover off, pulled the tubes and tried some more.
I found that by getting some tin foil and wrapping it around the AC cord where it enters the chassis I could reduce the hum in some locations as I rotated it. Also I found by placing a jumper wire on the EL84 plate and touching the other end to ground killed the hum--so it is I think the incoming AC is effecting the OT. So as previouly suggested, think I need to move the cord entry location to behind the PT.
On attached Pix #3 below on tone stack. The white wires from 250pf passing by parellel by DCV power resistors/filter caps to tone pot, white wire to volume from tone pot and white wire from volume to V1b---I think might need to be all sheilded?
On attached Pix#6 I think maybe moving that yellow cathode wire running under the resistor and parallel to the heater wires and screen DCV wire would benifit being run above the resistor.
« Last Edit: May 21, 2012, 12:07:32 pm by Platefire »
