August 29, 2026, 02:48:46 pm
Hoffman Amps Forum image Author Topic: Dual Bias or Bias and balance  (Read 6117 times)
« on: April 06, 2012, 01:51:30 pm »
I am going to use this layout, but I put bias controls on the back with probes.  What do you think would be the best setup.  To separate into dual bias, or a bias/balance?  NOS 6v6 singles are cheap.  I will have a 50v bias tap PT.
Re: Dual Bias or Bias and balance
« Reply #1 on: April 06, 2012, 04:53:13 pm »
           :w2:                  Where?
Less than 6L6's or EL34's, but still.....       Ed did you win the lottery and not tell us????       :laugh:
I like the idea of dual bias, but it can be a pain to work it in space wise.
Edit; just saw you wrote singles, sorry.
« Last Edit: April 06, 2012, 04:55:17 pm by Willabe »
Offline RicharD
    • Toxic Water
« Reply #2 on: April 07, 2012, 01:44:18 am »
Either dual or balance is fine.  Depends on if you want them independent of each other.
Offline FYL
« Reply #3 on: April 07, 2012, 06:20:05 am »
I prefer bias + balance - it's easier to dial-in the right voltage - but dual bias pots are OK.
Offline Fresh_Start
  • noob de Lux
« Reply #4 on: April 07, 2012, 08:09:03 am »
Do you have a schematic of the bias & balance circuit that you like?
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #5 on: April 07, 2012, 10:47:46 pm »
Cheers,
Chip
No, I do not have a schematic, have you seen one?
Offline Fresh_Start
  • noob de Lux
« Reply #6 on: April 08, 2012, 10:35:14 pm »
Cheers,
Chip
Kevin O'Connor has one in "The Ultimate Tone" Vol. 1 IIRC but it looks really hard to figure out what the component values need to be.
I've attached one that I saved in 2010 based on this thread:
http://www.el34world.com/Forum/index.php?topic=8863.0
Note that FYL offered up a circuit there, so he responded to my request before I asked!  Actually, I ought to bookmark that thread so I can find it again when I want it.  Elegant French is just so... elegant!
Cheers,
Chip
Quote from: PRR
« Reply #7 on: April 13, 2012, 09:18:06 am »
In reviewing the schematic, it shows creating adjustable bias, the balance from the PT voltage.  If you had a bias tap of 50v and were using 6v6, would the wiring be the same except you would not need the 120K resistor?  What else would need revised.  I am assuming the pots are connected center lug to center lug.
