July 29, 2026, 06:44:04 pm
Hoffman Amps Forum image Author Topic: Crate Vintage Club 60 Part ID  (Read 9808 times)
« on: March 16, 2012, 08:22:04 am »
I cant find the Crate Vintage Club 60 schematic
I am looking for the value of the AC suppresion cap seeing as the one i removed from the board is missing the top half of the cap
Im thinking .047 or .1 600V?
Re: Crate Vintage Club 60 Part ID
« Reply #1 on: March 16, 2012, 08:38:42 am »
» Crate General Contact Infomation
For general questions please email:
misupport@loudtechinc.com
Ciao
Kagliostro
« Reply #2 on: March 16, 2012, 08:42:51 am »
Thanks  kagliostro! I just emailed them. There are a few schematics that are just plain hard to find or not available at all for free. I did find a site a while back that sells just about every schematic using Paypal
By the way! What makes these supression caps smoke out? AC voltage surge or cap material? The paper and metal impregnated caps are suppose to be quieter but they have a higher failure rate.  Never really questioned what makes them blow
« Last Edit: March 16, 2012, 08:50:08 am by plexi50 »
« Reply #5 on: March 16, 2012, 01:15:24 pm »
Ok i have to stop work and ask what is this part VR1 on the schematic? Cap,Resistor?
I cant find a symbol that matches the one on the crate schematic for VR1. Im thinking resistor anyway
I called crate and they have no data or manufacturer part data left for this amp
« Last Edit: March 16, 2012, 01:33:04 pm by plexi50 »
« Reply #6 on: March 16, 2012, 01:33:01 pm »
A thermistor?
« Reply #7 on: March 16, 2012, 01:34:26 pm »
I dont know. What i think is i screwed up by putting a .047 cap in that spot and im not getting AC to the PT
It's one of those days ya know/
« Reply #8 on: March 16, 2012, 01:51:15 pm »
I think your right Willabe
http://www.newark.com/ametherm/sl22-1r020/ntc-thermistor/dp/72J6816?in_merch=Popular Products&in_merch=Popular Products&MER=PPSO_N_C_EverywhereElse_None
I dont have any. Is there any other substitute method i can use?
« Reply #9 on: March 16, 2012, 02:13:59 pm »
A varistor act in similar way, but not due to current across it, it acts when a larger voltage cross it, so isn't usable for this purpose
if you where in the B+ rail as the brimistor in Vox AC50 you can use this circuit
but you are still in the AC side of the PS
as a temporary solution you can use a large (in W) resistor
Kagliostro
« Last Edit: May 18, 2013, 09:43:09 am by kagliostro »
« Reply #10 on: March 16, 2012, 02:26:09 pm »
I'm not sure you have to use it? If it's a thermistor it's just to slow down the in-rush current, which is a good thing, but shouldn't be necessary.      :dontknow:
                               Brad
« Reply #11 on: March 16, 2012, 02:27:28 pm »
Could i use a 470 ohm 10 watt resistor just to test the circuit out or would i ues a higher value resistance
« Reply #12 on: March 16, 2012, 02:32:31 pm »
I think you can use that 10W resistor, I don't think you want to use the amp for a long time
maybe 470R is a bit high as value, you must consider that isn't an NTC and those 470R will be always at the same value, it will be something like using a light bulb
Kagliostro
« Reply #13 on: March 16, 2012, 02:47:44 pm »
I think kagliostro is right, 470R is too much. 10R@10w should be plenty. It's just to slow down the in-rush current, once that's over it's like the thermositor isn't there.
I think you can test the amp with out either.
« Last Edit: March 16, 2012, 02:54:49 pm by Willabe »
« Reply #14 on: March 16, 2012, 03:12:37 pm »
Well i think it's over at this point because the PT is dead so i dont think im going to find one for it
I called Crate and they done even have the data on who made there transformers for this amp anymore. They did say they were proprietary. That says it all
Offline Shrapnel
« Reply #15 on: March 16, 2012, 03:25:33 pm »
That could easily explain why the thermistor blew. Now as far as it being proprietary? Well, unless you can tell size/mounting is going to be an issue, a little circuit tracing, and some guess work on what the working voltages were should yield, if its possible, a workable drop-in, or if you'd need a custom model made.
-Later!
« Reply #16 on: March 16, 2012, 04:17:09 pm »
The PT info i found is on the new topic i posted for the bad PT
« Reply #17 on: March 16, 2012, 05:03:52 pm »
What a bunch a horse pucky! It's PT not a missile or rocket ship.    :cussing:
                               Brad      :laugh:
