August 29, 2026, 11:28:19 am
Hoffman Amps Forum image Author Topic: Hammond 270FX Primary wires ?  (Read 4585 times)
Offline worth
« on: May 22, 2012, 02:06:28 pm »
I just received this PT.. it's got three primary wires , white , black , and grey. What IS the grey wire ? It's not really clear on the wiring diagram ?
Re: Hammond 270FX Primary wires ?
« Reply #1 on: May 22, 2012, 02:12:38 pm »
Scroll to the bottom of this page.
Apparently, Hammond made a change to their PT's in 2009, but they still haven't updated the diagrams on their boxes. I got a Hammond PT a few months ago, with the same lack of indication on the diagram for the gray wire.
I suggest using the 125v wiring (white, black wires) to avoid the too-high voltage that used to be common with Hammond PT's.
« Reply #2 on: May 22, 2012, 02:14:30 pm »
Use white and grey if your line voltage is 115VAC. Use white and black if your line voltage is more like 125VAC.
