September 14, 2026, 10:21:13 pm
Hoffman Amps Forum image Author Topic: Diode/GZ34 wiring... I'm confused!  (Read 29695 times)
Offline bluesbear
« on: May 08, 2012, 03:40:38 pm »
I've seen a number of was to run diodes across a GZ34 as protection but I don't understand this one. As you can see, the diodes are run from pins 7 to 6 and 5 to 4. I've seen pins 7 and 5 to pin 8 or between the PT and pins 5 and 7. What is the reason for this particular wiring scheme and how does it work?
Dave
Re: Diode/GZ34 wiring... I'm confused!
« Reply #1 on: May 08, 2012, 03:58:27 pm »
The ss diodes are simply in series with the tube diodes. Pins 5 and 7 are not connected inside the tube and are just being used as a convenient terminal to mount the ss diodes.
Offline drgonzonm
« Reply #2 on: May 08, 2012, 05:01:35 pm »
I see the nice red wires, but where do they tie into in the circuit?
Offline bluesbear
« Reply #3 on: May 08, 2012, 05:34:03 pm »
If pins 5 and 7 have no internal connection, what are the diodes in series with? It makes zero sense to me. There must be more to it. Those diodes weren't added for beauty... unless, of course, this drawing is incorrect. It's supposed to be from a Bluesbreaker Ceriatone.
Thanks,
Dave
Offline blackcorvo
« Reply #4 on: May 08, 2012, 06:06:12 pm »
Pins 5 and 7 are connected to the PT, and the silicon diodes are connected to pins 4 and 6 (the plates for the GZ34's diodes).
That means the silicon diodes are connected between the PT and the GZ34.
In other words:
PT----|Silicon>|----|GZ34(---|
                                          |_____B+
I hope this can clarify thigs for you now  :icon_biggrin:
I remember seeing people using these NC pins to add an optional SS rectification, so they could switch between the two if desired.
« Last Edit: May 08, 2012, 06:10:56 pm by blackcorvo »
She/Her since August 2021
stratele52
  • Guest
« Reply #5 on: May 08, 2012, 06:07:50 pm »
+1 blackcorvo, that is what bleusbear need
« Reply #6 on: May 08, 2012, 07:11:08 pm »
The red wires are the high voltage leads from the PT secondary.
« Reply #7 on: May 08, 2012, 07:31:52 pm »
Hi bluesbear, maybe this will help?
I left out the ceramic disc cap, it's for killing the ss diode hash/noise.
Edit; Doh! I had 1 leg of the 5v heater supply going to pin 1 instead of pin 2. Drawing fixed. Sorry all.     :w2:
« Last Edit: May 08, 2012, 09:46:28 pm by Willabe »
« Reply #8 on: May 08, 2012, 08:10:46 pm »
« Reply #9 on: May 08, 2012, 08:25:00 pm »
Is this a safety feature or for some other purpose?
Offline Shrapnel
« Reply #10 on: May 08, 2012, 08:44:08 pm »
Safety feature. If the tube recto were to short out, it would overload the secondaries (possibly) of the PT, but it will also dump AC into your amp, and this can destroy your filter caps, sometimes violently if they are very intolerant of reversed voltages. The SS diodes in series with the recto plates will prevent this.
-Later!
stratele52
  • Guest
« Reply #11 on: May 09, 2012, 04:42:41 am »
If this append the fuse will blow ....normally. But these diodes ere a good protection for a very cheap price.
« Reply #12 on: May 09, 2012, 09:02:21 am »
Another diagram/
Offline bluesbear
« Reply #13 on: May 09, 2012, 02:39:14 pm »
Sorry, I see it now that it's not midnight. Of course, the red wires from the PT go to 6 & 4, not 5 & 7. I was going to use a terminal strip to add the diodes. This is better. This WAS a case of a dumb question... or a dumb response to the correct answer.
Dave
stratele52
  • Guest
« Reply #14 on: May 09, 2012, 04:04:55 pm »
Another diagram/
Your diagram Plexi50 is very interesting for bypassing tube rectifier with silicon Diodes. This will remove tube's sag and boost voltage. With the switch , you can choose.
It is not a safety diodes use  like the post by bluesbear
« Reply #15 on: May 09, 2012, 06:02:42 pm »
No, you had it right the first time.
The ONLY reason for these diodes is if one or both tube rectifier sections shorts from cathode to plate. If you have the solid state diodes added as per your original drawing, then when a side of the rectifier is shorted, the solid state continues to rectify the B+.
Yes, the red wires normally run to pins 4 and 6, but you will be using those pins as one mounting point of your series diodes. Since the convenient point on the socket for mounting the other side of the diodes are pins 5 and 7, then your red wires will run to those pins.
When the tube rectifier is functioning properly, the solid state rectifies the B+, and the tube drops the voltage as normal. If a tube rectifier section shorts, the output voltage will rise somewhat, but the amp will continue to function properly. A more severe short (probably external to the tube, from a socket pin to chassis) will be required to cause a fault that will pop the fuse.
Offline bluesbear
« Reply #16 on: May 09, 2012, 07:50:41 pm »
I'm also fusing the circuit. A 5AR4 shorted in my son's amp and took out the filter cap can and the PT. That was way too expensive! It's not going to happen again if I can help it... and I think I can.
Thanks,
Dave
Offline xm52
« Reply #17 on: May 09, 2012, 08:40:10 pm »
Adding a silicon diode in series with the plate of the tube rectifier increases the peak inverse voltage capacity over just just that of the 5AR4. Doing this allows you to put a larger capacitor after the tube rectifier. Without it, you can get flash over in the tube when you first power the amp up due to the current draw of the charging capacitor. It serves to protect the tube rectifier.
