September 16, 2026, 03:57:30 pm
Hoffman Amps Forum image Author Topic: DC coupling...  (Read 7300 times)
Offline bruno
  • got to love that glow
DC coupling...
« on: May 02, 2012, 05:47:08 am »
Anyone here tried building an amp with a direct coupled gain stage?
I'm interested in trying one, to check the results.
Re: DC coupling...
« Reply #1 on: May 02, 2012, 06:43:46 am »
Do you mean in cases other than d.c. coupling from a plate-loaded stage into a cathode follower?
5F6-A Bassman
Offline bruno
Re: DC coupling...
« Reply #2 on: May 02, 2012, 07:30:26 am »
Hi HBP,
I'm refering to DC coupling as shown in Merlin's book... coupling two gain stages directly, no coupling cap, the previous stage affecting the bias of the following!
Re: DC coupling...
« Reply #3 on: May 02, 2012, 08:41:22 am »
If that is the one you're referring to, Geezer's HoSo amp (which I also built) does exactly that. It sounds great.   :smiley:
Offline bruno
Re: DC coupling...
« Reply #4 on: May 02, 2012, 09:22:19 am »
That is exactly what HBP indicated in the 5f6-a schematic... as anyone tried doing the DC coupling to a regular gain stage, rather than a cathode follower?
Re: DC coupling...
« Reply #5 on: May 02, 2012, 06:14:07 pm »
Probably no, without a negative supply handy (the bias supply may or may not be suitable).
Why? You can't use the coupling cap to block the first stage's plate voltage from the second stage's grid. Since the grid will probably be (in a preamp stage) near 1-3v more negative than the cathode, that means the 2nd stage's cathode voltage has to be a couple volts higher than the 1st stage's plate voltage.
Same problem applies to the 3rd stage, but now it has to be that much higher than the 2nd stage, and twice as high compared to the 1st stage's plate.
The cathode follower naturally will have it's cathode close to the prior stage's plate voltage, due to the large cathode load. The direct coupling actually causes the tube to settle to an operating point where the cathode is slightly higher than the grid voltage.
Design of a 3-stage amplifier using dc coupling throughout is a major feat of engineering; you can pretty much forget most hobbyists going for 4 or more stages, without copying a known good plan. There are also few of those known-good plans, because the hassle usually outweighs any benefit obtained from eliminating the coupling caps.
Note also that you lose the single biggest tone-shaping mechanism found in your amp.
Offline bruno
Re: DC coupling...
« Reply #6 on: May 03, 2012, 03:15:09 am »
As usual the HBP, thank you. I got curious, because other then the obvious DC coupled cathode follower, I had never thought about dc coupling stages until reading Merlin's book. A whole preamp with dc coupled stages would be a tough job for sure, thanks for the interesting reply!
Offline sdp1234
Re: DC coupling...
« Reply #7 on: May 03, 2012, 03:10:36 pm »
Take a look on the AX84 site.  There has been a lot of work done with DC (resistive coupling).  Search DC Drive, DC-Drive, Melissa, Raffler.  Most of the activity on dc drive was several years ago.
http://www.ax84.com/bbs/index.php?area=-1
