August 29, 2026, 11:24:10 am
Hoffman Amps Forum image Author Topic: 5e3 hi/lo jack wiring from library  (Read 4205 times)
Offline olgoat
« on: April 02, 2012, 09:51:00 pm »
I was going through the library and saw Hoffmans suggestion on wiring hi/low jacks.   It looks like he relies on the chassis to jack contact for ground.
Is this the way most do this?  Looking at the Ceriatone layout I was working from, it looks like they wire the ground tabs to a chassis ground.  The Hoffman pic certainly looks simpler.
Thanks for your thoughts and comments
Re: 5e3 hi/lo jack wiring from library
« Reply #1 on: April 02, 2012, 11:27:30 pm »
Maybe 50/50.
Classic US practice is to ground metal input jacks on chassis.
There are also plastic jacks which must be grounded via wire.
Either way can work fine.
