September 18, 2026, 10:51:10 am
Hoffman Amps Forum image Author Topic: Hmmm what to build with these trannies  (Read 5386 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: May 15, 2012, 11:51:15 am »
Ello ello!
I considered naming this thread, "What to do with these trannies?"...  :icon_biggrin:
Here's where I am - a few years ago I built a single channel AB763 (no verb/trem) x 4 6l6 and initially liked it, but found that the tone controls were not really all that effective.  It had the basic Fender tone, but I don't really think it was all that "blackface".  It was actually very flat and midrange heavy, lacking the sparkle and chime I expected, so I probably missed the boat somewhere..  I've decided to strip it down and start over with a new build, as this is my backup amp.    So here are the parts that I have available -
Power
Hammond 290FX (335-0-335@450mA, 60V bias tap, 6.3VCT@5.5A)  - I think I was getting around 430-440vP out of this
Heyboer JTM-45-E
Output
Heyboer JTM-45, Multi-tap (40w, 6.6K primary)
Choke
Hammond 194B (4H, 90mA)
17.5" x 6.5" x 2.5" chassis
What are some options?  I'm not opposed to building another AB763, but was curious about other circuits for nice chime (and maybe a lil grit).  Definitely open to hearing any and all opinions.
Thanks!
« Last Edit: May 15, 2012, 01:42:01 pm by fdesalvo »
FDeSalvo,
Principal Engineer & Owner,
Re: Hmmm what to build with these trannies
« Reply #1 on: May 15, 2012, 04:12:37 pm »
The power transformer could support any 2-4 output tube amp. The OT could support a pair of EL34 or (more likely) KT66/6L6.
Your preamp isn't dictated by your transformers.
« Reply #2 on: May 15, 2012, 09:24:45 pm »
trainwreck express.
:icon_biggrin:
« Reply #3 on: May 15, 2012, 10:47:42 pm »
Fix the preamp and tone controls. Don't gut a perfectly working power stage.
Offline fdesalvo
  • "...I can walk!!"
« Reply #4 on: May 15, 2012, 11:39:31 pm »
Thanks, guys.
PRR - you beat me to the punch.  While I rebuild the preamp in this amp, I will build another amp in tandem.
FDeSalvo,
« Reply #5 on: May 16, 2012, 07:09:06 am »
Where's the schematic for your existing build fdesalvo? It may simply be a matter of tweaking a few things here and there, and if you put the schematic up, we could all confuse/confound you with our opinions ;-)
Offline fdesalvo
  • "...I can walk!!"
« Reply #6 on: May 16, 2012, 10:41:47 am »
http://www.el34world.com/Forum/index.php?topic=5513.0
I built this pup - It was suggested that I remove the voltage divider before the PI, but I built it as you see it here.  The voltages are fine in the preamp, though the 6L6 plates are about 30V shy of listed specs (fender twin schem).
FDeSalvo,