As an example, Fender does this on their 57 Deluxe reissue amp http://support.fender.com/schematics/guitar_amplifiers/57_Deluxe_Fender_57_schematic.pdf.
Offline Fresh_Start
  • noob de Lux
« Reply #18 on: May 09, 2012, 09:58:11 pm »
R. G. Keen wrote about this use of diodes in Immortal Amp Mods.  There are 3 additional installments, all having to do with protecting the power supply and transformers.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
stratele52
  • Guest
« Reply #19 on: May 10, 2012, 04:45:32 am »
Thanks,
Dave
I'm afraid that even with these diodes, if the the tube rectifier short this can destroy you PT . A short at the secondary of the diodes will draw too much current from the Power Transformer.  And if fuse at the primary don't blow your PT will be destroy.
Is this make sense for you ?
stratele52
  • Guest
« Reply #20 on: May 10, 2012, 04:56:10 am »
IMO in the Fender 57 Deluxe schematic , it is F2  the best ( and only ? ) protection for saving PT from rectifier tube shortening or any B+ line short . Semiconductor Silicon diodes will only protect filter capacitors from AC voltage in case of rectifier tube short .
Offline bluesbear
« Reply #21 on: May 10, 2012, 08:12:19 am »
Well, I've added every protection shown in the 57 Deluxe schematic plus a couple more, thanks to the "Immortal Amp" mods. It should be as safe as is possible to make it. As I've been playing since 1965 and this is the first time I've had to deal with it, I feel pretty safe. There's no such thing as perfect but I've done all I can. The only alternative is to quit playing. Ain't gonna happen!
Thanks,
Dave
« Reply #22 on: May 10, 2012, 08:29:05 am »
I did the diodes on the little SE I built as rect. protection, but didn't install the .001/3KV cap across them. Could that be the cause of what sounds like faint speaker buzz, but isn't? I tried another speaker to eliminate that. I'm the only one that hears it, and only then if I'm listening for it, but still. Taint right!
stratele52
  • Guest
« Reply #23 on: May 10, 2012, 08:57:01 am »
Thanks,
Dave
First time this append from '65 ! So you don't need to re design an amp for one bad luck in 45 year. Can we say today's tubes are cheaper so this can append more often ?
« Reply #24 on: May 10, 2012, 09:36:20 am »
Take the ss diodes out and see if you still hear it.
Then you'll know.
            Brad      :icon_biggrin:
« Reply #25 on: May 10, 2012, 09:37:36 am »
But I'm too busy playing it to do that.  :laugh:
Offline bluesbear
« Reply #26 on: May 10, 2012, 09:56:51 pm »
I don't mind the rectifier tube burning out. In fact, I expect to replace them occasionally. I'm only a little upset that the filter cap can was destroyed. It's a pain but not too expensive. What really bugs me is losing the power transformer. That is way more trouble and expense to replace than adding the safeties.
Dave
Offline bluesbear
Re: Diode/GZ34 wiring... one last question
« Reply #27 on: May 13, 2012, 04:40:17 pm »
What is the purpose of the .01uf 3KV cap between pins 4 and 6? I hadn't noticed that until I started soldering.
Thanks,
Dave
« Reply #28 on: May 13, 2012, 04:51:23 pm »
Dave, that is the cap I was talking about too. It is supposed to filter/smooth out the sound of the diodes operating, if I understand correctly. When I get a chance I'm going to tack one across the diodes on that little SE and see if it doesn't get rid of the faint "speaker buzz" that isn't speaker buzz.
Offline xm52
« Reply #29 on: May 15, 2012, 05:43:20 pm »
Yes, as John stated, that capacitor filters high frequency hash. I've never found the need for one with fast switching diodes but it doesn't cost a lot and would come in handy of noise is present.
In some amps you will see a large value capacitor to filter 60 or 120 Hz and there is a small value capacitor, often ceramic, in parallel as shown below. In the circuit, the capacitors are part of an LRC circuit. The larger capacitor usually has a low resonant frequency and is effective at filtering hum but not high frequencies. The ceramic capacitor, with a high resonant frequency, doesn't do anything at the lower frequencies but does filter at very high frequencies. So each capacitor covers different bases.
Offline MaJiG
A Caveat
« Reply #30 on: August 20, 2013, 08:33:38 pm »
This thread is pretty old, but I just to have to add a caveat. The idea to use the unused pins of the GZ34 socket to add the series resistors is attractive one. When I first started adding the "safety"/"helper" diodes I did use them, however now I don't.
The problem is after the mod is made and the amp is returned to the user. If anytime in the future some guy gets the the bright idea of dropping in a different rectifier tube that might use one or more of those "unused" pins, you run the risk of an arc welding demonstration. These days I place the diodes between the plate pins and the primary winding to avoid any problems downstream.
Of course I keep leads short and use shrink wrap.
I started by using 1N4007's, and then swapped to 1N5399's (thanks to Gerald Weber) which added 50% more current handling. Lately I found the UF5408, which has twice the current handling of the 1N5399 and three times the 1N4007's max current.
The UF5408 is a FRED (Fast Recovery Epitaxial Diode) and seems to have reduced switching transients (when the slow tube is shorted or bypassed). I am going to get a scope on these when I get the time.
Just my tuppence...
« Last Edit: August 20, 2013, 08:46:03 pm by MaJiG »
« Reply #31 on: August 20, 2013, 09:22:31 pm »
Which rectifier tube would that be???
Offline MaJiG
« Reply #32 on: October 03, 2013, 01:06:17 am »
Well, my post was generic and was more a corollary to Murphy's law,  but the 5X4 has its plates on 3 and 5, for instance.
I stand by my modest caveat on general principle and everyone is free to accept or reject it.
« Last Edit: October 03, 2013, 04:11:10 am by MaJiG »
